Hovercraft Help: Can Yamaha 440 Handle 130lb Load?
  • Thread starter Thread starter motomax99
5 replies · 3K views
motomax99
i need some help with my one engine hc
i have a 85lb snomo engine and a 45lb deck and me (130lbs)
is that too heavy for a yamaha 440 snomo engine?
Hmm. Don't know. I think you need to research the prop you'll use. You want to get one with as much thrust as possible. They sell hovercraft specific ones online, for like $100-200.
I've had a plan for a few years of making one using a plywood deck, lawnmower engine and (very) large innertube. Keep me posted on your progress. Perhaps you could more fully explain your plans.
It depends on the HP of the Yamaha engine? Is that the 4 cycle 40 horsepower engine??
Still not enough information. We also need the physical size of the hovercraft and how high off the ground you want it to go. Try playing with this calculator for a bit: http://www.olshove.com/HoverHome/hovcalc.html
thanks russ that helps a lot!
my deck ids made of two pices of luan sandwiching foam covered in fiberglass
and yes the engine is 40h
