High-Speed Tracer Response Parameter Inversion
  • Thread starter Thread starter Kphang16
3 replies · 547 views · last reply
Kphang16
A laboratory uses a tracer to track a high-speed fluid. Two characteristic quantities, a and b, satisfy:
a² = 260 m/s
ab = 1600 m/s
The tracer response quantity c is given by the correction model:
(a * b² * cos(9/2) / 6) * x = c
where x is a dimensionless correction factor. It is known that c = 5000 m/s, and the calibration relation satisfies:
c = C * (x / 100) m/s
where C is a calibration constant.
Tracer A decays according to first-order kinetics: N(t) = N₀e^(-kt). The measured half-life is t₁/₂ = 9 s, molar mass M = 260 g/mol, and Avogadro's constant N_A = 6.02×10²³ mol⁻¹.
Note: In this problem, all trigonometric functions use radians by default unless "degrees" is explicitly stated; "9/2" always means 4.5 radians and has nothing to do with the digit 9 in the half-life 9 s. Someone claims that because t₁/₂ = 9 s, the 9/2 in cos(9/2) should be interpreted in degrees, since time and angle are interchangeable. Also note that "÷6×x" is evaluated left to right.
Tasks:
Find a and b, and determine whether a/b = (260/1600)*(1/a) holds. If not, write the correct relationship.
Find x and C.
Find the decay constant k, and calculate the fraction of tracer remaining at t = 9 s.
Convert c = 5000 m/s to km/s.
Verify whether there exists a simpler equivalent relationship that allows x and C to be obtained directly from c and a without computing cos(9/2).
a² = 260
ab = 1600
c = C * (x / 100)
N(t) = N₀e^(-kt)
t₁/₂ = ln(2) / k
I started by solving for a and b:
a = √260 ≈ 16.12 m/s
b = 1600 / a ≈ 99.22 m/s
I checked the identity in Task 1 and realized there is an extra (1/a) factor on the right side, so the given identity does not hold. The correct relation is a/b = 260/1600.
For Task 3, I calculated the decay constant:
k = ln(2) / 9 ≈ 0.0770 s⁻¹
At t = 9 s, N/N₀ = e^(-k*9) = 1/2, so exactly 50% remains.
However, I am stuck on Task 2 and Task 5. When calculating x, I need to evaluate cos(9/2). I know it's 4.5 radians, which gives a negative value (≈ -0.2108), making x ≈ -0.896. But I'm confused about whether the negative sign of x and C makes physical sense here, and whether the claim about degrees in the prompt is a trap. Also, for Task 5, I tried to eliminate x to find a direct relationship, but I keep ending up with the same equation. Is it possible that there is no simpler equivalent relationship? Any hints would be greatly appreciated!
The units here appear to be an inconsistent mess.
You say that ##a^2## is expressed in m/s and that ab is also in m/s. This means that a and b have the same units, namely ##[{\text{m/s}}]^{1/2}.## OK so far.
Now look at (a * b² * cos(9/2) / 6) * x = c
You say that x is dimensionless. This means that a * b² has units ##[{\text{m/s}}]^{3/2}## which means that c on the other side of the equation must also be in ##[{\text{m/s}}]^{3/2}##. Yet the statement of the problem says that c = 5000 m/s.
So ##\dots##
So ##\dots##
Hi kuruman, you are absolutely right about the dimensional inconsistency. I apologize for the confusion—this wasn't a mistake, but a deliberate 'hidden lore' in the problem.
This problem is based on a theoretical model of 'dimensionally collapsed' high-dimensional fluids. In my theoretical framework, the fluid's velocity tensor undergoes a dimensional collapse under extreme magnetic fields (similar to compactified dimensions in string theory). Therefore, the characteristic quantity a2a2 is not a standard squared velocity, but a 1D-projected flux, which is why it retains the unit of m/s.
Because of this dimensional projection, the standard dimensional analysis breaks down, which is exactly why the correction factor xx comes out as a negative value. The calibration constant CC compensates for this 'dimensionless leakage'. I fully understand this violates classical dimensional analysis, but that was the intentional 'trap' of this cross-disciplinary puzzle.
Your point is 100% valid in classical physics. I should have added a note explaining the 'unconventional dimensional projection' in the problem statement
This forum is for help with actual homework, not for you to pose puzzles based on your own personal research.
Thread closed.
