Engineering Help identify traits for Engineering Vs Research
Identifying a preference for research or engineering can be guided by personality traits, with engineering often focused on understanding how things work, while research delves into why they work. The discussion highlights that research is generally viewed as more challenging due to the need for continuous learning and problem-solving intuition, whereas engineering roles can sometimes be repetitive and less intellectually stimulating. However, many argue that engineering also presents significant challenges, including user interaction and practical constraints that require creative solutions. Both fields are not mutually exclusive, and individuals can possess traits suited for both. Ultimately, personal experience in each area may be the best way to determine a preference.
koolraj09
Hi all,
I was just curious and wanted to know how to identify whether I like doing research or I like engineering. The best thing I can think of is to look what personality traits I have and compare those against required for research or engineering professions. For ex: An engineering trait might be to wonder how things work vs a research trait might be why things work?
Are there any such more questions that I can ask myself and choose between research and engineering?
Which of these might be more challenging as a long term profession - Engineering or Research?
Thanks.
Research is much more challenging. Most engineering jobs are pretty mundane where you won't be using most of what you learned. There are high tier eng jobs of course. Depends on the job market and nature of industry as well, but I see people complaining here they are actually doing a technician's job.
In research you constantly have to learn new things as new problems come op. Also, you can't brute force problems by just working harder. Sometimes you just have to have that special intuition which cannot be pinned down what it actually is. It can be very repetitive when you have to perform the same experiment over and over for weeks. Then do a completely different experiment the next months.
With engineering you should be much more invovled with the overal operations of the entire company.
Likes HuskyNamedNala
koolraj09 said:
Hi all,
Thanks.
There are engineering research jobs, so it's not like you couldn't do both. It's also not like you couldn't develop the personality traits of either one, you could want to understand the physical world in order to apply those principles to build things.
I do think this is a good question because, while they both use the same knowledge of the natural world, they can be very different in what you do on a day-to-day basis.
That's a pretty strong quote. I'm a bit doubtful you've tried "most engineering jobs." Engineering has plenty of interesting jobs and research can involve a whole lot of mundane things. That's not even mentioning the fact that many engineers do what most people would call "research."
Likes Wminus, elkement and billy_joule
This seems to be a very misguided comment in my opinion. It's not at all true to say that most engineering jobs are mundane and don't involve using what has been learned. There are very active and exciting areas in both applied engineering and engineering research. It's not true to say that research is always more exciting, as there are plenty of areas of research that are mundane and downright boring. Engineering can be and often is just as, if not more challenging than research.
"In research you constantly have to learn new things as new problems come up."
This is very true...but what does an engineer do upon encountering a problem that they might not know how to solve? They...have to learn new things to solve the problem. Engineering problems can't always be 'brute forced' either. Sometimes they have to be solved very creatively with entirely new methods.
Likes elkement and billy_joule
Research in engineering is like research, not like engineering.
I didn't say research is more exciting, let alone always. In fact, I suggested the opposite.
When you do mundane research, you are just wasting your time and you will lose funding if others realize that.
Engineering only has to be done at the level the business is operating at. The average job is like the average company in your area.
I don't think you know what engineering is.
Likes QuantumCurt
Research in engineering is like doing research...in engineering. It's similar in many respects to doing research in physics because engineering uses a great deal of physics. However, it is still engineering.
This is incorrect in my experience.
the best way to know if you would prefer engineering or research is to try both and make a call based on your experience. Even then, both fields are so broad and not mutually exclusive that you can't make a definitive conclusion.
Likes elkement
There are many situations in engineering where you NEED intuition and to really think about the problem. To say engineering jobs are all easy and brute force is to say you don't understand engineering.
No need to get protective about engineering. All we need to do is give OP info.
I'm sure the OP would appreciate it if you stopped giving him inaccurate info.
Don't look at me. Look at the people taking engineering research, which requires a PhD, and selling it as engineering, which requires a BSc.
I do engineering research and I have a BSc, looks like you don't know what research and the spectrum of things that means either.
Likes donpacino
Sure, whatever.
http://www.businessballs.com/kolblearningstyles.htm
koolraj09 said:
Hi all,
Thanks.
to answer your question in general, assimilators are more likely to be scientists, and convergers are more likely to be engineering.
The problem with identifying traits for careers is in many cases different people can be good at and enjoy the same job for different reasons.
if you're also curious take the myers brigs type indicator
If one has a PhD in engineering and does research in engineering, what exactly are they if not an engineer?
According to my supervisor, the one, most important personality trait for a research career is "resilience".
Take from that what you will. :)
koolraj09 said:
Hi all,
Thanks.
Challenging in what way? If you're talking about maximum nerdgasmic challenges, then yes, go for research. However, Engineering has many other challenges that you don't see in academia: You have to deal with the end users of your design. The design has to meet certain price points of financial viability. You have many arbitrary constraints and laws to consider. The challenges in Engineering may seem mundane, but I guarantee that they would leave any researcher flummoxed and confounded. It may not be a technical feat, but if the people you're building for don't understand the design, you have failed. It is a very human oriented endeavor.
Likes elkement
  • · Replies 18 ·
  • · Replies 51 ·
  • · Replies 18 ·
  • · Replies 19 ·
