Mentor
- 51,163
- 27,186
jartsa said:When approaching:
Objects gain momentum towards each other.
When the light has disappeared:
The momentum of the black hole =
The momentum of the black hole at time t + the momentum of the light at time t
(t can be chosen freely)
Once again, you are using a coordinate chart in which you can't assume that conservation of momentum works. Unless you have done the math, you can't just help yourself to the above statements. A coordinate chart in which a black hole is moving does *not* work like a standard inertial frame in SR, nor does it work like standard Schwarzschild coordinates in GR.
jartsa said:Velocity change of the black hole = momentum change / mass
Even if the coordinates you are using did work like standard coordinates, this would not be true; relativistic momentum is not mass times velocity. You really need to do some math on this problem.
