How can I find two linearly independent solutions for 4xy''+2y'+y=0?
  • Thread starter Thread starter rapwaydown
    Frobenius Series
To find two linearly independent solutions for the differential equation 4xy'' + 2y' + y = 0, the discussion emphasizes the importance of assuming a power series solution of the form y = ∑ a_n x^(n+c). Participants suggest deriving the first and second derivatives from this series and substituting them back into the equation. One contributor mentions that dividing by 4x is unnecessary and that the equation can be simplified by substituting x = t^2 to find a closed-form solution. The conversation highlights the need for a solid understanding of calculus to effectively tackle such differential equations. Overall, the focus is on the method of assuming a series solution and deriving the necessary components from it.
rapwaydown
the question is
" find two linearly independent of frebenius series solutions for 4xy''+2y'+y=0"
I try almost everything to slove this, but could't figure it
any help is appercaited
thank you
Well, what have you done on it? You say you've tried "almost everything". Okay, what have you tried?
well, i divided the whole thing by 4x, trying to get it to the general format, but it didnt work out.
In other words, you really haven't done anything!
Start by writing
y= \sum_{n=0}^\infty a_n x^{n+c}
Find y' and y" from that and put them into the equation. What do you get?
Start by writing
i don't know how to find y' and y''
im slef learning def.Q
thanks for the reply tho.
Start by writing
by the way, i don't think y' and y'' is needed here
i divided the whole thing by 4x, then slove for the indicial,
which are r=0,-.5
but i don't know what to do from this point on,
i think i need to find the equation for cn, but don't know how.
can you help
You have to assume a solution as you have been advised
You don't need to divide by 4x.
When you assume the solution you will find d second and first derivatives of y, you will then subtitute into the equation.
I solved it and that's the way it goes.
Though not the question it is interesting to know that this DE has a solution in closed form. One can find this by substituting x=t^2 in the equation. A very simple DE will appear and can be solved directly. Doing the inverse substituting on this solution gives the result of the original DE. This solution can then be compared to the series solution.
It's probably not a good idea to try to learn differential equations, by your self or not, if you do not know Calculus!
Are you seriously saying that you do not know how to find the derivatives of xn?
And, to even attempt a problem like this you should have had enough Calculus to know that a power series is "term by term" differentiable inside its radius of convergence.
