Gravitationtrouble setting up equation
  • Thread starter Thread starter Saladsamurai
2 replies · 3K views
Saladsamurai
My problem lies in setting this up.
A particle of mass M is split into two pieces, M and M-m, and are set some distance apart.
What ratio of m/M maximizes the magnitude of the gravitational attraction.
I will definitely be needing [tex]F_g=\frac{Gm_1m_2}{r^2}[/tex]
I know that after making appropriate substitutions I get.
[tex]F_g=\frac{GM(M-m)}{r^2}[/tex]
but my problem is in how to compare what happens as m-->M?
Any thoughts in the set up?
Thanks,
Casey
Thanks,
Casey
You mean that the pieces are m and M-m!
basically, you have to optimize the product m(M-m) as a function of m. Just take the derivative with respect to m and set the derivative equal to zero. That will give you the optimum m and then you may calculate the ratio m/M.
nrqed said:
You mean that the pieces afre m and M-m!
basically, you have to optimize the product m(M-m) as a function of m. Just take the derivative with respect to m and set the derivative equal to zero. That will give you the optimum m an dthen you may calculate the ratio m/M.
AWWWW! I knew that! I wrote out the product wrong! Thanks nrqed
Casey!
