Help with complex number function problems
12 replies · 3K views · last reply
jaychay
Text reading Find lim as z approaches i/2 of f(z), given f is a complex function defined piecewise: f(z) = (4z^2 + 1)/(2z - i) for z not equal to i/2, and f(z) = a + bi for z = i/2.
Problem text: Find (a, b) which make f continue at z = i/2. Given f is a complex function with f(z) = (4z^2 + 1)/(2z - i) for z not equal to i/2, and f(z) = a + bi for z = i/2.
Can you help me with this two questions
I am really struggle on how to do it
Please help me
Thank you in advance
Factorize $(4z^2 + 1) = (4z^2 - i^2)= (2z+i)(2z-i)$
How can I solve the limit
Substitute the hint DaalChawal gave into the function definition of $f(z)$ and simplify it.
Then substitute the limit point $z=\frac 12 i$ for $f(z)$ with $z\ne \frac 12 i$ and evaluate it.
How far do you get?
Then substitute the limit value $z=\frac 12 i$ for $f(z)$ with $z\ne \frac 12 i$ and evaluate it.
How far do you get?
On question 2
Can you tell me on how to find (a,b) that can make it continue at z=1/2i
jaychay said:
On question 2
Choose $a$ and $b$ such that $a+bi$ is the same as the limit value from question 1.
Did you find the limit value or are you stuck somewhere?
[/QUOT
Did I do it correct ?
  • Handwritten working: z = 1/2 i, (4z^2 + 1) = (2z + i)(2z - i); then 4z^2+1 over (2z-i) or (2z+i)(2z-i) over (2z-i) with a cancelled factor; then 2z + i = 2(1/2 i + i) = i + 2i = 3i.
You made a mistake there bro
$2(\frac{i}{2})+i = 2i$
The first substitution is correct, but the parentheses are placed the wrong way in the substitution of $z=\frac 12 i$.
It should be:
$$\lim_{z\to\frac 12i} f(z) = \lim_{z\to\frac 12i} \frac{4z^2+1}{2z-i} = \ldots = \lim_{z\to\frac 12i} 2z+i = 2\left(\frac 12 i\right) +i=2i$$
Tha
Thank you bro
How far do you get?
Can you please check me on my another post on complex graph equation problem on question 2 on how to find ( a, b )
It should be:
On question 2
Is ( a,b ) equal to ( 0,2 ) right ?
It should be:
How far do you get?
On question 2
