Grocery Cart Forces: Final Speed
6 replies · 6K views · last reply
mortho
A 105.0 N grocery cart is pushed 11.0 m along an aisle by a shopper who exerts a constant horizontal force of 40.0 N. If all frictional forces are neglected and the cart starts from rest, what is the grocery cart's final speed?
Wnet=deltaKE
So i used that equation which ended up to mad=1/2mv2
(10.7)(9.81)(11)=1/2(10.7)(v2)
v= 14.7 m/s
But it ended up being wrong, i don't get it. and also i could cancel out the masses right? but it would still give me same answer so it wouldn't matter. Thanks for your help!
The work done in moving the cart 11m is converted into k.e.
so that [itex]Fd=\frac{1}{2}mv^2[/itex]
so F is the constant force exerted to move the cart 11m(d) and m is its mass(105/9.81) and re-arrange to find v^2
In F*d, F refers to the Horizontal force (Fa) aka 40N. Now for 1/2*mv^2, you use the M of the cart (10.7)
oh? my teacher was saying use force parallel, oohhh..but i guess that would be the same as Force applied. ok so i worked it out as (40)(11)=1/2(10.7)v2
my answer is 9.07 m/s correct?
Right, in Work problems, you consider the part of the force that's acting parallel to the distance it's acting on, in this case that force is 40 N. 9.07 looks right
THANK YOU! hey could you help me out with a skier problem ,,,it's on the bulletin,,i think it's called skier coefficient or velocity..that one's soo hard and it's almost due .
