Help with a power supply (farnell G6 60a)
The discussion focuses on powering a matrix of 64 servo motors using the Farnell G6-60A power supply. The user calculated a requirement of 6V at 32A and confirmed that the G6-60A, rated at 6V and 60A, is sufficient. Key setup instructions include connecting a mains lead to the appropriate terminals and configuring the terminal blocks for 240V operation. Specific jumper settings for the six-way terminal strip are provided to ensure proper functionality.
  • Understanding of basic electronics and power supply connections
  • Familiarity with the Farnell G6-60A power supply specifications
  • Knowledge of wiring and terminal block configurations
  • Ability to read and interpret operating manuals for electronic devices
  • Research proper wiring techniques for connecting power supplies to electronic components
  • Learn about configuring power supplies for specific voltage and current requirements
  • Study the operating manual for the Farnell G6-60A to understand all features and settings
  • Explore safety precautions when working with high-current power supplies
Electronics enthusiasts, hobbyists working with servo motors, and anyone setting up power supplies for complex electronic projects.
ktz
Hi all,
I'm brand new to the forum and dreadfully new to electronics in general, but am doing my best to learn and I figured this may be a good place to start. (ps - this is not homework..I'm not a student of an electrical engineering, just an enthusiast trying to learn :)).
I'm trying to power a matrix of 64 servo motors through a board via a single power supply. I've got the board and calculated the power required as 6v @ 500mA x 64, so roughly 6v @ 32amps. I purchased a power supply online that will supply 6v @ 60amps (so plenty for the motors). The power supply in question is a Farnell G6-60A. It arrive as a single unit without cables, etc and a slightly confusing (to a rookie) front panel that I certainly don't want to hook up incorrectly. Can anyone help?
My guess would be to first buy a mains lead, clip the connector off, and screw the wires into the appropriate terminals (on the left in the photo). The manual states to then link the mains to the appropriate voltage on the 3-way terminal block on the right (which is 240V as I am in the UK). How would this be done? Just a single wire from the live block on the left to the 240V block on the right? After that, I'm a little confused on what to hook up to what to get power from the unit to my board @ 6V.
Sorry for the rookie questions, any help would be greatly appreciated!
The operating manual is here: http://3gcl.no-ip.org/3GCL/Datasheets/Electronics/SMPS/Farnell PSU/FARNELL. G6-60A. PSU. OPERATING GUIDE..pdf
(that first link, to imageshack.us, is broken)
On the second three-way terminal strip: to select 240V mains power jumper the top two terminals together, the ones labeled 240V and 220V.
On the six-way terminal strip, jumper:
+S to +
to -S
IN1 to PROG
The Output is those two big studs with nuts on them labelled + and -.
You can adjust the output voltage with that adjustment just above the six-way terminal strip.
Cheers,
Tom
