Help Understanding Lorentz Factor
To determine the observed speed of a projectile fired from a train moving at 0.9c, the velocity addition formula must be applied rather than simply dividing by the Lorentz factor. The Lorentz factor for the given speeds is 2.294, but this does not directly yield the correct observed speed. Instead, using the velocity transformation equations will provide the accurate result. This involves performing two Lorentz boosts: first from the projectile's frame to the train's frame, and then from the train's frame to the observer's frame. Understanding and applying these concepts is crucial for accurate calculations in special relativity.
mdergance3
If I am at rest and I observe a train moving past me at .9c and then the train fires a projectile at .5c relative to it how fast do I observe the projectile moving?
With the speeds given, the lorentz factor is 2.294. I made the incorrect assumtion that I could just take the .5c and divide it by the lorentz factor since S = d/t and time is now 2.294 times slower.
How do I find the correct observed speed?
Apply the velocity transformation.
For this the simplest way is to just use the velocity addition formulas. If you want to know where that formula came from, though, you can do 2 lorentz boosts, one from the projectile's Frame to the train frame, and then from the train frame to the platform frame.
MOVING CLOCKS In this section, we show that clocks moving at high speeds run slowly. We construct a clock, called a light clock, using a stick of proper lenght ##L_0##, and two mirrors. The two mirrors face each other, and a pulse of light bounces back and forth betweem them. Each time the light pulse strikes one of the mirrors, say the lower mirror, the clock is said to tick. Between successive ticks the light pulse travels a distance ##2L_0## in the proper reference of frame of the clock...
  • · Replies 18 ·
  • · Replies 101 ·
  • · Replies 23 ·
  • · Replies 24 ·
