Heat Capacitance Homework: Compute Work & Internal Energy Increase
  • Thread starter Thread starter v_pino
    Capacitance Heat
The discussion focuses on calculating the work done and the increase in internal energy when boiling water at 2 atm pressure. The work done during the phase change from water to steam is computed using the formula W = p(V2 - V1), resulting in 164.6 kJ. The increase in internal energy is derived from the first law of thermodynamics, yielding a total change of 2035 kJ after accounting for the heat of vaporization of 2200 kJ/kg and the work done. Key equations include the ideal gas law and the first law of thermodynamics.
  • Understanding of the first law of thermodynamics
  • Familiarity with the ideal gas law (pV = nRT)
  • Knowledge of heat of vaporization concepts
  • Basic calculus for integration in thermodynamic equations
  • Study the ideal gas law and its applications in thermodynamics
  • Learn about heat capacitance and its role in phase changes
  • Explore the first law of thermodynamics in greater detail
  • Investigate the calculations for work done in isobaric processes
Students in thermodynamics, physics enthusiasts, and anyone involved in engineering or physical sciences who seeks to understand the principles of heat transfer and energy calculations during phase changes.
v_pino
When water is boilded under a pressure of 2 atm, the heat of vaporization is 2.2 x 10^6 J/kg and the boiling point is 120 degree C. At this pressure, 1 kg of water has a volume of 10^-3 cubic meter and 1 kg of steam has a volume of 0.824 cubic meter.
a.) Compute the work done when 1 kg of steam is formed at this temperature.
b.) Compute the increase in the internal energy of the water.
boiling point = 393 K
number of moles = 1000 / 18.0
first law of thermo: change in internal energy = energy input - work done by system
a.) W = p(V2-V1) since it is isobaric
= 2x10^5 (0.824 - 10^-3)
= 1.646 x 10^5 J (work done by water)
(Is this correct?)
b.) pV = nRT
2x10^5x10^-3 = (1000/18.0) x 8.31 x T
T = 0.43 K
therefore: change in T = 393 - 0.43
= 392.57 K
(Don't I need to know the heat capacitance to work out the heat used to increase the temperature of the water to the boiling point? If I find this, then I can simply add this to the heat of vaporization to get the total heat input. Then, from first law of thermodynamics, I can find the change in internal energy.)
W_{b}= \int Pdv
where pressure is constant and dv is the change in volume. The volume goes from .01m^3 to .824m^3.
This will give you the work done BY the system if it was in a piston cylinder device.
To computer the work required to vaporize 1kg of water, simply multiply the the heat of vaporization by the amount of water.
2.2e6 kJ/kg * 1kg = 2200 kJ
Using your own formula for the first law of thermo:
\Delta h = 2200 kJ - 164.6 kJ = 2035 kJ
14K
  • · Replies 131 ·
10K
  • · Replies 18 ·
