Harry Wertmuller's Doubt on Windmill Energy Proportionality
  • Context: High School
  • Thread starter Thread starter HarryWertM
    Energy Windmill
The discussion clarifies that the energy extracted from wind is proportional to the cube of the wind velocity, contrary to the common misconception that it is proportional to the square. This principle is derived from the fan laws, where horsepower (HP) varies with the cube of the RPM, and the kinetic energy of air is calculated using its mass and velocity. The Betz limit, which states that no wind turbine can capture more than 59% of the kinetic energy in wind, is also highlighted, with actual windmills achieving around 40-45% efficiency on average.
  • Understanding of basic physics concepts, particularly kinetic energy.
  • Familiarity with fan laws and their implications in energy extraction.
  • Knowledge of the Betz limit and its significance in wind energy.
  • Basic comprehension of wind velocity distribution, specifically the Rayleigh distribution.
  • Research the implications of the Betz limit on wind turbine design and efficiency.
  • Explore the fan laws in detail and their applications in various engineering fields.
  • Learn about the Rayleigh distribution and its impact on wind energy generation.
  • Investigate advanced wind turbine technologies that aim to exceed traditional efficiency limits.
Engineers, renewable energy researchers, and students studying wind energy systems will benefit from this discussion, particularly those focused on optimizing wind turbine performance and understanding energy extraction principles.
HarryWertM
Reading about renewable energy on the Internet a short time ago, I came across the statement that "energy is proportional to the cube of the velocity".
Huh? I thought energy was proportional to the _square_ of the velocity. After all, we're not talking relativity here.
-Harry Wertmuller
HarryWertM said:
Reading about renewable energy on the Internet …
Hi Harry! :smile:
Where on the internet?
I googled "energy is proportional to the cube of the velocity", but only got two hits, neither of them relevant. :confused:
Maybe it's just an error ! :)
It's true. The reason is that an increase in velocity also involves and increase in pressure. Here are the fan laws: http://www.delhi-industries.com/Engineering/Tips/FanLaws.asp
1 CFM varies Directly with RPM (CFM 1 / CFM 2 = RPM 1 / RPM 2)
2 SP varies with the SQUARE of the RPM (SP 1 / SP 2) = (RPM 1 / RPM 2)2
3 HP varies with the CUBE of the RPM (HP 1 / HP 2 = (RPM 1 / RPM 2)3
You need to substitute the first equation into the third...
Learned the same law in my Alternative Energy class at community college. It's true alright, and it's one of the factors that made our instalation of the school's windmill a lot easier. You see, as input (wind) increases by x, otuput increases by x3, and resistance (load) increases proportionally with output. So, as windspeed goes up, the blades' resistance to acceleration goes up exponentially, which keeps the blades from spinning too fast and ripping themselves apart.
Aerodynamic drag and lift forces vary with the square of the speed (assuming sub mach air speeds here). Since power = force x speed, then power varies with the cube of the speed (speed^2 for force component x speed).
-Harry Wertmuller
Here is how I think of this surprising, but true, fact:
1. The energy per molecule (or mole, or gram, or whatever) of air is proportional to the square of the air velocity.
2. The number of air molecules per unit time, that pass through the windmill blades, is proportional to the air velocity.
Multiply the quantities in these two statements and we find:
The power (i.e. energy per unit time) in the air passing through the windmill is proportional to the cube of the air velocity.
-Harry Wertmuller
the column of air in 1 second= v
the volume of air= va (a= cross area)
the mass of air=vad (d=density)
the kinetic energy= 1/2 m v v
=1/2 vad v v(vad=m)
= 1/2 ad (v v v)
hope you got the answer
It is not theoretically possible to remove all the energy from wind, because the air has to go someplace after passing through the windmill. This limit is called the Betz limit, ~59%. Actual windmills achieve ~40 to 45% maximum. Furthermore, because the wind velocity distribution is approximated by the Rayleigh distribution
http://en.wikipedia.org/wiki/Rayleigh_distribution
windmills on average operate at only ~35% of their maximum design power. So a 1.5 MW windmill on average produces only about 500 kW.
Bob S.
  • · Replies 60 ·
  • · Replies 35 ·
11K
  • · Replies 17 ·
