Fortran How are numbers stored in F2 and F3 matrix in Fortran programming?
The discussion centers on interpreting a Fortran code snippet that reads data into two matrices, F2 and F3, from a file containing 118 sequential numbers. The matrices are defined with dimensions F2(4,6,2) and F3(5,7,2). The user seeks clarification on how the numbers are stored within these matrices based on the provided input format, which consists of 30 lines of four numbers each, with the last line containing only two numbers. The user proposes a specific mapping of the numbers to the matrix indices and asks for confirmation of its accuracy. A suggestion is made to run the program and print the values to verify the proposed storage arrangement.
scorzolin
Hi all,
I'm stuck on a fortran line code where I have a doubt on its interpretation.
The line is the following:
dimension F2(4,6,2), F3(5,7,2)
open(77,...)
read(77, '(4I3)') F2,F3
the file contains 118 numbers in 30 lines of 4 numbers (the last line has only 2 numbers).
considering that the file contains the numbers from 1 to 118 in this way
001 002 003 004
005 006 007 008
117 118
how these numbers are stored in the F2 and F3 matrix?
I suppose they are stored in the following way
F2(1,1,1)= 001
F2(2,1,1)= 002
F2(3,1,1)= 003
F2(4,1,1)= 004
F2(1,2,1)= 005
F2(2,2,1)= 006
F2(3,2,1)= 007
F2(4,2,1)= 008
F3(1,1,1)= 049
Is it correct?
or, if NOT, where I'm wrong?
thank you in advance for the help!
Technology news on Phys.org
Well, since you know the order of the numbers in your input text file, you could simply run the program and print out the first few values to see if you are correct.
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
18K
