Greatest possible value of a constant in polynomial
  • Thread starter Thread starter songoku
The discussion revolves around finding the greatest possible value of a constant \( b \) in the polynomial \( 27x^{18} + bx^9 + 70 \), given that \( px^9 + q \) is a factor. Participants explore the implications of the Factor Theorem and the relationships between the coefficients \( p \), \( q \), and \( b \).
  • Some participants attempt to express \( b \) in terms of \( p \) and \( q \) and question whether there is a maximum value for \( b \). Others explore the conditions under which the polynomial has real roots and the implications of \( p \) and \( q \) being natural numbers. There are discussions about the behavior of \( b \) as a function of the ratio \( q/p \) and the significance of quadratic equations derived from the problem.
The discussion is ongoing, with various interpretations being explored. Some participants suggest that there may not be a maximum value for \( b \) under certain conditions, while others propose specific values for \( p \) and \( q \) to test for integer solutions. There is a recognition of local maxima and minima in the context of the problem.
Participants are considering the implications of the coefficients being natural numbers and the constraints that arise from the polynomial's structure. There is also mention of the need for \( q \) to divide 70 for \( b \) to remain an integer, which adds a layer of complexity to the problem.
songoku
A factor of ##27x^18+bx^9+70## is ##px^9+q##. What is the greatest possible value of ##b##?
Factor Theorem
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots.
Let ##f(x)=27x^{18}+bx^9+70##, then:
$$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$
$$b=27 \frac{q}{p}+70 \frac{p}{q}$$
$$b=\frac{27q^2+70p^2}{pq}$$
From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##.
How to find the greatest value of ##b##?
Thanks
Are ##b##, ##p##, ##q## natural numbers?
Must the quotient polynomial have natural coefficients?
If so, you have a one parameter family of quadratic equations ##~27y^2+Zy+70=0~## . What are the values of ##Z## (real number) for which there is only one solution?
The answer suggests an upper bound for ##b## .
Edit: rephrased reply.
Try to express b as a function f(y) where y=q/p and f(y)=27y+70(1/y). We can speak about the greatest value of b for q/p<0. If q/p>0, then we can speak about the smallest value of b.
I have posted the full question so I don't know about this
Sorry but why should we consider the case where the quadratic must have one solution?
Using differentiation, I can get the stationary point but I still don't see what the max value of ##b## since the greatest value of ##b## for ##\frac{q}{p}<0## is still less than min. value of ##b## for ##\frac{q}{p}>0##
Thanks
You are right.
There are the local maximum and the local minimum. In my opinion, the question only holds for q/p<0.
songoku said:
Homework Statement: A factor of ##27x^18+bx^9+70## is ##px^9+q##. What is the greatest possible value of ##b##?
Relevant Equations: Factor Theorem
Thanks
This question makes no sense to me. If ##p, q## are fixed, then that determines ##b##. There is no question of maximising ##b## in this case.
And, if we allow any ##p, q##, then all that says is that we have at least one real root. That means that ##b^2 > 4ac## and there is no maximum for ##b##. It can be as large as you like, and the polynomial will have real roots.
If ##b > 0##, then there is a minimum of ##b = 2\sqrt{ac}##, below which the polynomial has no real roots.
You are right. Given the problem as stated, there is no maximum value for ##b##.
Thank you very much for the explanation JimWhoKnew, Gavran, PeroK, FactChecker
Thanks
27x^{18}+bx^9+70=(px^9+q)\cdot \sum_{n=0}^9 a_nx^n=\sum_{n=9}^{18} pa_{n-9}x^{n}+\sum_{n=0}^9 qa_nx^n
and therefore ##70=qa_0\, , \,27=pa_9\, , \,b=pa_0+qa_9.## There are only finitely many integer solutions for ##(p,q,a_0,a_9)## which can be tested easily.
Divisibility considerations only make sense over rings, not fields. Otherwise, we could as well complain about the fact that the polynomials weren't explicitly ruled out to be rational functions, which would allow any division.
Alternatively, for integers ##p, q, b##, wlog take ##p = 1##, with ##b = 27q + 70/q##.
For ##b## to be an integer, ##q## must divide 70. A quick look at the equation shows that ##q = 70## must give the largest value of ##b##, namely 1891.
Why can we take ##p## to be 1?
Because only the ratio ##q/p## determines ##b##.
If b, p and q are integers then from the post #9 we have:
70=qa0 ⇒ q∈{1,2,5,7,10,14,35,70}
27=pa9 ⇒ p∈{1,3,9,27}.
1/27 is the smallest value of q/p and 70/1 is the biggest value of q/p among all possible values of q/p.
The function f(y)=27y+70(1/y) from the post #3 strictly increases for y>√(70)/√(27) and strictly decreases for 0<y<√(70)/√(27). 70/1>√(70)/√(27) and 1/27<√(70)/√(27), so the pair q=1 and p=27 gives the largest value of b which is 1891 and the pair q=70 and p=1 also gives the largest value of b which is 1891.
Thank you very much for the explanation fresh_42, PeroK, Gavran
  • · Replies 20 ·
