Reaching the Speed of Light: A Thought Experiment on Halving Distance Traveled
  • Context: High School
  • Thread starter Thread starter ShaunM
    Distance traveled
The discussion revolves around a thought experiment involving an object traveling between two points, A and B, where it only covers half the remaining distance at each step. This raises questions about motion, speed, and the implications of Zeno's paradox, particularly in relation to whether the object can ever reach point B and the nature of time and space.
  • One participant describes a scenario where an object travels half the remaining distance to point B, suggesting it will never reach B, leading to a perception of slowing down.
  • Another participant identifies this as Zeno's paradox and argues that time must be considered, implying that the object does reach B despite the paradoxical reasoning.
  • There is a discussion about whether the object's speed is constant, speeding up, or slowing down, with one participant expressing confusion over how to determine the object's behavior.
  • A participant asserts that physics is empirical and emphasizes the importance of observing motion, suggesting that questioning motion itself may hinder understanding physics.
  • Another participant challenges the validity of Zeno's paradox in modern physics, stating it is not applicable to classical physics where motion is observable and time passes.
  • One participant expresses uncertainty about the implications of Zeno's paradox and whether it suggests that time does not exist or stops.
  • There is a suggestion that the discussion should focus on the assumptions made about motion and the nature of the distance to point B.
Participants express differing views on the implications of Zeno's paradox, the nature of motion, and the role of time in the thought experiment. There is no consensus on the interpretation of the paradox or the behavior of the object in question.
Participants highlight the need for clarity regarding the assumptions about motion and the distance to point B. The discussion reflects varying interpretations of Zeno's paradox and its relevance to contemporary physics.
ShaunM
Hello
Ive have a problem with this simple question and hope someone (probably a lot of you) can help.
An object is traveling in a straight line between point A and point B. It always only goes half the remaining distance and so it will always be moving forward towards B but would never reach it. It would in effect be slowing down. If however its speed is increased with every half length traveled so the speed at which it is actually traveling is constant then it would eventually reach the speed of light, its overall speed however wouldn't be and it still would never reach point B.
Can someone help me see what I am missing here please.
ShaunM said:
Hello
This is Zeno's paradox. You and Zeno are missing the passage of time. While you are endlessly decomposing the motion, time has passed and the object has long since reached B.
Decide whether it's speeding up, slowing down, or staying at constant speed. You can't hope to solve a problem when your self-contradiction means that you are describing two or three different problems as if they were one.
Thanks for the reply Ibix.
I can't however see how I can 'decide' what's going on (or can I?) and that's precisely the problem I have. What is the object actually doing? Speeding up, slowing down, is its speed constant and why doesn't it seem to reach point B?
If you stand up and walk steadily across the room, you get to the other side. Yes?
What's the issue?
Thanks PeroK
Thats really interesting and having just read a few things quickly it does seem to be exactly that.
The question is then actually whether or not our reality (Im not sure if that's the correct term, maybe 'space time'?) is discrete or not?
What's the issue?
Im not sure and that's bothering me, hence my post:)
Zeno's paradox won't help you with that. Going back to ancient wisdom is no use to modern physics.
The way to decide whether spacetime is discrete is a testable theory of quantum gravity.
You can't decide by pure thought inside a Greek ivory tower.
Physics is an empirical science. If you're not sure motion is possible then you are not in any position to study physics.
The starting point for physics is that we observe motion and need a theory to explain it. Newton and Leibnitz invented calculus for this. Zeno didn't.
You're not a philosopher, I hope?
I'm me and I'm here with a question. What I'm not sure about is whether you are giving me answer or simply telling me my question is stupid.
Thanks either way for your time.
The answer is that motion is possible. I do consider Zeno's paradox to be particularly unparadoxical. I never understood the point of it.
An object traveling at ##5m/s## travels ##5m## in ##1s##. The only way to deny that is to claim that ##1s## never passes. Which is more or less what Zeno did.
Thanks. So Zeno's paradox suggests time doesn't exist or stops in some cases?
Have you done a search on Zeno's paradox?
No. Zeno's paradox is completely and utterly wrong. You can read up about it online.
Certainly in terms of classical physics, which is where you posted your question, it is wrong.
Time passes, things move, particles collide. That's classical physics.
I had never heard of it until about 2 hours ago so any searches I have done have been very superficial. I had a problem trying to work out what was happening in the situation contained in my original post and thought this would be a place where someone could help:)
What's not clear in post #11? Object moving at constant velocity of ##5m/s##.
It travels ##5m## in ##1s##, ##10m## in ##2s## etc.
Give me any distance and I'll tell you how long it takes to cover that distance.
It doesn't have to speed up or slow down or jump about.
What's unclear about that?
Now that you know what to look for, you should find plenty, even on this forum.
I had a look at the Wikipedia page on this and I see I've been playing the role of Diogenes the cynic.
I like his style!
I don't know if in my situation there is a set distance being travelled. I assumed point B would never be reached.
Then you are assuming the conclusion.
There are lots of ways not to reach B. What are you assuming about the motion?
Im assuming that if an object only ever travels half the way between its current position and another point in space in which direction it is traveling that it doesn't matter how quickly it travels it would never reach said point in space. I am starting to think that I need to have a think about what 'travelling' means maybe. Is the halfway point the actual destination each time for instance.
Why call it halfway point then?
No, the point is to help you learn to think. Rather than spoon-feed answers, we try to help people see how to work them out for themselves. That's what people in this thread have been doing.
EDIT: also, just FYI, it's "halving", not "halfing"
Zeno's paradox begins by assuming our commonly accepted notion of continuous distance. In particular, that given any two distinct points on a line, there is at least one point between them. It uses this to demonstrate that there must be at least one unending sequence of points within any non-empty line segment, each point being farther along than the last.
If the traversal of a point is thought of as an "action", one is invited to believe that we can only perform a finite number of "actions" in any finite extent of time. But I've never seen any logic extended to demonstrate that premise. It seems obviously false.
Alternately, one might be invited to believe that for any ordered set of actions, there must be a "last action" in the set. However, this is false.
Thanks and yes, I see my thinking was flawed, as was my spelling. I thought that word looked odd.
Indeed.
As you approach the destination you will eventually get close enough that, as the Heisenberg Uncertainty Principle describes, you will not be able to state both the speed and the position with enough precision to be able to continue halving the distance.
Zeno had several paradoxes, all intended to refute the atomist philosophy. Some are resolved using calculus, but the resolution of this particular one requires quantum mechanics.
  • Skeptical
It might help you to learn about infinite series. Mainly that the sum of infinitely many non-zero positive numbers can still be finite. For example:
1/2 + 1/4 + 1/8 + ... = 1
If you move 1m at 1m/s you have these steps:
1/2m + 1/4m + 1/8m + ... = 1m
Which take these times:
1/2s + 1/4s + 1/8s + ... = 1s
So the total time is still 1s.
You are seriously overthinking the problem. It does NOT require QM.
@ShaunM I would strongly recommend going over this post multiple times until you understand it completely. This post completely resolves Zeno’s paradox, and it does so on Zeno’s own terms without avoiding the issue raised by Zeno.
  • · Replies 93 ·
  • · Replies 22 ·
  • · Replies 29 ·
