How Does an Object's Weight Change from Earth to Moon?
  • Thread starter Thread starter XylophoneDealer
    Gravity
The discussion focuses on the gravitational changes experienced by an object transitioning from the Earth's surface to the Moon's surface. Key equations include the law of universal gravitation, represented as GM1m / x^2 = GM2m / y^2, where M1 is the mass of Earth and M2 is the mass of the Moon. The total distance between Earth and the Moon is approximately 3.8e8 meters, and the mass of Earth is 6e24 kg, which is 81 times that of the Moon. The critical point where the resultant gravitational force is zero, referred to as point P, can be determined by solving for the ratio of distances x and y along the path.
  • Understanding of Newton's law of universal gravitation
  • Basic algebra for solving equations
  • Familiarity with gravitational force concepts
  • Knowledge of mass and distance relationships in gravitational fields
  • Study the law of universal gravitation in detail
  • Learn how to manipulate algebraic equations to solve for unknowns
  • Explore gravitational force calculations between two celestial bodies
  • Investigate the concept of gravitational equilibrium points
Students studying physics, educators teaching gravitational concepts, and anyone interested in celestial mechanics and gravitational interactions.
XylophoneDealer
Can anyone help me with this question?
[/B]
"Describe how the weight of an object changes as it moves from the surface of the Earth to the surface of the moon. At what point between them is the resultant gravitational force on an object zero? Where is its acceleration zero?"
(distance between Earth and moon = 3.8e8 m
Mass of Earth = 81 x mass of moon
Mass of Earth = 6e24 kg
Radius of Earth = 6.4e6 m
Gravity on Earth's surface = 9.8 m/s
Universal gravitational constant = 6.7e-11 N m^2 kg^-2)
Thanks in advance!
Welcome to PF!
You need to show your work before we can help.
Also I moved your post to the proper forum and edited it adding the homework template.
jedishrfu said:
Welcome to PF!
Thank you, but I don't understand - what do you mean by "you need to show your work"? Apologies!
It means that the 3rd section of the HH Template is for you to start working on the problem. Use the relevant equations and write out the equation for the pull of the two gravity forces on the object as a function of distance along the path from the Earth to the Moon.
Ah, sorry. I just read the Terms of Use.
Well, the only thing I can seem to be able to do is to use the formula:
Where M1 is the mass of the earth, M2 is the mass of the moon.
The only way I got that was from manipulating other formulae, and by looking at the law of gravitation.
I named the unknown point (the point at which the resultant gravitational force is zero) point P, and the distances between P and the earth/P and the moon distances x and y, respectively. I tried to use algebra in solving it but I'm at a loss. I'm not very experienced on the topic, sorry to seem stupid! It's just bugging me so much that I don't know where to go.
It looks like you've set it up right, with x+y = total distance between Earth and Moon, right? Can you maybe solve for the ratio of x/y? Knowing that ratio and the total distance, you could solve for the point P...
Ah - that would help immensely. I'll try that now. Thank you!
  • · Replies 18 ·
  • · Replies 73 ·
