Hertz Contact Stress for static condition
The discussion focuses on calculating Hertz contact stress for side guide rollers designed for a vertical gate under static loading conditions. The formula used is derived from Roark's, specifically stress = 0.798*sqrt(p/(Kd*Ce)), where 'p' is the applied load, 'Kd' is the roller diameter, and 'Ce' is a constant based on material properties. Participants debate the appropriate allowable stress for static conditions, referencing standards such as DIN 19704 and the US Army Corps Engineering Manual EM 1110-2-2703, which primarily address dynamic contacts. The consensus leans towards using allowable bearing yield stress or yield strength for static conditions, although concerns about conservativeness in these estimates are raised.
  • Understanding of Hertz contact stress calculations
  • Familiarity with material properties such as Poisson's ratio and Young's modulus
  • Knowledge of engineering standards like DIN 19704 and USACE EM 1110-2-2703
  • Basic principles of static and dynamic loading in mechanical design
  • Research the allowable bearing yield stress and its application in static loading scenarios
  • Study the differences between static and dynamic contact stress criteria in engineering standards
  • Examine the factors influencing yield strength in roller materials
  • Explore advanced calculations for contact stress in non-repetitive loading conditions
Mechanical engineers, design engineers, and anyone involved in the design and analysis of roller systems for static load applications will benefit from this discussion.
servaa
Hi all,
I am designing a set of side guide rollers for a vertical gate. There are four rollers on the gate (two on each side), and the rollers are designed for jamming load condition (they are not loaded most of the time). When jamming happens, one top roller and one bottom roller (on the opposite side of the jammed top roller) will be in contact with the rail, resisting tilting moment caused by hoist load. I was able to calculate hertz contact stress on rollers from Roark's as follows:
where p is applied load, Kd is equal to roller diameter, and Ce is some constant based on poisson's ratio and young's modulus of roller/rail material.
I am not sure though, what my allowable stress is in this case. I was able to find some criteria and standards that define allowable contact stress for wheels such as DIN 19704 (german), US Army Corps Engineering Manual EM 1110-2-2703, but the allowable stress defined in these standards seem to be for dynamic contacts.
The rollers that I'm designing is not going to be loaded repeatedly (maybe once in 5 years or so) and I think I need allowable static contact stress. Does anyone know how to approach this...??
Thanks a million!
servaa: Assuming you do not want the contact surface to yield, I think you could use the allowable bearing yield stress, which you could assume to be 1.5 times the allowable tensile yield stress. Or if you want to be more certain to not yield the contact surface, I think you could use the tensile (or compressive) yield strength.
nvn,
Thanks for info. Could you tell me what your source is..? Using allowable bearing stress seems to be a bit too conservative, as the allowable stresses defined in the standards that I mentioned are quite higher than those (2~2.5 times yield strength for USACE and 1.8 times ultimate strength for DIN standard).
Thanks!
I don't have a good reference for that.
may I know where I can find the 2.5 factor in USACE I mean section...
thanks
servaa said:
nvn,
Thanks!
33K
9K
