Exploring the Mass and Temperature of a Slower Photon: Half the Speed of Light
  • Context: Graduate
  • Thread starter Thread starter golith
    Light
The discussion centers on the theoretical implications of slowing down a photon to half the speed of light (149,896,229 m/s) and its associated mass and temperature. Participants argue that photons possess no mass at light speed and that slowing them down would not result in mass gain but rather a change in energy state, potentially altering their frequency and color. The conversation also touches on the role of physical constants, such as epsilon-0 and mu-0, in affecting the propagation speed of light, emphasizing that light's inherent mass remains zero regardless of speed alterations.
  • Understanding of photon behavior and properties
  • Familiarity with the principles of energy conservation
  • Knowledge of physical constants, specifically epsilon-0 and mu-0
  • Basic concepts of wave-particle duality in quantum mechanics
  • Research the implications of changing epsilon-0 and mu-0 on light propagation
  • Explore the concept of wave-particle duality in greater detail
  • Investigate experimental methods for measuring photon energy and frequency
  • Study the effects of different materials on photon behavior, such as crystals that split photons
Physicists, students of quantum mechanics, and anyone interested in the fundamental properties of light and its behavior under varying conditions.
golith
Hi,
If you were to slow down the speed of light (299,792,458 m/s)
to half then what is the mass of a photon of light?, this is using the premis a photon has no mass at the speed of light, or it is losing mass as it approaches the speed of light. Therefor a photon must assume mass as it slows down.
P.s what would its relative temperature be at 1/2 of C.
Thanx
Problem is in trying to find a way, even in a thought experiment to
1) put the brakes on a photon and slow it down OR
2) find a ‘slow photon’ to speed up to light speed
It be nice to find a slow one actually measure its mass then watch it lose mass to zero as we ‘allow’ it or force it up to light speed.
But like a Teenage kid in a hotrod, light doesn’t know the meaning of slow, so you aren’t going to find one at anything but full speed.
How about slowing one down:
We can find a crystal that will take a single photon and split into two. Due to conservation of energy both can only have a MAX of 1/2 of the original energy! That should translate to half the speed. But this is the deal; if you start with BLUE light and split a photon in two new photons. They would indeed have half the energy needed to be able to go at full speed. However they are so insistent on top speed you will find they just change color, frequency, and wavelength to RED. And by measurement we know that each red photon has half the energy of the blue. The energy needed for red to keep going at the speed of C. Note the original mass is also cut in half. You already had that a zero right.
When you say "slow down the speed of light", I'm not sure what you mean. If I were saying it, I would assume that I was changing either epsilon-0 (the permitivity of free space), or mu-0 (the permeability of free space) somehow. Note that these two changes are not equivalent, though they both would slow down the propagation of light, so I would specify which one.
In any case, if you cange the speed of light in the sense I'm talking about, light still travels at the speed of light, and it still has no mass, it's simply that that speed at which light travels is slower because of the difference in physical constants.
I really can't make any sense out of what you are trying to do at all.
to revive this old thread. i see what your attempting to say, though it does not seem to have a a great deal of rationality about it- if you were to measure the mass of light with an instrument that would have the same means of movement (essentialy the same thing as having a stopped photon) the mass would again still be zero, i do not se any possible way that the "slowing down" of a photon could increase its mass rather the change of this enegry to a more "particle like" form would do this job, this could be better defined when describing your (slowing down) change more exactly.
-i hope this was of some help, and you are still keeping tabs on this thread
  • · Replies 25 ·
  • · Replies 25 ·
  • · Replies 53 ·
  • · Replies 130 ·
15K
  • · Replies 26 ·
