Heisenberg's uncertainty principle and photons
The discussion revolves around the Heisenberg uncertainty principle in the context of photons, particularly as it relates to the double slit experiment and the implications of measuring a photon's position and momentum. Participants explore concepts of mass, speed, and momentum of photons, as well as the nature of uncertainty in quantum mechanics.
  • One participant questions whether knowing the slit through which a photon passes implies that its momentum must be unknown, suggesting a connection to the uncertainty principle.
  • Another participant clarifies that a photon's momentum is related to its wavelength, not its speed, which is always the speed of light in a vacuum.
  • A different participant points out that the uncertainty discussed is not about speed but rather about the direction of travel.
  • Some participants discuss the concept of "rest mass" in relation to photons, with conflicting views on its applicability and relevance to the discussion of momentum and energy.
  • One participant argues against the use of "rest mass" for photons, stating that it is a misleading concept and that photons do not have an inertial reference frame where they can be at rest.
Participants express differing views on the concepts of mass and momentum in relation to photons, particularly regarding the use of "rest mass." There is no consensus on the implications of these concepts for the uncertainty principle or the nature of photons.
There are unresolved issues regarding the definitions of mass and momentum as they apply to massless particles like photons, as well as the implications of these definitions for the uncertainty principle.
Comscistudent
Hi everyone,
Apologies if this is common knowledge or a silly question, I'm just coming back to physics and I've been looking through the double slit experiments ( both double slit and delayed choice quantum eraser ) and it got me thinking about the uncertainty principle.
With a photon of light in either version if we know through which slit the photon passes does that not mean that the momentum at that point must be unknown?
Since a photon is a massless particle ( I think ) that implies that the speed of the photon must not be exactly C. Since C is the absolute limit the photon at that point must have the ability to be moving slower than C. Is that even possible? The opposite is also true, that the mass could have changed but if the photon has mass it again cannot be traveling at C.
I assume I've missed something basic here so please correct me.
That helps a lot thanks!
It's not an uncertainty in the speed, but an uncertainty in the direction of travel.
Comscistudent said:
Hi everyone,
_____________________
Although photon "particles" do not have a mass, they do have what's called a "rest mass"- that means if you take the energy of a photon and translate it to what it WOULD be if it had mass, you would come up with a number (remember Einsteins equation relating mass and energy). This number actually does have "mass-like", effects, because photons actually have a momentum which you can then calculate through the famous p=mv equation. If you shoot out enough photons in one direction, you could even accelerate a rocket into space or knock a person down. Granted, it would take a lot of photons to do that, but theoretically it would be possible.
Sophrosyne said:
Although photons do not have a mass, they do have what's called a "rest mass"- that means if you take the energy of a photon and translate it to what it WOULD be if it had mass, you would come up with a number (remember Einsteins equation relating mass and energy).
Photons are massless. And the concept of "rest mass," which applied to massive particles, is no longer employed (you will find many threads on the subject on PF).
"Rest mass" is very ridiculous for photons. Even if you use a (totally wrong) picture of a classical massless particle (which in fact doesn't exist in nature) it's very clear that there is no inertial reference frame, where it can be at rest. That's why the idea of a "relativistic mass" is abandoned in the modern treatment (if you call a paper of 1907 "modern"), and you only use invariant mass (a Lorentz scalar) as a concept to describe mass. What has been called "relativistic mass" is just relativistic energy (divided by ##c^2##) which is the temporal component of the Minkowski energy-momentum four-vector.
  • · Replies 22 ·
  • · Replies 36 ·
9K
  • · Replies 24 ·
  • · Replies 18 ·
