How Can I Build a Biomass Steam Generator Using Coco Shells?
  • Thread starter Thread starter Bong
    Generator Steam
This discussion focuses on building a biomass steam generator using coco shells as fuel. Key considerations include the need for strong materials to withstand high pressure when converting steam to electricity. The process involves burning coco shells to produce steam, which can then be used to drive a turbine for electricity generation. For a more eco-friendly approach, recycling water is recommended to reduce energy and water consumption.
  • Understanding of biomass fuel properties
  • Knowledge of steam generation principles
  • Familiarity with turbine operation and design
  • Basic concepts of pressure vessel engineering
  • Research "biomass steam generator design specifications"
  • Explore "pressure vessel materials for high-temperature applications"
  • Investigate "turbine efficiency in biomass energy systems"
  • Learn about "water recycling techniques in steam generation"
Engineers, renewable energy enthusiasts, and anyone interested in sustainable energy solutions using biomass for steam generation.
Bong
Please help me, this is urgent. Anyone who has a sample of design and construction of a cocoshell feed steam generator? or site/s where i can find complete data in the design of the said steam generator?
I think you need to add a little more detail to your question.
Are you trying to burn a fuel to make heat for the production of steam?
It all depends on what you have in mind. If you are just trying to make steam, then build a coco shell fire and put a pot on it. The water boils to make steam. If you wish to convert this steam to electricity this is a little more complicated and dangerous. You will need to let the steam build up pressure, which requires stronger materials that won't rupture at high pressure. The steam pressure is released to drive the turbine, which will generate electricity. This cools the steam. To make it all more green friendly, one needs to recycle the water to lower your total energy and water requirements. If it was me I would google "used wood fired" steam generator. Then I would try to substitute coco shells for wood. The design parameters should be close.
  • · Replies 19 ·
10K
