Horner's Method vs (x-1)^n: Which is More Accurate for Evaluating Polynomials?
  • Context: Undergrad
  • Thread starter Thread starter rukawakaede
    Method
The discussion revolves around the evaluation of polynomials, specifically comparing Horner's method with the expression (x-1)^4 for the polynomial f(x)=1-4x+6x^2-4x^3+x^4. Participants explore the computational efficiency and numerical stability of these methods, considering their implications in practical applications.
  • Some participants argue that Horner's method is more efficient and stable for evaluating f(x) due to fewer operations and reduced round-off error.
  • Others question the direct equivalence of f(x) and (x-1)^4, noting that recognizing the binomial expansion is not immediate and requires additional work.
  • One participant mentions that using (x-1)^4 can propagate numerical errors when x is close to 1, while Horner's method does not exhibit this issue.
  • Another participant discusses the concept of catastrophic cancellation when evaluating (x-1)^4, particularly in the context of subtracting nearly equal numbers.
  • Some participants provide examples and calculations to illustrate how numerical errors accumulate differently between the methods, particularly when x is near 1.
  • A later reply indicates that a mistake in code led to a realization that Horner's method was less accurate than initially thought.
Participants express differing views on the efficiency and accuracy of the two methods, with no consensus reached on which is definitively better. The discussion remains unresolved regarding the comparative advantages of each approach in specific contexts.
Participants highlight limitations related to recognizing polynomial forms, the impact of numerical errors in calculations, and the conditions under which each method performs optimally. These factors contribute to the complexity of the discussion without reaching a definitive conclusion.
rukawakaede
Firstly, I am not sure if I am in the right section. Pardon me.
I was reading something related to computational efficiency when evaluating polynomials. Suppose we want to evaluate
[itex]f(x)=1-4 x+6 x^2-4 x^3+x^4[/itex]
it would take n=4 additions and (n^2+n)/2 =10 multiplications to evaluate this f(x) on computer.
We know that it would be better (efficiency and stability) to evaluate f(x) using Horner's method, i.e
[itex]f(x)=1+x (-4+x (6+(-4+x) x))[/itex]
which only take n=4 additions and n=4 multiplications on the computer, (i.e. round-off error will be minimised).
So here is my question: wouldn't it better to evaluate
[itex]f(x)=(x-1)^4[/itex]
since it would only need 1 addition and 4 multiplication?
Could anyone share some insights on this?
no, in my opinion, because you need to do some work to go from 1-4x+6x^2-4x^3+x^4 to (x-1)^4. It is not obvious that the two functions are the same.
Well, it is just the binomial expansion of (x-1)^4.
I don't understand why we should not evaluate the f(x) directly using (x-1)^4 in terms of computational efficiency.
I believe this is something trivial, but I can't see it myself. Hope someone could give some idea.
I wrote some codes and plotted all the three variations of the functions with x around integer 1. It seems that only Horner's method give a desirable result. Significant numerical error occurs for the other two.
I understand that f(x)=1-4x+6x^2-4x^3+x^4 is give worse numerical result because of the number of multiplications and the rounding error accumulates.
But for f(x)=(x-1)^4, what other reasons (other than number of calculations) could that be?
"Well, it is just the binomial expansion of (x-1)^4."
when you are given "f(x)=1-4x+6x^2-4x^3+x^4" do you immediately recognize it as (x-1)^4? Using (x-1)^4 to calculate the value of the function around x~1 propagates the numerical errors which does not happen with Horner's. (x-1)^4 should be fine for x not close to 1.
Alright. I agree that needs some time.
Thanks. This is what I am looking for.
Could you please explain a little bit more on how numerical errors accumulate for (x-1)^4 when is x is about 1?
I am still not fully understand.
"Could you please explain a little bit more on how numerical errors accumulate for (x-1)^4 when is x is about 1?"
I took the numerical analysis course a long time ago. I am not sure I can provide you with an explanation. It has to do with substracting numbers that are almost equal...
It looks to me like 1 addition and 2 multiplications (2 successive squares).
epsi00, thanks. I think I understand now. I nearly forgot catastrophic cancellation.
Calculating (x-1)^4 by first calculating (x-1) and then calculating the fourth power seems to be the only way to get reasonable accuracy, when x is close to 1.
Suppose a multiplication gives a relative error of e, and addition/subtracton gives an error of e/(operand with largest absolute value)
suppose you calculate (x-1)^4 for x=1.01
(x-1) will produce a result of 0.01+e, (hopefully e<0.01)
(x-1) will produce a result of 10^(-8) + 4 * 10^(-8) e, so you get a relative error of 4e.
(ignoring higher powers of e)
The final addition when using horner rule will produce an error of at least e, on a result of 10^(-8), so a relative error of 10^8 (e) (ignoring the errors in the earlier steps),
so Horners' rule is a factor of 2.5 * 10^7 less accurate.
Thanks willem. I just realized that I made some mistake in my code and horner's method is less accurate that (x-1)^4.
Thank you very much.
  • · Replies 26 ·
  • · Replies 0 ·
