Hamiltonians, do they need to be positive definite?
  • Context: Graduate
  • Thread starter Thread starter mtak0114
    Positive
Hamiltonians do not need to be positive definite; they can have negative eigenvalues, as demonstrated by the ground state energy of the Hydrogen atom at approximately -13.6 eV. While it is common to require Hamiltonians to be bounded from below to ensure the existence of a ground state, this is a physical requirement rather than a strict mathematical constraint. A Hamiltonian can be adjusted by adding a constant to shift the lowest energy state to zero, making it appear positive definite. In the context of supersymmetry, energy is always positive, but this does not apply universally across all Hamiltonians.
  • Understanding of quantum mechanics and Hamiltonian operators
  • Familiarity with eigenvalues and eigenstates in quantum systems
  • Knowledge of the physical implications of boundedness in Hamiltonians
  • Basic concepts of supersymmetry in quantum physics
  • Research the implications of negative eigenvalues in quantum mechanics
  • Learn about the concept of boundedness in Hamiltonians and its physical significance
  • Explore the role of supersymmetry in quantum field theory
  • Investigate the mathematical properties of Hamiltonians with unbounded potentials
Physicists, quantum mechanics students, and researchers interested in the properties of Hamiltonians and their implications in quantum theory.
mtak0114
Hi
(I'm not sure where this question belongs)
I had a general question about hamiltonians, do they need to be positive definite?
is this required in QM, or is this a relativistic requirement?
cheers
M
Hamiltonians do not need to be positive definite. The eigenvalues of the Hamiltonian are the energies. In standard notation, the energy of the ground state of the Hydrogen atom is about -13.6 eV, i.e. negative => one example of a negative eigenvalue => my statement.
I'm not completely sure that I understood your question, hence the explanation.
Timo is correct. However, you typically demand that a Hamiltonian is bounded from below. Otherwise there is no ground state.
Once you have a such a Hamiltonian, you could just trivially add a constant to the Hamiltonian (which doesn't change the physics) such that the lowest energy state (the ground state) has zero energy. It's often the convention to label a state that is not the ground state as zero energy (such as for the mentioned hydrogen atom). However, these Hamiltonians can always be chosen to be positive definite by a constant energy shift. This is why you may have seen some sort of general argument for something that assumes a positive definite Hamiltonian (assuming this is why you asked the question).
This might be a little irrelevant, but I want to mention that if one requires supersymmetry then it is true that the energy will always be positive.
thanks for the replies
this agrees with what I was thinking
but from a relativistic perspective this
wouldn't the hamiltonian need to be positive definite
as the 4-momentum operator must have time like eigenvalues?
i.e. timelike four-momenta
as another question
what is the reason for a hamiltonian to be bounded from below?
I understand that this is required if one would like to avoid having an infinite energy source.
But is there a precise mathematical reason or is this simply a constraint that we as physicists impose?
thanks again
Mark
mtak0114 said:
as another question
thanks again
Mark
I don't think that there are any mathematical constraint that restricts the Hamiltonian to be bounded from below, this is a physical requirement. Take for example a potential of the form V(x) = x^3, then the Hamiltonian will not be bounded from below (and there is no mathematical reason for this not to be allowed)! I think that when this is solved, the particle will go to infinity in finite time, and therefore not so physical.
  • · Replies 0 ·
  • · Replies 59 ·
