LloydSm01
- How did you find PF?
- Just searching the internet.
Dispersion of Space: A Volumetric Density Gradient as an Alternative to Spacetime Curvature
Author: Lloyd Small
Abstract
General Relativity describes gravity as the curvature of spacetime caused by mass and energy. This paper proposes an alternative framework in which gravity arises from the volumetric dispersion of space itself. Rather than spacetime bending like a two-dimensional membrane, mass is proposed to actively disperse or dilute the underlying density of space in three dimensions, creating a radial density gradient. This model aims to reproduce observed gravitational phenomena including light deflection, time dilation, and orbital mechanics through varying space density rather than geometric curvature.
Introduction
Since its publication in 1915, Einstein’s General Theory of Relativity has been remarkably successful in explaining gravitational phenomena. However, the geometric interpretation of gravity as curvature of a four-dimensional spacetime manifold remains conceptually abstract and difficult to visualize in three physical dimensions.
The proposed "Dispersion of Space" model suggests that what we perceive as gravity is not the result of curved spacetime geometry, but rather the consequence of mass dispersing the density of space in a three-dimensional volume. In this view, space possesses an inherent density that becomes progressively diluted in the vicinity of massive objects, creating a natural gradient that influences the motion of matter and the path of light.
This approach offers a more intuitive, physically tangible mechanism for gravity that may be more compatible with certain quantum interpretations of spacetime. The model maintains consistency with key observational tests of General Relativity while potentially offering new insights into unresolved issues in cosmology and quantum gravity.
The Dispersion Model
In the proposed framework, space is not an empty, dimensionless void nor a smooth geometric manifold, but rather a three-dimensional medium possessing an intrinsic density, denoted as ρ_s (space density).
When mass is present, it does not curve spacetime. Instead, it actively disperses the density of space in all three spatial dimensions. The greater the mass, the more strongly it dilutes ρ_s in its vicinity, creating a radial density gradient that decreases as one moves away from the mass.
This creates a natural "flow" of space from regions of higher density toward regions of lower density. Objects and light follow the path of steepest density descent through this volumetric gradient.
Mathematically, this can be expressed through a density potential function φ_d, where the effective gravitational acceleration emerges as the negative gradient of the space density: g = -∇φ_d.
Observational Consistency
The dispersion model reproduces several key predictions of General Relativity through density gradients rather than curvature:
Gravitational Lensing: Light traveling through regions of varying space density behaves analogously to light passing through a medium with changing refractive index, producing the same bending effects.
Gravitational Time Dilation: In regions where space density is highly dispersed, the "thinning" of space affects the rate at which physical processes occur, causing clocks to run slower.
Orbital Motion: Planets follow the natural density gradient created by the central mass, similar to a ball rolling downhill.
Key Differences and New Predictions
The model differs from General Relativity by treating gravity as an emergent effect from varying space density rather than geometric curvature. It predicts possible density saturation (potentially explaining black holes), slight variations in light speed in different density regions, and the theoretical possibility of creating artificial density gradients.
Conclusion
The Dispersion of Space model offers a conceptually simpler and more physically intuitive alternative to Einstein’s geometric interpretation.
With this theory, we can also theorize that space time and matter retracting into a black hole must create a different force to not upset the entropy of the universe. Maybe that is what we call Dark Energy.
Author: Lloyd Small
Abstract
Introduction
Conclusion
