Help with NEXT and FEXT volatage magnitudes
  • Thread starter Thread starter Callum Plunkett
    Magnitudes Volatage
The problem involves calculating the magnitudes of Near End Crosstalk (NEXT) and Far End Crosstalk (FEXT) voltages in a transmission line formed by two parallel tracks on a printed circuit board. The line is characterized by specific parameters including length, termination resistance, and input voltage conditions.
  • Participants discuss the configuration of the transmission lines and the nature of the signals involved. Questions are raised about the definitions of NEXT and FEXT, as well as the reference voltages. There is also uncertainty regarding the variables t and td in the context of the equations provided, particularly in relation to the rise time.
The discussion is ongoing with participants seeking clarification on specific terms and parameters. Some guidance has been offered regarding the interpretation of the problem, and references to external resources have been shared to aid understanding. However, there is no explicit consensus on the definitions or values of certain variables.
Participants note the lack of complete information regarding the transmission line setup and the definitions of terms used in the equations. There is also mention of constraints related to the rise time and its relationship to the variables in the equations.
Callum Plunkett
A transmission line is formed by two identical parallel tracks in a printed circuit board. The line has a length of 50 mm and all line terminations are of 70 Ω. The line can be assumed to be lossless.
calculate the magnitude of the NEXT and FEXT voltages generated in the victim conductor when the source voltage, Vin, in the aggressor conductor is a voltage step of 2 V with a rise time of 100 ps.
Vs = Vin x Rin/(Rin+Zo)
Kne =Vp/4 (CmZo + Lm/Zo)
Vne = Kne (Vs(t) - Vs(t-2td)
Kfe = 1/2(CmZo - Lm/Zo)
Vfe = Kfe x length (d/dt)[Vs(t-td)]
Zo = root L/C = 70.7Ohms
Vp = 1/root LC = 17677695
Vs = Vin x Rin/(Rin+Zo) = 0.995v
Kne =Vp/4 (CmZo + Lm/Zo) = 0.08
I start to struggle with the next part (assuming the previous are correct) in regard to t and 2td. I'm sure from my notes t=vp but I'm unable to find the page any more and so I'm unable to verify this.
Vne = Kne (Vs(t) - Vs(t-2td) = 0.08
Again I'm struggling to find d and dt in regard to Far end
Kfe = 1/2(CmZo - Lm/Zo) = 3.99515E9
Any help would be much appreciated.
How many transmission lines do you have?
One line made from two parallel tracks, fed with a differential signal, or;
Two lines over a ground plane that work as a backward wave coupler?
All voltages are differential. What is/are the reference voltage(s).
FEXT = Far end cross talk, from what to what, relative to what?
NEXT = Near end cross talk, from what to what, relative to what?
The above picture accompanied the original question this is all the information I've been given.
You sir are a gentleman and a scholar, thank you very much!
is t the rise time? 100ps?
I am thinking not, because later in the notes it expresses td to be half the rise time.
If so what is t? for both the NEXT and FEXT equations??
thanks
Craig
is it this:
t = length √LV
td = Tr / 2
