-gre.al.9 absolute value domain
The discussion revolves around solving the inequality involving absolute values, specifically the expression $\quad |y+3|\le 4$. Participants explore different methods to arrive at the solution and express their opinions on the difficulty of the problem.
  • Homework-related
  • One participant suggests that the problem could be solved by observation, although they acknowledge this approach may be risky.
  • Another participant states that the distance between $y$ and $-3$ is at most $4$, leading to the conclusion that $y$ is between $-7$ and $1$.
  • A participant provides a step-by-step equivalence transformation of the inequality, concluding with $-7\le y \le 1$.
  • There is a request for feedback on the difficulty of the problem, with one participant rating it as easy.
  • Several participants agree that the problem is easy if one understands the property of absolute values, specifically the implication $|x| \le a \implies -a \le x \le a$ for $a \ge 0$.
Participants generally agree on the solution to the inequality, with multiple confirmations of the range $-7 \le y \le 1$. However, there is no explicit consensus on the overall difficulty of the problem, as participants express varying opinions.
Some participants reference the property of absolute values without detailing the assumptions or conditions under which it applies. There is also a lack of discussion regarding any potential edge cases or alternative methods for solving the inequality.
karush
MHB
Solve for y: $\quad |y+3|\le 4$
a.$\quad y \le 1$
b.$\quad y\ge 7$
c.$\quad -7\le y\le1$
d. $\quad -1\le y\le7$
e. $\quad -7\ge y \ge 1$
Ok I think this could be solved by observation but is risky to do so...
since y can be either plus or minus y would be between 2 -7\ge y \le 1 thus a and b are not answers
\begin{array}{l|l}
(y+3)=4&-(y+3)=4\\
y=4-3&-y=4+3\\
y=1&y=-7
\end{array}
thus
$-7\le y \le 1$
which is c.
[sp]
The distance between $y$ and $-3$ is at most $4$. That means $y$ is between $-3-4=-7$ and $-3+4=1$.
[/sp]
$|y+ 3|\le 4$ is equivalent to $-4\le y+ 3\le 4$. Subtracting 4 from each part:
$-7\le y \le 1$.
well that's a lot quicker
mahalo btw how would you rate this problem easy, medium, hard
easy, if you know $|x| \le a \implies -a \le x \le a$ for $a \ge 0$
$-7\le y \le 1$.
mahalo
Mahalo
