Hovercraft vibration noise problem
  • Thread starter Thread starter tnorm12
    Noise Vibration
The discussion revolves around a hovercraft built from plywood with a pond liner bag skirt, which produces a loud vibrating noise when occupied. The noise is attributed to the skirt flapping and vibrating, particularly when weight is added to the craft. Suggestions include consulting experts from the UK hovercraft club for hands-on solutions, as they may have experienced similar issues. The original poster notes that their first prototype did not have the same noise problems, indicating that design changes may have contributed to the current issue. Overall, the conversation highlights the importance of design and proper construction in reducing noise in hovercraft.
tnorm12
I have built a 3' by 4' hovercraft (with rounded corners) out of plywood with a pond liner bag skirt. it it powered by either 2 battery operated leaf blowers or 1 plug in electric leaf blower. I have encountered a problem with both power sources. The hovercraft makes a loud vibrating noise when I stand/sit on it. It sounds like when you vibrate your lips together but much louder. With nobody on the craft there is a very small noise and with somebody on it its much louder. On the bottom there is a rectangular piece of plastic in the middle (16" by 4") positioned so that is 16 inches to every side (a little longer to the corners). There are 6 approx 2" holes around the middle (2 on each long side and 1 on each short side). Any suggestions of how to get rid of the noise? I assume its from not enough holes/bad positioning of the holes but i don't know.
What is the noise coming from? The skirt?
Fan designed for high volume and fast rotating is always going to have servere noise problems as the pressure jacks up and down at the skirt.
You are best talking to experts in the area like the hovercraft club in uk.
http://www.hovercraft.org.uk/archive/index.php
They have active forums with people who would have hands on solutions most likely.
yes the noise seems to be coming from the skirt. I noticed when turned on the skirt is flapping/ vibrating. The noise becomes louder and the vibrations quicker when I step on the craft
Uglybb you said it will always have sever noise problems but the thing is in my 1st prototype i built straight off the basic online model (round 4' diameter, leaf blower, plastic 6 mil sheet for skirt, 6 holes evenly spaced around the center, bag skirt) and there was not the same vibrating/rumbling sound. Thanks for the link
I haven't played with hovercraft for way too many years!
Admittedly my early attempts I didnt even create a proper bell chamber it was just an open cavity with a skirt and they were particually loud with two counter rotating propellers for lift.
Having a good model to start with would definitely been an advantage!
Times have changed understanding of the problems and solutions are much easier to find because if the internet ... enjoy :-)
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 21 ·
13K
  • · Replies 42 ·
  • · Replies 67 ·
15K
