Help finding minimum Tension that a rope can withstand without breaking
The problem involves a tightrope scenario where a person of mass M stands in the middle of a rope stretched between two buildings, with the rope sagging vertically by a height h. The objective is to find the minimum tension T that the rope must withstand without breaking, expressed in terms of h, g, M, and L.
  • Participants discuss the need for specific values such as the mass of the person and material properties of the rope. There is mention of using Hooke's law and the addition of forces to analyze the situation.
Some participants have provided guidance on considering forces acting on the person and the equilibrium condition. Others are exploring how to represent these forces mathematically and are seeking clarification on vector addition in this context.
The discussion is constrained by the absence of numerical values and specific material properties, as the problem is to be solved symbolically. Participants are also navigating differences between the problem's complexity and their prior learning experiences.
mathnoobie
A person of mass M stands in the middle of a tightrope which is fixed at the ends of two buildings separated by a horizontal distance L. The rope sags in the middle, stretching and lengthening the rope slightly.
a)If the tightrope walker wants the rope to sag vertically by no more than a height h, find the minimum tension T, that the rope must be able to withstand without breaking, in terms of h, g, M, and L.
f=ma?
Honestly, I have no idea how to approach this. I do not know a single thing to do. Please be thorough and explain to me what has to be done and what to consider. My teachers homework problems are so much different from the reading and what we discuss in class, it is unbelievably harder without guidance.
You need a value for the mass of the person, also need a value for the young module of the rope, or the material of what is made. Then, look for Hooke's law, that will give you an idea of what you need to find.
I may have posted this in the wrong section.
It's undergraduate physics.
There are no values, you solve solely on variable.
You need to know addition of forces. The man stands at the middle of the rope which is sagged a bit. His weight is balanced by the forces both pieces of the rope exert on him. Those forces act along the rope. Draw it.
ehild
I have the diagram.
I also know the forces, but I don't really know what to do with them.
force of gravity on the string
force of gravity on the person
force of person on the string
force of tension(this is the one I kind of don't understand)
How would I do this on paper and solve for those variables?
You do not show the diagram, so I show it to you. The person is standing on the string, he is in equilibrium, the resultant force on it is zero.
Gravity pulls the man downwards, and the rope keeps him up. Both strands of rope exert T force on the man (T for "tension": the rope exerts the same force along its length everywhere.) The direction of the tension is the same as that of the rope. It makes the same angle θ with the horizontal direction as the rope does.
So you have three forces exerted on the man: gravity and the two tensions. The forces are vectors, and their sum must be zero.
Do you know how to add vectors?
ehild
  • · Replies 16 ·
