How can I make singular matrix become nonsingular matrix?
The discussion focuses on transforming a singular matrix A into a nonsingular matrix suitable for unitary transformation on matrix B using Mathematica. The original matrix A is singular due to its structure, which zeros out six of its eight dimensions. A proposed solution involves creating a new orthogonal matrix C that retains certain dimensions while modifying others, specifically by negating and swapping specific rows. This approach allows for a valid transformation without compromising the integrity of the matrices involved.
  • Understanding of linear algebra concepts, particularly matrix singularity and orthogonality.
  • Familiarity with unitary transformations and their mathematical implications.
  • Proficiency in using Mathematica for matrix operations.
  • Knowledge of matrix multiplication and its properties.
  • Explore the concept of orthogonal matrices and their applications in linear transformations.
  • Learn about unitary transformations and their significance in quantum mechanics.
  • Investigate methods for modifying singular matrices to achieve nonsingularity, including perturbation techniques.
  • Study the implementation of matrix operations in Mathematica, focusing on functions related to matrix inversion and transformation.
Mathematicians, physicists, and computer scientists who are working with linear algebra, matrix transformations, and computational mathematics using Mathematica.
munirah
<< Mentor Note -- thread moved from Homework Help forums to General Math >>[/color]
Good day,
I run coding in Mathematica. But, I get singular matrix A at certain loop. In theory, how can I make matrix A become orthogonal
A=\begin{pmatrix} 0& 0 &
0 & 0 & 0 & 0 & 0 & 0\\ 0& 0 &
0 & 0 & 0 & 0 & 0 & 0 \\ 0& 0 &
0 & 0 & -1 & 0 & 0 & 0\\ 0& 0 &
0 & 0 & 0 & -1 & 0 & 0\\ 0& 0 &
\\ 0& 0 &
\end{pmatrix}
because I want to make a unitary transformation on matrix B
B=\begin{pmatrix} 1& 0 &
\\ 0& 0 &
\end{pmatrix}
with using definition AB A^{-1} since matrix A is orthogonal matrix.
Please help me to figure out my problem.
Thank you very much.
Afaict, you haven't given us enough information to enable us to help you.
Your ##A## matrix is singular. Without further information, you can't magically make it nonsingular.
Thank you for respond. I want to make unitary transformation to the state B. When I run the coding, at certain time, the matrix become singular. How can I solve it hence it will give the result of the trace equal to 1
Sorry, but unless you can better understand the meaning of "you haven't given us enough information", I doubt anyone can help you.
You could vary the matrix entries by a small (infinitesimal) amount to get it regular or even unitary. But as long as you cannot control the meaning of such a manipulation, your results become worthless. It would be a topological method, and you have to assure beforehand, that this is a valid method to do. Normally, i.e. when considered the pure algebraic or geometrical aspects of a linear equation, this won't be allowed, or to be exact: only within very special conditions. (V. Strassen once considered aspects of the Zariski-topology to prove lower bounds on the complexity of matrix multiplication.)
This means you can't do this, e.g. to get rid of the kernel.
So in the generality you stated your question, the answer has very likely to be: It cannot be done (without smashing the outcome).
Likes munirah
Your A matrix is so far from orthogonal that it just zeros out 6 of the 8 dimensions. And it zeros out the only dimension where B has a non-zero element. So making A orthogonal would be totally fabricated.
That being said, I will take a wild stab at something. If you are asking for an orthogonal matrix that has the -1s of A but leaves the other dimensions unchanged (instead of zeroed out), then this might be what you want. It just negates and swaps the 3rd and 5th dimensions and it negates and swaps the 4th and 6th dimensions, leaving the other dimensions 1,2,7,8 unchanged.
C =\begin{pmatrix}
1& 0 & 0 & 0 & 0 & 0 & 0 & 0\\
0& 1 & 0 & 0 & 0 & 0 & 0 & 0 \\
0& 0 & 0 & 0 & -1 & 0 & 0 & 0 \\
0& 0 & 0 & 0 & 0 & -1 & 0 & 0\\
0& 0 & -1 & 0 & 0 & 0 & 0 & 0\\
0& 0 & 0 & -1 & 0 & 0 & 0 & 0\\
0& 0 & 0 & 0 & 0 & 0 & 1 & 0\\
0& 0 & 0 & 0 & 0 & 0 & 0 & 1
\end{pmatrix}
Likes munirah
Thank you for respond it. It check it and yes,I made a mistake from multiply the matrix. Thank you all.
  • · Replies 30 ·
