How Can Ethanol Be Converted to Acetone?
  • Thread starter Thread starter rohanprabhu
    Acetone Ethanol
9 replies · 18K views · last reply
rohanprabhu
Q] How would you convert Ethanol to Acetone?
none..
What I need is a C=O group at the second carbon in a 3-carbon chain. What I need first is a 3rd carbon. To do this, I first could:
i] React Ethanol with Ethanoic Acid [itex]\textrm{CH}_3\textrm{COOH}[/itex] to get Ethyl Ethanoate [itex]\textrm{C}_2\textrm{H}_5\textrm{COOCH}_3[/itex].
The problem here is that I have an extra [O]. Can a peroxide remove this? I'm not sure how to get rid of this.
ii] I could do HCN addition to gain an extra carbon in the chain. But how could I convert the CN to a ketonic group. Also, the problem is that it is on the terminal carbon, but i want it on the 2nd.
EDIT:
With Ethyl Ethanoate, if i could replace the [itex]-\textrm{OCH}_3[/itex] group with a [itex]-\textrm{CH}_3[/itex] (methyl) group.. I could get acetone. How do i go about doing it? Would Methyl Chloride help??
Hard to do with an alcohol. Not so hard to do with an aldehyde.
k then.. i could reduce it to an aldehyde using PCC. I will get [itex]\textrm{CH}_3\textrm{CHO}[/itex]. How can i get propanone from this?
Think about the way acetone was produced in "the old" days.
how exactly did they do it in old days?? I have no idea whatsoever...
chemisttree said:
Consult either Dr. Grignard or Dr. Wittig.
is this sarcasm or a hint telling me to consider using Grignard Reagents?
you can dehydrogenate the alcohol. pass the vapours of the alcohol over copper as catalyst at about 400 degrees. you will get the corresponding ketone and hydrogen.
It's not sarcasm. You have two paths from the aldehyde...
