How can I get my ListPlot to go from {x,-10,10} on x?
  • Context: Mathematica
  • Thread starter Thread starter Freya
The discussion revolves around how to adjust the x-axis of a ListPlot in a coding context, specifically to ensure it ranges from -10 to 10 based on the iteration variable n. Participants are exploring the use of list pairs and the structure of their data to achieve the desired plot output.
  • One participant describes their code that generates a ListPlot but notes that the x-axis currently ranges from 0 to 21 instead of -10 to 10.
  • Another participant suggests using list pairs to adjust the x-axis, indicating that this approach has worked in examples they have seen.
  • A participant mentions trying to create list pairs but encounters difficulties due to the structure of their list, which contains multiple elements per entry.
  • One participant confirms that using the format [{n,f[n,o]}] is the correct approach and asks about the errors encountered when trying this method.
  • Another participant describes an issue where the output graph appears incorrect, showing unexpected data points and ranges.
  • There is a suggestion that the list may be transposed, leading to incorrect plotting behavior.
  • One participant proposes checking the shape of the data being sent to ListPlot to ensure it is formatted correctly.
Participants express differing views on the cause of the plotting issue, with some suggesting that the list structure is the problem while others believe the issue may lie earlier in the code. No consensus is reached on the exact solution.
Participants mention various attempts to format their data correctly for ListPlot, indicating potential limitations in their current understanding of list structures and plotting functions.
Freya
I have some code that is basically taking a range of energies, putting them into some recurrence equations and solving, and then I want to plot the results.
Code:
\[HBar] = 1;
m = 1;
Do[Energy[z] = 0.5 + 5 z, {z, 0, 14}]
Table[Energy[z], {z, 0, 14}];
Do[Entot[n, o] = Energy[o] - \[HBar]*\[Omega]*n, {n, -10, 10}, {o, 0,
  14}]
Do[k[n, o] = 2*m*(Entot[n, o])^(1/2), {n, -10, 10}, {o, 0, 14}]
\[Omega] = 1;
s = 10;
k0 = 10;
\[Alpha] = 10;
t0 = 1;
t[-11] = 0.01;
t[11] = 0.01;
r[-11] = 0.01;
r[11] = 0.01;
ClearAll[plot1]
Do[eqn[n, o] = -t[n] +
    KroneckerDelta[n,
     1] + (s*m/(2*\[HBar]^2*I*k[n, o]))*(t[n - 1] +
       t[n + 1]), {n, -10, 10}, {o, 0, 14}];
tab1 = Table[eqn[n, o], {o, 0, 14}, {n, -10, 10}];
tab2 = Table[t[n], {n, -10, 10}];
Do[plot1[p] = NSolve[tab1[[p]] == 0, tab2], {p, 1, 15}]
Do[f[n, o] = t[n] /. plot1[o], {n, -10, 10}, {o, 1, 15}]
ListPlot[Abs[
  Table[Flatten[Table[f[n, o], {n, -10, 10}]], {o, 1, 15}]],
 PlotRange -> {0, 1.5}, PlotLegends -> Automatic]
At the moment, the ListPlot at the bottom takes the index of the list, so it goes from 0 to 21. But really, this should go from -10 to 10, following the iteration of n. I have tried everything it seems, from making my table go like [{n,f[n,o]},{n,-10,10}] but this doesn't work. I've tried making a separate list of n's and then transpose this with the f's, but as f is going over o as well, I think the length discontinuity is causing issues.
Any help would be much appreciated, and apologies if my code's a mess, I'm very much a rookie.
Thanks!
Can you create list pairs? The examples I saw of listplot adjusted the x-axis when list pairs were used.
Thanks for your reply!
I tried that but due to my list being effectively a list with 21 elements, with 15 in each element, it can't be done simply it seems, I think I need some tricky syntax
This is the right way to do it. What error did you get when you tried this?
Try just one fixed value of o first.
It doesn't get an error per say, but the graph it spits out is wrong, if I look at just one o I get a 2 sets of data plotted (or so it seems) one that's a straight line going from -10 to 10 in y (no idea why) and then roughly the right shape of the graph for f, but x now goes from 0 to 42.
List pairs are:
(-3,9), (-2,4), (-1,1),(0,0), (1,1),(2,4),(3,9)...
ListPlot will then adjust the X-axis to match the axes to range of x values and the range of y values which in this case is
x: -3 to 3 and y:0 to 9
jedishrfu said:
List pairs are:
I've been trying to do this but I think the issue is my code isn't quite {x1,y1},{x2,y2} etc, I have several values for each x
That sounds like your list has been transposed. So instead of {{x1,y1},{x2,y2},...} your list goes {{x1,x2,...},{y1,y2,...}}.
I may be wrong, but I don't think that's my problem, I think it may be further back in my code as when I print values of f, they are already in a list, I'll play around and see what I can find
It is easy enough to check. Just make a new variable and set it equal to the value sent to ListPlot. I bet it isn't shaped right.
