Gravity -- Does gravity depends on atmosphere?
  • Context: High School
  • Thread starter Thread starter san D
    Atmosphere Gravity
31 replies · 6K views
san D
Astronomy news on Phys.org
Mass and mass only.
(Now gravitational force, on the other hand, depends on mass and distance)
The answer could be just as well 'yes'. It all depends on what you actually mean.
Why won't you try being a bit more descriptive? What exactly is it you want to find?
My answer would be no, it's the other way around. The atmosphere depends on gravity. sanD, you don't seem to be putting much (ANY actually) research into finding this out on your own. This is not one of those forums where you ask trivial questions and someone tells you the answer, it's a forum where we try to help people figure out how to get answers on their own. The first thing to do on your own for a question like this is type the question into Google and see what pops up. If that doesn't quite give you want you want, come here with a more focused question.
A body on a planetary surface will experience a different gravitational acceleration depending on what radius they are from the gravitational source's mass centre (core). This body will also likely be under atmospheric pressure, with a summed force in the same direction as the gravitational acceleration. Does this atmospheric force compound the gravitational force or will the atmospheric force have a net of zero?
I'm going to take a guess at what the OP may be thinking about... which may be related to the different meanings of mass vs. weight...
When you "weigh" something in the conventional sense, in open air, you're actually not "weighing it" as much as you are determining how much "heavier" it is than air (or comparing the differences between the force on the atmosphere due to gravity and the force on the object due to gravity). It's a little easier to see what I'm getting at if you take the example of if we take a scale of infinite mass to the bottom of the ocean. If you placed a rock on a scale, you don't get the same "weight" as you do on land, even though gravity is (essentially) the same.
Like i said, I am just taking a guess of what the op may have had in mind when they asked the question...
no, but the opposite is true when it comes to a planet having an atmosphere.
Without significant mass, the planetary body won't have a strong enough gravity to retain an atmosphere
Read post #6. You're a day late :smile:
phinds said:
Read post #6. You're a day late :)
LOL didn't even see that in your comment as I read through the thread ...
well at least I gave you good backup ;)
Dave
Perhaps he wants to know if the effect of gravity feels stronger with greater atmospheric pressure. I'm not sure it works like that, I think a strong gravitational pull would crush you into the ground whereas a high atmospheric pressure would be more like an implosion. Or am I wrong?
You are right. Well, a crushing rather than an implosion but I see that you were thinking in the right direction.
In any case, it gets boring trying to figure out what some random posted comes and asks and then goes away and you never hear from them again. Maybe he'll come back to say what he really wants to know but don't hold your breath.
Confused about this the gravity changes when we move out of the surface of Earth at the same time we can observe atmosphere also changes that's why i confused
Did you think the Earth's atmosphere just goes on forever into the universe? Of course it tapers off as you get higher, as does the force of gravity. What is confusing about that?
I will agree that gravity depends on mass only ...then the gravity of uranus must be greater than Earth's gravity because uranus is bigger than Earth but it's not why...?
san D said:
I will agree that gravity depends on mass only ...then the gravity of uranus must be greater than Earth's gravity bcz uranus is bigger than Earth but it's not why...?
That is probably surface gravity you're thinking about, which can be greater for a less massive object because the surface is farther away from the center of gravity in the massive object.
Gravity doesn't depend on mass only, but also on distance from the source. The gravitational force equation shows that clearly:
$$F=G\frac{Mm}{r^2}$$
(G is the only constant here)
Dividing both sides by m(test particle mass) you get the gravitational acceleration:
$$a=G\frac{M}{r^2}$$
As long as the two objects you're comparing have the same density, the larger an object is(greater r), the greater its gravity because as you increase radius the mass increases faster than the square of radius:
$$M=V\rho$$
where ρ is the density and V is the volume of a sphere
$$V=4/3 \pi r^3$$
Combining the above you get $$a=4/3G\pi r \rho$$
If you'll make one of the objects less dense, its surface gravity will fall down. As long as you make the density fall by the same fraction as you increase the radius, the surface gravity will stay the same.
With Uranus, its density is 4.3 times lower than Earth's while its radius is 4 times larger.
As I said: gravity depends only on mass. The gravitational force experienced at some point depends additionally on its distance from the mass. A fine distinction perhaps, but a distinction nonetheless.
Could you clarify what you mean by gravity?
Fun thread.
I was thinking of Bandersnatch's alternate interpretation of the problem from the get go.
Just did the math.
It was very fun.
Wait. What was the original question?
Yes! As atmospheres have mass.
Duh.
Gravity is an intrinsic property of anything with mass.
Gravitational force is an effect of gravity, modified by distance.
But now you're causing me to doubt my convictions... :s
With the caveat that you've just made me doubt mine...
How would that definition work? Isn't it just synonymous with mass?
Bandersnatch said:
... Isn't it just synonymous with mass?
Noooooo! Don't say "MASS"! It'll attract those stress-energy-tensor fellows, with their "momentum warps space too" mumbo jumbo...
And then my head will explode, again.
I got clear idea frnz gravity depends on density of the object Uranus is hav less density than earth
Earth's gravity also varies with density w.r.t oceans,mountains etc..
san D said:
I got clear idea frnz gravity depends on density of the object Uranus is have less density than earth
Not entirely. The density of the Earth could change but it would have the exact same gravity as long as it's mass stayed the same.
It's better to discuss gravitational force at certain points, because what would change is the distance between the center and the surface.
This is only correct when talking about gravity(force or field) far away from the source. This whole discussion is about surface gravity, even though that might have not been clear when it started. For surface gravity that statement doesn't hold as you can't change density and keep mass constant without changing radius, so let's not confuse the OP needlessly.
Oh, you know what I meant, Om. We're all simple people here, talking about ye olde Newtonian ideas and none of that GR woo-woo.
He commented on the strength of Earth's gravity varying at different places. This is not really a density issue but a distance from the center issue. Otherwise, the strength of gravity would be weaker if you were in a boat then on land at sea level.
But yes I completely understand what you're saying.
