How Can Gravity and Electromagnetism Be Unified Through a Rank 1 Field Theory?
  • Level: Graduate
  • Thread starter Thread starter sweetser
    Em Gravity
612 replies · 155K views
Lawrence B. Crowell said:
To start, I am so used to backslashes in TeX that it is hard to kick the habit with [/tex].
At this stage I would say with the GEM proposal that one of two things need to be done. Either the graviton and photon sectors, the abuse with the term graviton with standing, need to be clearly indicated in some way. This might be done with some tetrad formalism or with the embedding of GR and EM into some larger [itex]GL(n,~C)[/itex] group. Another approach is to somehow show that the spin-2 field of gravity, say in particular in the pp-wave solutions, can be built up from some coupling of photons. A gravity wave is a bivector, and in quantum optics there are phenomena of photon bunching or "bi-photons" which are similar to gravity waves. I say similar, for they still interact with electric charges and so forth. In such a theory two photons with alligned spins would interact to form a graviton. Currently such an interaction for counter spin alligned photons generate the [itex]Z_0[/itex] particle of weak interactions. In this way at very high energy, probably approaching the Planck energy, two photons would generate a graviton. How this would fit into Doug's theory theory is a bit unclear. Maybe if Randall et al. are right with so called "soft black holes" that occur at the TeV range in energy the other fields that the photon interacts with have some mass matrix so that there are oscillations between gravitons and photons. By this two photons correlated in a Hanbury Brown-Twiss manner will have some probability of being a graviton.
Yet this is pretty speculative. The dust bin of physics is littered with a lot of quantum field theory speculations.
On a related manner, my "hobby horse" is with information physics of quantum gravity. I have worked out how it is that black holes will preserve quantum information. I am not sure how one starts a thread on this list. Yet I would like to start throwing out some trial balloons before I try to publish things. If so this should prove to be interesting, for I have done some preliminary work on how symmetries of quantum gravity involves error correction codes. Things get into Riemann zeta functions and the like.
Cheers,
Lawrence B. Crowell
I don't know if Doug appreciates this parasite but interesting discussion and that's why I want to thank him and you, Lawrence. I don't know who you are and I guess that you are flying 2 km over my head with your knowledge but if you are interseting in, we could continue this thread on my subforum. I did make a try to investigate situations where the Lorentz Einstein Law is a differential operator and got a unique familly of solutions where the Christoffel's symbols can only be 0 or 1; that is intuitively appearing to be a possible junction with your "horse" and for a vision of the geometry as being a kind of computing machine: don't you think so?
Thank's for the precision concerning the bi-vector.
EM in GR & Information Q-gravity
I am not sure how to interpret the word “parasite.” The issue of including EM into gravity is almost as old as general relativity. The first suggestion was made by Kaluza & Klein in the early 1920s. Here the space is extended to 5 dimensions with the usual connection coefficients. Here one has metric terms [itex]g_{5\mu}[/itex], but one imposes the so called cyclic condition that [itex]g_{\mu\nu,5}~=~0[/itex]. This means that one has a connection term of the form [itex]{\Gamma^5}_{\mu\nu}~-~{\Gamma^5}_{\nu\mu}[/itex], which is interpreted as [itex]B~=~\nabla\times A[/itex] on the spatial terms. Of course one observation is that the Yang-Mills field, in this case electromagnetism, is on the connection level with GR, and the field potentials for this field are on the metric level in GR.
As for my information approach to quantum gravity, this involves the so called information paradox with black hole evaporation. The entropy of a black hole is only reversible if the black hole is in equilibrium with the environment so that [itex]dS~=~\frac{dM}{T}[/itex]. Yet the effective heat capacity of spacetime is negative, which means that as the black hole decays to lower entropy it heat up, contrary to normal thermodynamics. This means that even a quantum fluctuation will bump the black hole away from equilibrium and so [itex]dS~>~\frac{dM}{T}[/itex], which is contrary to standard thermodynamics where systems tend towards equilibrium. Quantum fields in curved spacetime are related to those in a flat spacetime by Bogoliubov transformations. The entropy of quantum states is given by the von Neumann equation [itex]S~=~-k~\rho~log_2\rho[/itex]. Because of this transformation I compute a conditional entropy [itex]\rho_{A|B}~=~lim_{n\rightarrow\infty}{{\rho_{AB}}^{1/n}({\bf 1}_A\otimes\rho_B)^{-1/n}[/itex] for the teleporation of quantum states with this conditional entropy negative. In a setting where quantum information is not included this negative entropy is ignored and so things appear irreversible. However, this negative conditional entropy means that excess information may be had “for free” so the apparent entropy increase of a black hole is accounted for. However, to use the analogy of a lottery, if one does not read the ticket to claim the winnings one plays a losing game. Of course reading that ticket is difficult, for this means an accounting of a vast number of entangled EPR pairs must be tracked, and tracked from the past to future of the black hole. This is in principle feasible, but is from a practical point of view intractible. A stellar mass black hole is then for all practical purposes an irreversible entropy machine.
Cheers,
Lawrence B. Crowell
This thread is intended to focus on the GEM proposal. As I interpret it, Blackforest was trying to be polite in shifting the discussion to things like bi-vectors which do not play a key role in my proposal. I am working on a (hopefully) clear statement about group theory and the GEM work which will require a few more days of work.
Efforts to unify gravity and EM go back to Priestly's discussions with Franklin about electricity. Franklin told Priestly about his observation that there was no electric field inside a conducting can. That is similar to there being on gravitational field inside a hollow massive shell. Priestly was the one to deduce the inverse square law of EM by this analogies to gravity. I have seen the GEM Lagrangian in the context of a purely EM proposal.
doug
bivectors & GEM
Doug,
Actually I brought up the issue of bivectors within the context of gravity waves. It is a real issue, for gravity waves are dyadic, while EM waves are vector. From a particle physics perspective this is why photons (as well as gluons and weak vector bosons) are spin = [itex]\hbar[/itex] and gravitons are spin = 2[itex]\hbar[/itex]. The issue is then how it is that the two sectors are intertwined.
Agreed that this forum is primarily for your GEM proposal. Things have sort of bled over a bit. I am not sure how strictly things are compartmentalized here. I have looked at Blackforest’s proposal, but have yet to dig into the meat there. The pdf files are a bit dense.
Cheers,
Lawrence B. Crowell
Hello Lawrence:
Let me clarify what is know about gravity waves. From observing binary pulsars, people have been able to infer that the lowest mode of emission is has a quadrupole moment. Rosen was the first person to write about the exponential metric, but his proposal is considered in error because it has a second metric metric field that could allow for a dipole moment in the wave emission. It is difficult to come up with an alternative proposal that adds fields yet has the quadrupole moment as the lowest mode of emission. The GEM proposal does not add fields, and I believe has the quadrupole, or as I like to think of it, wobbly-water balloon mode, as the lowest form of emission. I thought this issue was all about conservation of energy and momentum, not spin.
The reason that a gravity field must be spin 2 was spelled out for me in Brian Hatfield's introduction to "Feynman lectures on gravitation". If one wants like particles to attract, it takes particles of even spin: 0, 2, 4... He eliminates the spin 0 graviton because gravity bends light. That leaves the spin 2 field as the simplest possibility.
Unfortunately, I don't understand this issue yet, so I will explain how I see the relationship. There is the 4D wave equation. The gravitational and electric behavior of massless and massive particles can be characterized by this equation according to the GEM proposal. Focus only on the massless particles. These travel at the speed of light, which in a way is a constraint (I have forgotten how to discuss that constraint, something about polarity perhaps). A massless spin-1 field represents the photon, and has two of the four degrees of freedom of the wave equation. A massless spin-2 field represents the graviton, and has the other two degrees of freedom of the wave equation. Together the spin-1 and spin-2 fields completely describe long distance forces, one where like charges attract, the other where like charges repel.
Particles arise from field strength tensors. For the photon, that would be [itex]\nabla^{\mu}A^{\nu}-\nabla^{\nu}A^{\mu}[/itex]. For the graviton, the irreducible tensor [itex]\nabla^{\mu}A^{\nu}+\nabla^{\nu}A^{\mu}[/itex] is the source.
It might help to list all the things that I think are related in groups"
Gravity
like charged attract
graviton
spin-2
symm. tensor
EM
like charges repel
photon
spin-1
anti-symm. tensor
It still is necessary to explain what is going on on a group theory level. If that is what you mean by intertwine - clarify the group theory story - I remain guilty for a little while longer.
Researchers need the ability to wander, which is why I made an effort to explain Blackforest's unusual word choice, not complain about the digression. I too printed out three of the PDFs in his thread, but have not made a comment because I was not able to grasp why EM which works so great in 4D should be represented by 3D equations. To prevent a digression along the E question lines in this thread, I'll post something over there.
doug
Doug,
Cheers,
Lawrence B. Crowell
Thanks for the patience. Parasite was absolutely not negative but exactly what sweeter has said.
Coming to your point: "The issue is then how it is that the two sectors are intertwined."
In fact, if you read my homepage and not only the work proposed on this subforum, you will discover another alternative to this question and I am myself astonished. If you construct (as I tried) a GR theory with the moving frame method but without neglecting terms of the second order, only trying to incorporate them via the introduction of the ad hoc mathematical terms, then you find very funny things concerning the first partial derivates of the basis vector: they are isotropic vectors, they can generate symplectic forms, they can generate matrices with a formalism analogue to the formalism of the Maxwell EM field tensor 4D... Because I am not owning all appropriate tools to develop rapidly my theory, I stay in front of these results, perceiving roughly a fundamental relation between geometry and EM fields... For me, in this very special approach, it's like if variations of the geometric structure would generate EM fields in the tangent space of each event...
In principle The GEM is not far from this discussion. The difference is that I try to developp a more general approach (not reduced to the formulation of a Lagrangian). The problem is that I don't have the necessary mathematical tools to do that. That's why I need your helps. If I have the good ticket !
Best Regards
gravity wave quadrupole moment
The reason that gravity waves are quadrupole is because a dipole gravitational moment is [itex]P~=~mx[/itex], and so by conservation of momentum [itex]dP/d\tau~=~constant[/itex]. This makes a further point in illustrating the differences between gravitation and EM.
cheers,
Lawrence B. Crowell
Hello Lawrence:
That statement looks accurate about GR. There are other theories for gravity that predict dipole moments because there are other fields that can contain the momentum, so the field for gravity can trade momentum with the other field, leaving [itex]dP/d\tau~=~constant[/itex].
Would it be correct to say that the difference between gravitation and EM in this context is equivalent to saying there is one sign for mass, but two for EM? Momentum is conserved for an isolated electric dipole too.
doug
Diff(M) breaks U(1) symmetry
Hello Lawrence:
This is a valid request:
(To be honest, I am not familiar with what the word "sectors" means in this context, but I'll accept the task).
Before posting here, I did not have any position about how my proposal worked with group theory, although I wish I had one! Now I have a position.
EM arises due to U(1) symmetry of the action. Gravity is accounted for by the Diff(M) symmetry of the Hilbert action. I consider these two groups, U(1) and Diff(M), to be indispensable groups if one wishes to characterize EM and gravity respectively.
The GEM proposal looks not to replace these groups, but rather to find a relationship between them, how the two groups relate to each other. I propose the Diff(M) symmetry exceptionally weakly breaks U(1) symmetry. For an electron, the mass charge associated with Diff(M) symmetry ([itex]\sqrt{G}m_{e}[/itex]) is 16 orders of magnitude smaller than the electric charge associated with U(1) symmetry. At this point I have no explanation why there is such a large difference.
Contrast this to our best effort to unify gravity and EM, the Einstein-Maxwell equation. That action has Diff(M) symmetry for gravity, U(1) symmetry for EM, and the Higgs mechanism to introduce mass into the Lagrangian while preserving U(1) symmetry. The GEM proposal eliminates the need for the Higgs boson. There is a need for a scalar field to couple with all particles with mass, but that is simply the trace of the asymmetric tensor, or [itex]tr(g_{\mu \nu}\nabla^{\mu}A^{\nu})[/itex]. Another big problem with the Higgs mechanism is there is no obvious connection to the graviton. To my eyes, the symmetric second rank tensor [itex]\nabla^{\mu}A^{\nu}+\nabla^{\nu}A^{\mu}[/itex] can do the work of the graviton for gravitational mass, while its trace does the work of the scalar boson need for inertial mass.
doug
group structure of gravity
I am not going to comment much on alternate theories of gravitation. Dicke proposed an alternative as a benchmark for testing deviations from expected results by GR.
As for group theory, gravitation is the group [itex]SO(3,~1)~=~Z_2\times SL(2,~C)[/itex]. The group [itex]SL(2,~C)[/itex] may in turn be written as
[tex] SL(2,~C)~=~SU(1,~1)\times SU(2).[/tex]
The algebra for this is then [itex]su(2)[/itex] given by the standard Pauli matrices [itex]\sigma_{\pm},~\sigma_3[/itex] and [itex]su(1,~1)[/itex] has the elements [itex]\sigma_{\pm},~\tau_3~=~i\sigma_3[/itex]. The latter change gives the pseudoEuclidean nature to spacetime.
Now consider a connection one-form
[tex] A~=~A^+\sigma_+~+~A^3\sigma_3[/tex]
and a gauge transformation determined by the group action of [itex]g~\in~{\cal G}[/itex], [itex]g~=~e^{i\lambda\sigma_3}[/itex]. The gauge transformed connection is then
[tex] A^\prime~=~g^{-1}Ag~+~g^{-1}dg~=~e^{-2\lambda}A^+\sigma_+~+~A^3\sigma_3,[/tex]
where [itex]d\lambda~=~A^3[/itex]. Thus [itex]\lambda[/itex] is a parameterization of the gauge orbit for this connection. This leads to the observation
[tex] \lim_{\lambda\rightarrow\infty}A(\lambda)~\rightarrow~A^3\sigma_3,[/tex]
where [itex]A^+\sigma_+~+~A^3\sigma_3[/itex] and [itex]A^3\sigma_3[/itex] have distinct holonomy groups and thus represent distinct points in the moduli space [itex]\cal M[/itex]. However by the last equation we must have
[tex] F_\mu(A^+\sigma_+~+~A^3\sigma_3)~=~ F_\mu(A^3\sigma_3),[/tex]
and similarly for any gauge invariant function. Hence there exist two distinct point in the moduli space that define the same set of gauge invariant functions. Hence there does not exist a measure over these two points that separates them, and [itex]\cal M[/itex] is then nonHausdorff and has Zariski topology.
So the moduli space for gravitation is nonHausdorff, due to the hyperbolic nature of its group structure. This is also tied into why it is that gravity only has one “charge,” for with EM the two charges as roots are related by a simple rotation in the argand plane, but in gravity the two charges are not so connected. Thus for physics only one root is chosen, that for positive mass, while the negative root is not considered in the theory. Besides negative mass-energy creates all types of problems with GR, such as closed timelike curves and require quantum field sources that are not bounded below. Thus such solutions, wormholes and warp drives, are suspected of being pathological.
I tried to start a thread here, but it seems to have vanished into informationn to entropy land. I am not sure what I am doing wrong here.
Cheers,
Lawrence B. Crowell
Two groups pass in the night
Hello Lawrence:
It looks like we are talking past each other. Although I have the Diff(M) symmetry group in the title of two of my recent posts, you did not mention the group in your reply. Likewise, I have not really worked with any of the groups you have suggested. I understand why this can happen: technical discussion tend to stay near the technical topics one is most familiar with. Yet I always challenge myself: what is it I am missing or getting wrong? It is fun for me to make information move in my head.
So I decided to get out all my gravity books this weekend, and read up on Diff(M). I've got MTW, Wald, Feynman, Ohanian & Ruffini, and a few books on quantum field theory and groups. I went to the index, and none of them listed Diff(M). This completely takes you off the hook! (OK, you never were really on a hook, you gave me an honest reply, so this is a nonjudgmental observation). Then I got kind of worried: where is my documentation on this group if it is not featured in these books?
It was on the web at a URL I had posted before. This time I will quote the relevant section:
Baez said:
Now I should point out that for each of the symmetry groups I've listed above, people have worked out the "representations" of these groups. A representation of a group is a way to think of its elements as operators, and this is what we need to understand symmetries in quantum physics. The representation theory of the Poincar´ group dominates relativistic physics, while the representation theory of the Galilei group dominates nonrelativistic physics. I encourage everyone to learn the derivation of Schrödinger's equation straight from the representation theory of the Galilei group! It's cool. (I think it appears in the books by Mackey and Jauch listed here.)
In any event, we can ask for still more symmetry than conformal symmetry. We can ask for symmetry under all smooth coordinate transformations! The first to demand this effectively was Einstein, who got his wishes when he devised general relativity as a theory of gravity. So gravity is the most symmetrical of field theories so far - it's "generally covariant", or invariant under the group Diff(M) all diffeomorphisms of a spacetime M! One can also come up with a (classical) theory of gravity coupled to Yang-Mills fields, or whatever fields you like.
http://math.ucr.edu/home/baez/symmetries.html
There are a couple of really neat things about this quote. There are quite a good number of things in your posts that I do not understand. That indicates that I am not well-educated in quantum physics, otherwise I would know what Zariski topology is. A man has to know his limitations, and one of mine is an in-depth knowledge of quantum theory.
My favorite line: "So gravity is the most symmetrical of field theories so far - it's "generally covariant", or invariant under the group Diff(M) all diffeomorphisms of a spacetime M!" This is the kind of property I think I see in the GEM proposal. Starting from the flat Minkowski metric, it is a smooth transformation out to the exponential metric. That metric is NOT a solution to the Einstein field equations. It makes predictions which are consistent with current tests, and could be accepted or rejected on experimental grounds alone.
And the final line is also very relevant: "One can also come up with a (classical) theory of gravity coupled to Yang-Mills fields, or whatever fields you like." You have gone through the effort to list some of the possibilities. I do not have an issue with your proposal. Instead it is the question I don't get along with. It presupposes the structure of the answer: you have gravity, and it couples politely with other stuff. In the GEM proposal, gravity breaks U(1), SU(2), and SU(3). It does not break it much, in fact it is so darn weak those symmetries appear to our ability to measure, perfect. I probably need to devise a more technical way of saying that, but that is the thrust of the non-debate.
doug
diff(M), moduli and Hausdorff conditions
Hello Doug,
I did mention the group, that group is [itex]diff({cal M})~=~SO(3,~1)[/itex]. This is the analogue of the gauge group for gravitation. Gauge theory rests upon the idea that the particular gauge choice used is unimportant. The elementary example in electrodynamics is with the magnetic field [itex]B~=~\nabla A[/itex], and so any change in the vector potential [itex]A~\rightarrow~A~+~\nabla\chi[/itex] does not change the magnetic field by the “curl-div = 0” rule. This can be generalized to higher dimensions, and in one my posts on this discussions I do describe gauge theory in spacetime or [itex]{\cal M}^4[/itex].
This construction leads to the idea of a moduli space. Given a gauge potential its explicit construction has no basis on the fields. Let [itex]\Omega^{1}(ad~g)[/itex] be the set of one-forms on a manifold which are transformed by the action of a group [itex]g[/itex]. The coboundary operator [itex]D[/itex] then determines these elements by its operation on zero-forms (functions) with
[tex] \Omega^0(ad g)~^D\rightarrow~\Omega^1(ad~g).[/tex]
Thus a gauge connection may be determined as a “pure gauge” potential for
[tex] A^\prime~=~gAg^{-1}~+~gd(g^{-1})[/tex]
with [itex]A~=~0[/itex], and the group elements define the one-forms of [itex]\Omega^0(ad~g)[/itex]. Now the set of one-forms [itex]\Omega^1(ad~g)[/itex] are “all over the gauge space map.” In other words nothing is specified about their gauge. However, within this space the moduli may be defined. The following set
[tex] {\cal S}_D~=~\{A~\in~\Omega^1(ad~g): *D*A~=~0\}<br /> \}[/tex]
Here [itex]*[/itex] is the Hodge star operator which takes a p-form on an n-dimensional space [itex]p~<~n[/itex] to an n-p-form. This uses forms of the Levi-Civita antisymmetric symbols. Also the condition [itex]*D*A~=~0[/itex] may be other conditions --- the Coulomb gauge in 3-d or the Feynman gauge or ‘t Hooft-Veltman gauge or ... . This defines the slice [itex]{\cal S}_D[/itex] through the bundle, or equivalently the tangent space over the base manifold.
Now to round this out the fields are given by the two forms in the set [itex]\Omega^2(ad~g)[/itex] under the map
[tex] \Omega^1(ad~g)~^{P_\pm D}\rightarrow~\Omega^2(ad~g)[/tex]
where the [itex]P_\pm[/itex] is projector operator that send the two-forms to self-dual or anti self dual forms. Now the set of gauge equivalent forms [itex]{\cal S}_D[/itex] is given by the pullback on [itex]\Omega^2(ad~g)[/itex], and since these two-forms are independent of the gauge choice it is then the case that the slice [itex]{\cal S}_D[/itex] is an element of a space [itex]{\cal M}_{mod}~=~A/g[/itex], or the set of points “modulo group actions.” So this is the meaning of [itex]diff({\cal M})[/itex]
In the case of gravitation the group action is the Lorentz group, on in general the Poincare group with 6 generators --- 3 boosts plus 3 rotations (or angular momenta). Globally these are the transformation of special relativity, which are described by the orthogonal group [itex]SO(3,~1)[/itex]. In a Euclidean format the group is [itex]SO(4)~\sim~SU(2)\times SU(2)[/itex], and [itex]SO(3,~1)[/itex] reflects the signature of spacetime. I could go on about how [itex]SO(4)[/itex] and [itex]SO(3,~1)[/itex], as the Euclidean representation and pseudoEuclidean representations, but I’ll do that later. This might have some relevancy for the thread here on Euclideanized spacetime, but I have not yet had time to comment on that. However, in general relativity they are defined for local inertial frames, and how these local regions patch together gives the connection structure and curvatures of general relativity. A set of connections under a coordinate condition define the moduli and the curvatures of GR are [itex]\Omega^2(ad~g)[/itex]. Since the moduli space for GR has this pseudoEuclidean structure a particular moduli as [itex]{\cal S}_D[/itex], a point in [itex]{\cal M}_{mod}[/itex], is not separable from another point. Hence the moduli space is nonHausdorff, in the parlance of point-set topology (compact, paracompact and all that jazz). The Hausdorf condition on a space says that for any two points in that space sufficiently small neighborhoods may be found around these points that do no overlap. This however does not appear to obtain for the moduli space of general relativity. Hence the solution space (a’la the Frobenius condition) is difficult to understand. However, there are some bright lights here, for this means that apparently independent solutions are not that separate. Pp-waves (Petrov type N solutions) have structure which are related to Black holes (type D solutions) and this Zariski topology may illuminate how solutions in GR transform between each other.
Lawrence B. Crowell
Hello Doug,
[/tex]
[/tex]
Lawrence B. Crowell
Don J said:
Considering the 60 posts limited discussion on this board
If you are interested to try the ultimate test about your theory I invite you to joint another board where you can have all the room needed for discussion with hard Einstein relativistic theorician defenders.They can check in details the maths using by your theory applied to the bending of light by the sun for example.Or the precession of the orbit of Mercury.
You are very confident about your theory than a little challenge must only be "good".
Example of an actual discussion which is related in part about the Schwarzschild metric
"Celestial Mechanic wrote"
http://www.bautforum.com
Just a message of WARNING .I feel very sorry to have linked to BAUT forum.
I realize now after verification than that board called Against the Mainstream don't really allow for serious discussion about allternative concepts or researchs.
In fact every posters with new concept are litterally attacked and ridiculised by a bunch of as they called themsefve "debunkers".
Using a very disloyal technique describe here
See section
HOW TO DEBUNK JUST ABOUT ANYTHING
http://www.tcm.phy.cam.ac.uk/~bdj10/scepticism/drasin.html
Dont post to BAUT forum. :-p
Edit to add example of debating technique used by BAUT forum members describe in the above link .HOW TO DEBUNK JUST ABOUT ANYTHING
"Portray science not as an open-ended process of discovery but as a holy war against unruly hordes of quackery- worshipping infidels. Since in war the ends justify the means, you may fudge, stretch or violate the scientific method, or even omit it entirely, in the name of defending the scientific method."
Break symmetry by enlarging the circles
Hello:
Another weekend, another nice technical refinement. Discussions with Lawrence had made me confront the issue of group theory for the GEM proposal. I have realized that Diff(M) symmetry breaks U(1) symmetry slightly. A problem with this statement is that it is not precise enough in defining how U(1) symmetry is broken. In this note I will clarify this issue.
Let's start with an example of symmetry breaking. The symmetry of the standard model for massless particles is [itex]U(1)\timesSU(2)\timesSU(3)[/itex]. Most particles in the standard model are not massless. The Higgs mechanism is able to introduce mass for fundamental particles such as quarks and electrons through a false vacuum. A scalar field made up of Higgs bosons does the trick. Several billion dollars are being spent by the global physics community to detect the Higgs, which is thought to have a mass between 120 and 200 proton masses (see the July 2005 Scientific American for a gentle introduction to this topic). This is the proverbial Mexican hat: it is easy to visualize how the mass arises from particles going to the low lands of the hat.
There are three players in the standard model:
[itex]U(1)[/itex] The unit complex numbers
[itex]SU(2)[/itex] The unit quaternions
[itex]SU(3)[/itex] A special (ie norm of 1) group with 8 elements
One thing is shared by these three groups: one. Let's form complex-valued vectors that would be elements of each group:
[tex]U^{\mu}/|U| \in U ( 1 )[/tex]
[tex]V^{\mu a} / |V| \in SU(2), \mathrm{a goes from 1 - 3}[/tex]
[tex]W^{\mu b} / |W| \in SU(3), \mathrm{b goes from 1 - 8}[/tex]
Calculate the norms of the three vectors in flat spacetime.
[tex]g_{\mu \nu} ( U^{\mu} )^{\ast} U^{\nu} / |U|^2 = 1[/tex]
[tex]g_{\mu \nu} ( V^{\mu a} )^{\ast} V^{a \nu} / |V|^2 = 1[/tex]
[tex]g_{\mu \nu} ( W^{\mu b} )^{\ast} W^{b \nu} / |W|^2 = 1[/tex]
[NOTE: this is technically in error, as this is the interval, not the norm. Please see the next post, but I will leave this mistake on the public record]
Now we want to break symmetry a bit using the group Diff(M). That effects the metric, and the metric only:
[tex]g'_{\mu \nu} ( U^{\mu} )^{\ast} U^{\nu} / |U|^2 = 1 + \Delta[/tex]
[tex]g'_{\mu \nu} ( V^{\mu a} )^{\ast} V^{a \nu} / |V|^2 = 1 + \Delta[/tex]
[tex]g'_{\mu \nu} ( W^{\mu b} )^{\ast} W^{b \nu} / |W|^2 = 1 + \Delta[/tex]
[This WILL equal whatever it was with g, a basic property of norms]
The vectors for EM, the weak, and the strong forces have not been changed. The metric has changed, and by the equivalence principle, the only thing that can do that is mass. The vectors with this metric are no longer in the corresponding groups because the norm is different from one. They will form a group, one where the norm is [itex]1 + \Delta[/tex]. Essential the unit circle or spheres change there size a little bit. That is how symmetry is broken for the GEM proposal.<br /> <br /> On ontological grounds (a fancy way to say "the reason why things work"), I like the visual of the groups that are a bit different from one. It is easy to see circles and spheres getting bigger or smaller. Now that I have an alternative that can be experimentally tested, I can give up the false vacuum of the Higgs mechanism as I have other false gods.<br /> <br /> doug[/itex]
Oops, my bad, I am doing my notation wrong:
[tex]g_{\mu \nu} ( U^{\mu} )^{\ast} U^{\nu} / |U|^2[/tex]
will calculate the Lorentz invariant interval. The norm is not the interval. Essentially, instead of [itex]t^2 - R^2[/itex], I want [itex]t^2 + R^2[/itex]. Right now I am confused about what symbols to use to get to the norm, and how calculating a norm is connected to the metric.
doug
Theordor Kaluza wrote a similar paper
Are you familiar with Theordor Kaluza paper on combining GR and EM?
Does your work confirm or use the same ideas?
Regards
Terry Giblin
Hello Terry:
I guess you are referring to what is known as the Kaluza-Klein approach. In some ways that is a basis for work on string theory. If that is your question, the GEM proposal is different. Kaluza-Klein is a 5 dimensional theory; GEM is 4 dimensional. As far as I am aware (and I do not know the literature in any depth), the predictions for light bending around the Sun are identical for Kaluza-Klein compared with GR, but the GEM proposal will be different at second rank PPN accuracy (not that anyone is planning on getting to that level of accuracy). I cannot make an accurate statement about how Kaluza-Klein works in terms of group theory, but I doubt it has anything to do with breaking U(1) symmetry by changing the norm.
There appear to me fundamental differences between the approaches.
doug
moduli space overview
I am not sure about the reply by Don J.
What I wrote about moduli space is basically "bioler plate" stuff on this, dating back to the work of Atiyah and Singer back in the early 1980s. This leads to the stunning results of Uhlenbeck and Donaldson. In the first case singularities on the base manifold may be lifted to the moduli space in projective spaces. In the second it turns out that there exists an uncountably infinite number of 4-dim spaces, where only a measure epsilon of them are diffeomorphic, and most are homeomorphic but not diff - able.
My pet approach to what lies beyond standard theoretical approaches is with nonassociative observables. QM and GR have noncommutative structures [x, p] = hbar and commutators in curvatures. The extension beyond this is not to my mind likely to lead to symmetric field theoretic structures, but with nonassociative ones where
(ab)c - a(bc) =/=0.
I advise taking a look at my book "Quantum Fluctuations of Spacetime," World Scientific (2005) to see how this works. Essentially I have found that quantum mechanics and general relativity are equivalent as categorical structures of observables over Galois fields. Then GR and QM are quaternionic pairs that exist in a system of octonions. The Galois code for this is then developed for the 24-cell and ..., well I'll leave it to you to look this up.
At any rate, I strongly doubt that field theoretic structures are going to be symmetric, except for those under supersymmetry transformations where commutators "go to" anti-commutators.
cheers,
Lawrence B. Crowell
Non-associative quaternion multiplication
Hello Lawrence:
I formulated my proposal for this forum using standard tensor notation throughout. That said, I am pretty good with quaternions, it was the algebra I used to figure this stuff out in the first place. I own the domain name quaternions.com which features ways for doing physics with quaternions, from classical physics, to special relativity with local transformations instead of the global Lorentz group, EM, quantum mechanics, and my efforts to unify gravity and EM. Rewriting fundamental laws with quaternions is good training for theoretical physics.
Octonions are not necessary if you want a non-associative quaternion product. I have defined what I call the "Euclidean product" as being the standard Hamiltonian product with a conjugate operator tossed in:
Hamilton product:
[tex](a,B)(c,D)=(ac - B.D,aD+Bc+B\times D)[/tex]
Euclidean product:
[tex](a,B)*(c,D)=(ac + B.D,aD-Bc-B\times D)[/tex]
John Baez pointed out to me that:
[tex](AB)*C - A*(BC) =/= 0[/tex]
See, no octonians are needed.
I can understand the source of the feeling: none are used now, so that pattern should continue. For me, there is no reasonable justification for working the the deviation of the average amount of change, but completely ignoring the average amount of change itself. At least the differences are clear.
doug
The quantum equivalence principle
Hello:
Let's start with things researchers agree on:
1. A spin 0 quantum field is necessary to give fundamental particles like electrons and quarks inertial mass.
2. A spin 2 quantum field is required to mediate the effects of gravity.
3. The equivalence principle is a classical doctrine confirmed by experiments that the inertial mass is equal to the gravitational mass.
4. The correspondence principle shows that classical laws arise from the aggregate of quantum events.
In my limited exposure, folks who are searching for the Higgs particle do not bring up gravitons. Likewise, the gravity wave detector crowd appears unconcerned with the Higgs. Yet the equivalence principle must arise from an absolutely unwavering link between the quantum source for rests mass, a scalar field, and the quantum source for gravitational mass, a spin 2 field. The two fields can never "get out of step" with each other, or the equivalence principle will be violated, which it is not.
In the GEM proposal, the link between the scalar field and the spin-2 field is direct and rock solid: the spin 2 field for gravitational mass is the symmetric field strength tensor [itex]\nabla^{\mu}A^{\nu}+\nabla^{\nu}A^{\mu}[/itex], and the spin 0 field for inertial mass is the trace of the same symmetric tensor, [itex]tr(g_{\mu \nu}(\nabla^{\mu}A^{\nu}+\nabla^{\nu}A^{\mu}))[/itex]. Einstein was the first to argue the elegant case for the classical equivalence of gravitational and inertial mass. I am pleased the GEM proposal sings the same song on the quantum level.
doug
nonassociativity, octonions & field theory
The nonassociative product
[tex] (e_ie_j)e_k~-~e_i(e_je_k)~=~\upsilon_{ijkl}e_l[/tex]
can be defined where [itex]\upsilon_{ijkl}[/itex] is defined without reference to octonions. However, this system will not satisfy a closed algebra unless it defines the Cayley four-form. One can of course restrict things to this rather myopic view.
I am not sure what you mean by the Hamilton product. It appears that you are referencing a Jordan product in some form. The Hamilton product to me is
[tex] i^2~=~j^2~=~k^2~=~ijk~=~-1.[/tex]
and a general quaternion is defined by
[tex] H~=~a\sigma_x~+~b\sigma_y~+~c\sigma_z~+~d{\bf 1}[/tex]
In four dimensions the Pauli matrices are generalized to Dirac matrices.
At any rate, nonassociativity without reference to the octonions means that there is no closed multiplication table defined by the structure constant [itex]\upsilon{ijkl}[/itex], of which there are 480 possible representations. I could go into the cyclic group and [itex]PSL(2,~7)[/itex] Hurzewitz discrete group theory behind this, but that gets too far into maths.
Gauge theory has some sort of algebraic structure, eg. [itex]SU(n)[/itex], and the like. One of course defines gauge connections according to representations of this group. However, for there curvatures on the principle bundle are found by [itex]F~=~dA~+~A\wedge A[/itex], where the tensor components of the two-form [itex]F[/itex] in the case of an abelian field (EM) is the antisymmetric field strength tensor containing the electric and magnetic field components. The antisymmetry is imposed not by any group structure, but rather from a much more basic theory of chains and cycles on any manifold.
Physics was not built from the ground up, but rather from a domain of experience that existed at the time. Faraday’s description of changing magnetic fields, currents and the like were based on observational experience of the time. Of course now we can easily see that this all stems from [itex]F~=~dA[/itex], and things appear elementary. Neither Faraday nor Maxwell had any notion of differential forms or integrating on chains in n-dimensional manifolds. Maxwell indeed had things according to spinning ether vortices and the like as his “description.” In part because of this his original theory was actually quaternionic. Now in our modern age we can see that these types of theories have antisymmetric structure because of these basic “facts,” and hold for any gauge theory --- even gravity.
Lawrence B. Crowell
Hello Lawrence:
This is the definition for a Hamilton quaternion product I am using:
While this is true:
The nonassociative product.
it is not relevant because I am using a conjugate operator, or more technically an anti-involutive automorphism. The conjugate flips the sign of the 3-vector.
What I call a Euclidean product has a closed multiplication table:
[tex]i^{*} i= j^{*} j = k^{*} k= (i^{*} j)^{*} k = 1[/tex]
The standard definition of a non-associative product you provide does not use a conjugate operator as I do. Because the automorphism keeps the quaternions within the quaternion manifold, the multiplication table is closed: [itex]i^{*} i = 1[/itex]. Let's see this in action, how always taking the conjugate of the first quaternion in the binary quaternion multiplication makes the triple product non-associative.
[tex]a (b c) = a^{*} (b^{*} c) = a^{*} b^{*} c[/tex]
[tex](a b) c = (a^{*} b)^{*} c = a b^{*} c[/tex]
These are not the same. The norm of these two are same, but they point in different directions.
Our current gauge theories for gravity and EM are both spectacular and inadequate. Both match experimental data extraordinarily well. Yet we cannot quantize EM without choosing a gauge. Even if a gauge is chosen, gravity cannot be quantized.
Let me reestablish how I am working from the "domain of experience". Gravity and EM as currently formulated work in 4 dimensions, as does GEM. It is odd that simple statement is at odds with the majority of work on gravity today. The group Diff(M) was used by Einstein to make his equations covariant, and it plays a role in GEM. EM symmetry must be broken by a scalar field, as it is in GEM by the trace of the field strength tensor. The 4D EM wave equation can be quantized by the Gupta-Bleuler method, but two of the modes of emission must be eliminated by a supplementary condition. GEM uses the same creation and annihilation operators, but it also has a spin 2 field that will not have the same technical issues the spin 1 scalar mode has. And in keeping with the most important of all scientific traditions, should we refine the level of accuracy of measuring light around the Sun, GEM predicts 0.7 microacrsecond more than GR, so unlike all the work in string theory, I am willing to put every chip I own on the line and let the data decide.
How things get written matters. You write the field strength tensor as [itex]F = dA[/itex]. Nothing can be simpler than that. Sure, it has all the differential forms stuff behind it, but since that is the starting point, I can appreciate that there appears nothing simpler. I write it differently, also in an established way, as a [itex]F=\nabla^{\mu}A^{\nu}-\nabla^{\nu}A^{\mu}[/itex]. In my notation, I can explain even to my girlfriend that the F thingie is not a complete story because of the act of subtraction: there are 4 parts in the triangle, 4 parts in the A, sixteen parts total, but the study of light needs only 6 of the 16. What I cannot explain to her is why the brightest folks on the planet do not share my feelings of obligation to work with the other 10 terms.
dougHistorical note: Maxwell was familiar with quaternions because Hamilton trumpeted their cause (too loudly). Scalar, vector, div, grad, curl were inventions of Hamilton in his quest to understand quaternions. In Maxwell's first edition of his treatise, he used "pure quaternions" which is one with a zero for the scalar, effectively as a stand-in for 3-vectors. He did nothing at all fancy with quaternion algebra. By the third edition, he only hoped that quaternions would play a role in describing EM. Many folks have figured out how to toss in an extra imaginary number and get the Maxwell equations. Peter Jack was the first person to do so with real quaternion (1996?) and I did the same independently a year later. There is a rumor on the Internet that some 200 quaternion equations were deleted from the first to the third edition. From my viewing of an on-line version of the first treatise, that is an inaccurate description: the quaternions were used like any 3-vector, and he did not write the homogeneous or source equations as an exercise in quaternion algebra.
Below is a multiplication table of octonions that I devised for fermions. It was derived with respect to black hole physics and Bogoliubov transformations --- but that is another story. These fields are the operators for ingoing and outgoing modes into a black hole. These fields include their conjugations. I hope this shows up right!
[tex] \left(\begin({\array}{}* & * & e_1 & e_2 & b_k & e_4 & b_k^\dagger & b_{-k} &<br /> b_{-k}^\dagger \\ *& * & *& * & * & * & * & * & *\\ e_1 & &-1 & e_4 &<br /> b_{-k}^\dagger & -e_2 & b_{-k} & -b_k^\dagger & -b_k \\ e_2 & &<br /> -e_4 & -1 & b_k^\dagger & e_1 & -b_k & b_{-k}^\dagger & b_{-k} \\<br /> b_k & & -b_{-k}^\dagger & -b_k^\dagger & 0 & b_{-k} & e_2 &-e_4 &<br /> e_1 \\ e_4 & & e_2 & -e_1 & -b_{-k} & -1 & b_{-k}^\dagger & b_k &<br /> -b_k^\dagger \\ b_k^\dagger & & -b_{-k} & b_k & -e_2 &<br /> -b_{-k}^\dagger & 0 & e_1 & e_4 \\ b_{-k} & & b_k^\dagger &<br /> -b_{-k}^\dagger & e_4 & -b_k & -e_1 & 0 & e_2\\ b_{-k}^\dagger &<br /> & b_k & b_{-k} & -e_1 & b_k^\dagger & -e_4 & -e_2 &<br /> 0}\end{array}\right)<br /> [/tex]
You say that (ab)c and a(bc) have the same norm but differ in their direction. That is standard with octionions. You might notice this if you examine this table.
A couple of other points. A choice of gauge amounts to lifting the base manifold up the fibre. Think of the base manifold as a sheet of paper. Then perpendicular to each point is a line coming up, which for the case of triviality defines the tensor product of the vector space in the line with the manifold. Now to compute the action of this internal vector space one needs to move from fibre to fibre. But how does one do this? One takes the base manifold (the sheet of paper) and lifts a copy of it so it cuts through the fibres. One can lift the copy paper any way one wants, but once done things are computed with that choice. This is what a gauge choice is. One needs to define a bundle section in some way. It does not matter how this is done, but it must be done and used consistently. Well, 't Hoft and Veltmann did a gauge choice change in mid-stream with QCD to get renormalizability, but one has to be very careful about that! At any rate a gauge choice is nothing more than a way of fixing a frame, akin to defining a reference frame in relativity (or Newtonian mechanics for that matter) in order to do calculations.
As for why only 6 of the possible terms end up as real is because the antisymmetry imposes a structure on the field. Anyway, we only have 3 E-fields and 3 B-fields. Imposing a structure on the theory involves the elimination of some of the possible tensor terms. The antisymmetry of gauge field 2-forms does that automatically.
Lawrence B. Crowell
doug
Hello Doug;
In QFT isn't mass obtained, at least some fraction of it, by radiative corrections? How does that relate here ?
Radiative corrections
Hello Creator:
The short answer is I do not know how to incorporate radiative corrections into the proposal.
I do know that for compound particles such as protons and neutrons, most of the mass is from the movement of gluons and quarks. Any radiative corrections would be just another source of energy to add into the picture. I am unable to calculate what percentage of the proton mass comes from the Higgs mechanism. I'm sure some folks on the planet know how to do that calculation, but I do not. The ice is very thin where I am skating!
doug
Hello Lawrence:
Unfortunately, your table for the Octonians did not work out :-( I would love to see it. If you come back to the forum, there should be an edit button at the bottom if you have logged in. The first two lines look something like this:
So the "*"'s need to be replaced with what goes in there. A second effort for this multiplication table would be appreciated. Note that after the save button is hit and the page appears, the new graphic does NOT appear. The equation is a graphic which the computer keeps in cache. One must hit the reload button while holding down the control key to see the improvements.
doug, whose LaTeX here is NEVER done perfectly the first time.
I have an inordinate difficulty with the LaTeX here, which I do not have otherwise. Anyway, I have taken a dvi page with this table and prduced an image file. I am going to try to attach that to this post.
Lawrence B. Crowell
Hello Lawrence:
Thanks for the dvi page. I am a bit confused about one aspect of this table. Octonions are a non-associative, non-commutative division algebra. The zeros that appear in the table would create a problem for the division algebra. I think those should be -1's. For completeness, the identity should be included. Here is a table from the web without zeroes: http://www.geocities.com/zerodivisor/obasis.html
doug
octonion table
The zeros are meant to convey fermionic content with b^2 = 0. The anticommutators of the Fermionic fields are "treated" as commutators in order to obtain associators
[a, b, c] = (ab)c - a(bc).
I suppose I should have considered the anti-associator
{a, b, c} = (ab)c + a(bc)
instead to avoid this matter. However, the basic import is that the xero reflect a topological content of fermions. Since b^2 = 0 this is equivalent to d^2 = 0, and that the fields are defined in ker(b)/im(b). This topological element is what skirts the problem with division algebras. I think this extends to the sedenions, but that is another issue.
Maybe this was not the best example for this, for in most cases there is none of this topological implication underlying it. I attach a more familiar octonion multiplication table.
