Group Index dependence on refractive index
loginorsinup
In Ng (the group index for a range of wavelengths), there is an index of refraction n used, but if the medium is dispersive, meaning n is a function of wavelength λ, which n is used? Is it some kind of an average? Or does n not change much over this range of wavelengths? if it doesn't change much, then
Ng = n - λ(dn/dλ)
would be approximately
Ng ~ n
So, it makes sense to me that dn/dλ must not be really small, because otherwise Ng ~ n and the concept of group index is redundant with the concept of the index of refraction. but if dn/dλ is not really small, then the choice of n (the first term in Ng) becomes crucial, does it not?
https://ssl.gstatic.com/ui/v1/icons/mail/images/cleardot.gif
##N_g## is a function of ##\lambda## too: ##N_g(\lambda)##, so you should use the respective value ##n(\lambda)## in the formulas you gave.
Take in mind that the group index refers to a wavepacket which is very broad, so that the spread of ##\lambda## in Fourier space is arbitrary small. If n depends strongly on ##\lambda##, the wavepacket will deform while traveling through the medium and it will be difficult to define a group velocity, or, you have to regard it as a superposition of broader wavepackets which travel with slightly different group velocities.
