How are Screw Conveyers Manufactured?
  • Thread starter Thread starter kateman
    Screw
Screw conveyors are manufactured through a process involving 3D modeling, laser or plasma cutting, and welding. The screw blade is typically roll-formed from strip or coil and then welded to a shaft. The body of the conveyor is constructed from a welded tube, a cone, and a cap, with the cone likely made from a flat sheet that is bent and welded. This method ensures a straighter final product by allowing the tube to extend through the cone.
  • Understanding of 3D modeling software for design
  • Knowledge of laser and plasma cutting techniques
  • Familiarity with welding processes and materials
  • Experience with roll forming techniques for metal fabrication
  • Research 3D modeling software options like SolidWorks or AutoCAD
  • Learn about laser cutting technology and its applications in manufacturing
  • Explore welding techniques specific to metal fabrication
  • Investigate roll forming processes and their advantages in screw conveyor production
Manufacturing engineers, metal fabricators, and anyone involved in the design and production of conveyor systems will benefit from this discussion.
kateman
Hello,
Does anyone have any idea how the screw conveyers in these photos would be manufactured? http://www.bwsinclair.com/Products/Live%20Bin%20Bottoms.htm
It's the variable fin length that I don't understand - could this be extruded? Any clue how it would/could be done?
Thanks for your help :)
Most likely modeled using 3D software, then laser or plasma cut based on flat patterns created by software. Finally, flat parts are bent/ formed and welded together.
My first thought was the same as tvaavavannnanad's: flat parts, bent and welded.
The screw blade is usually roll formed from strip or coil then welded to a shaft.
Thanks everyone for your insight- that does make a lot of sense :)
Out of interest, if they are made separately, how do you think the body may have been created?
Assuming that you mean the middle photo:
The body is made from a tube (purchased welded tube), a cone and a cap welded together.
The tube appears to extend full length through the cone (provides a straighter final part).
There are visible bend lines on the cone that suggest it was made from a flat sheet.
Note sure if they made the cone from one piece or two; may be possible to make from one, likely easier to make from two and have them joined with weld.
Get your grinder out.
  • · Replies 56 ·
