How Accurate is the CDF Calculation in This Probability Problem?
  • Thread starter Thread starter mattmns
    Probability
3 replies · 4K views · last reply
mattmns
[SOLVED] Probability (cdf question)
Here is the problem from the book
Let X be a random variable with distribution function (cdf)
[tex] F(x)=\begin{cases}<br /> 0 &\text{for } x\geq 0\\<br /> \frac{x}{8} & \text{for } 0 \leq x < 1\\<br /> \frac{1}{4} + \frac{x}{8} & \text{for } 1 \leq x < 2\\<br /> \frac{3}{4} + \frac{x}{12} & \text{for } 2 \leq x < 3\\<br /> 1 & \text{for } x \geq 3\end{cases}[/tex]
Calculate [tex]P(1 \leq X \leq 2)[/tex].
This should be a simple question, but I am getting a different answer than my book is, and I believe the book is wrong (how could I be wrong? :-p).Here is what I did:
[tex] \begin{align*}<br /> P(1 \leq X \leq 2) & = P(1 \leq X < 2) \\<br /> & = P(X < 2) - P(X \leq 1) \\<br /> & = \frac{1}{4} + \frac{2}{8} - \left(\frac{1}{4} + \frac{1}{8}\right) \\<br /> & = \frac{1}{8}<br /> \end{align*}[/tex]
We could also get the same answer by finding the pdf and then integrating it over the interval (1,2).The book I have gives an answer of [tex]\frac{19}{24}[/tex].
Here is what they did:
[tex] \begin{align*}<br /> P(1 \leq X \leq 2) & = P(X\leq 2) - P(X < 1) \\<br /> & = F(2) - \lim_{x\to 1^-}F(x) \\<br /> & = \frac{11}{12} - \frac{1}{8} \\<br /> & = \frac{19}{24}\\<br /> \end{align*}[/tex]
In my opinion this seems doubly wrong. They used the wrong function on both, but at least they were consistent I suppose. Am I being silly here and missing something, or is the book wrong? Thanks!edit... I am looking at my book, and they have [tex]P(a < X \leq b) = F(b) - F(a)[/tex]. Now I won't argue with this, but the way it is used in the above example seems completely counterintuitive to me. I will admit my use of the cdf may be dubious for P(X < 2), but it feels right. Maybe the book is right after all. Thoughts?
There are two delta functions in your pdf as well as the continuous part. And they are both included in [1,2]. So P(1<X<2) is not equal to P(1<=X<=2).
So you are saying we have a mixed distribution, and that at least one of P(X = 1), P(X = 2) is non-zero? So from looking at the graph of the cdf, I see that P(X = 1) is 1/4 and P(X = 2) is 5/12.
So if we take what I have, 1/8, and add the points I forgot we get 19/24 which is the book's answer. Thanks, I guess this problem was a little more complicated than I had originally thought.
I guess I should take a closer look at what the cdf actually looks like :redface:
