Help with mechanics problem from images
  • Thread starter Thread starter winichris
    Mechanics
43 replies · 7K views
I still cannot get any idea..
How to find the velocity of the center of mass of the rod initially?
initially, the ring is fixed, so the rod's motion is pure rotation
so the speed of any part of the rod is given by the standard formula
v = ωr (strictly, v = ω × r)​
where r is the distance from the centre of rotation (ie from the end of the rod, where the ring is) :smile:
So the initial momentum= mrω = (m)(a)(g/a)^0.5?
As the distance between center of mass of rod and ring is a?
THX
About the moment of inertia of the rod:
As the standard formula of moment of inertia of rod is (1/12)ML^2,
I just need to substitute L=2a such that I=(1/3)Ma^2
Then add Ma^2 to the above (1/3)Ma^2 because the rotation is at the ring,
which is equal to (4/3)Ma^2?
THX
yes! :smile:
yes, "but" :rolleyes:
yes, you've correctly calculated the moment of inertia about the end of the rod :smile:
but, when calculating kinetic energy, you can only use 1/2 Iω2 if I is about the centre of rotation
that's ok for the initial energy here (since the ring is fixed),
but it won't work for the final energy (since the ring is moving, and you have no idea where the centre of rotation is :wink:) …
so for the final energy, you'll have to use the more awkward formula 1/2mvc.o.mass2 + 1/2 Ic.o.massω2
tiny-tim said:
yes! :smile:
At the highest point(final stage), ω=0, so I don't need to consider that I?
Momentum: maω=m(velocity of ring)+m(final velocity of center of mass of rod)
Energy: 0.5m(initial velocity of center of mass of rod)^2 + 0.5(4/3ma^2)(ω)^2 = 0.5m(velocity of ring)^2 + 0.5m(final velocity of center of mass of rod)^2
there is no need to consider the moment of inertia of the rod when it is at highest point?
(try using the X2 button just above the Reply box :wink:)
that's right …
you only need the 1/2mvc.o.mass2 part of the general formula, since in this case the 1/2 Ic.o.massω2 is 0 :smile:
hmm … we're on page 3 now :rolleyes:
could you please start a new thread on the new question? :smile:
For first question, when the rod moves to the highest point, the gain in PE should be??
θ is the angle between rod and vertical line
mg2a-mg2acosθ
or
mga-mgacosθ <-- consider all the mass in the center?
let's see …
winichris said:
http://imageshack.us/f/685/19897974.png/
yes, mga-mgacosθ (considering all the mass in the center)
that's why it's called the centre of mass …
it's the average position of all the mass, and you use it in formulas like mgh :wink:
