Guide to Cutting Long Equations in Latex for Optimal Formatting
  • Context: LaTeX
  • Thread starter Thread starter ladil123
    Cut Latex
The discussion revolves around formatting long equations in LaTeX, specifically how to break them across multiple lines while maintaining proper syntax and alignment. Participants explore various methods and address common issues encountered when using commands like \left and \right.
  • One participant seeks advice on how to break a long equation in LaTeX so that it continues on the next line.
  • Another participant suggests using the split environment for better formatting of long equations.
  • There is a mention that the eqnarray environment is no longer recommended due to spacing issues.
  • A participant raises a follow-up question regarding the use of \left and \right commands when breaking equations across lines, noting that it leads to errors.
  • Another participant asks for clarification on the issue with \left and \right commands and suggests using dummy constructs \left. and \right. to resolve the problem.
Participants express differing preferences for methods of breaking long equations, with some advocating for the split environment while others highlight the limitations of certain commands. The discussion remains unresolved regarding the best approach to handle \left and \right commands across multiple lines.
Participants mention specific LaTeX commands and environments, but there are unresolved issues related to the proper use of \left and \right commands in multi-line equations, as well as potential errors that arise from their misuse.
ladil123
Hello!
I got a very long equation that I´m writing in Latex, it is so long that the equation reference can´t fit on the same line.
How do I write to cut the equation so it continues on the next line?
Thanks
Use http://www-h.eng.cam.ac.uk/help/tpl/textprocessing/teTeX/latex/latex2e-html/ltx-223.html .
http://www.ams.org/tex/amslatex.html" for more information.
Like lars, I prefer to use the split environment. Using it, it looks something like this
Code:
\begin{equation}
\label{whateverequation}
\begin{split}
x &= start of long equation \\
& second half of long equation
\end{split}
\end{equation}
The two backslashes indicate the end of the line, and the ampersands on each line are aligned underneath each other.
The use of eqnarray is no longer suggested, since the spacing leaves much to be desired. as las3rjock noted, there are much better options available.
One more note: this link is a little dated, but the advice found there is good.
http://www.math.uiuc.edu/~hildebr/tex/displays.html
Thanks for the help!
I got a follow up question..
If I have "\left(" command on the first line of the equation and the closing "\right)" command on the second line it won't work!
Any tips on how to make it work?
Could you be more precise in what won't work?
If you have a one line equation that you break at some point, why do you use \left( instead of just (?
I only use the \left( when I have multi line math environment, like a matrix.
Cheers
Ok,
My equation has one breaking point. At the first line i got the "\left[" command
and then that line is cut off with \\
Then on the second line I got "\right]".
Then when I should quick build my pdf file I get an error message:
"Missing \right inserted"
below is my input
\begin{align}
w_{h}^{''}(x) & =2 \lambda^{2} \left[ cosh \lambda x (E cos \\
\lambda x - D sin \lambda x ) + sinh \lambda x (B cos \lambda x - A sin \lambda x )\right] \label{winkler_homo8910} \\
\end{align}
I hope I made it more clear ?
There was JUST a post that addressed this. Basically each individual line in latex needs both a left and a right. In order to resolve this with multi-line equations, you use the dummy \left. and \right. constructs. Basically these act as ghost braces to end the current one.
Example:
Code:
\begin{equation}
\label
\begin{split}
x =& \left[ the start of the equation \right. \\
\left. &second half of the equation \right]
\end{split}
\end{equation}
14K
9K
