How Can I Simplify This Linear Algebra Expression for Differentiation?
15 replies · 6K views · last reply
GeoffO
I am trying to simplify the following, so that I can differentiate it (with respect to X). Ideally I'll have everything in terms of ([tex]XX^T - YY^T[/tex]).
[tex] \mathrm{trace}[(AX(AX)^T)((BX)(BX)^T)^{-1}] - <br /> \mathrm{trace}[(AY(AY)^T)((BY)(BY)^T)^{-1}][/tex]
Where X and Y are 3 x N and A and B are N x N. A is symmetrical, B is anti-symmetrical (or skew symmetrical).
Some useful properties:
[tex] \mathrm{trace}(UV) = \mathrm{trace}(VU)[/tex]
[tex] \mathrm{trace}(U)+\mathrm{trace}(V) = \mathrm{trace}(U+V)[/tex]
I can't figure this out and have spent a long time working on it.
A is a band diagonal matrix where each row is a shifted version of (1 -2 1) and B is similar with a stencil of (-1 0 1).
Any ideas?
Welcome to PF!
Hi GeoffO! Welcome to PF! :smile:
Hint: (PQ)T = QTPT.
And XXT is an n x n matrix.
So just change the order of everything. :wink:
Thanks for the reply. I have used this property and end up with
[tex] \mathrm{trace}[<br /> (B^{-1}A)^T<br /> (XX^T(B^{-1}A)(X^TX)^{-1} - <br /> YY^T(B^{-1}A)(Y^TY)^{-1}<br /> ][/tex]
Which is okay, but I'd really like to get that common [tex](B^{-1}A)[/tex] term out of there.
We can rewrite this as
[tex] (Q^T)(R^T Q R^{-1} - S^T Q S^{-1})[/tex]
Where R and S are symmetrical (because they're squared X and Y from above). This looks so simple, but I can not find a way to further simplify.
Now change the order of everything …
put all the As and Bs on the left, and the XXT or YYT on the right. :smile:
What property allows me to reorder like that? I only know of the property
[tex]\mathrm{trace}(AB) = \mathrm{trace}(BA)[/tex]
(Again, thank you.)
(Again, thank you.)
Yes, and it works for any square matrices …
and XXT is square, so you can shove it off to one end. :smile:
I see. You mean the following, right?
[tex] \mathrm{trace}[<br /> (B^{-1}A)(X^TX)^{-1}(B^{-1}A)^T (XX^T) - <br /> (B^{-1}A)(Y^TY)^{-1}(B^{-1}A)^T (YY^T)<br /> ][/tex]
I would like to factor out the [tex](B^{-1}A)[/tex] terms, if possible. (Thanks!)
No, I mean
[tex]Tr(B^{-1}A)(B^{-1}A)^T Tr(XX^T)(X^TX)^{-1} - <br /> Tr(B^{-1}A)(B^{-1}A)^T Tr(YY^T)(Y^TY)^{-1}[/tex]
tiny-tim said:
No, I mean
Hmm... somewhere I have made an error. [tex](X^TX)^{-1}[/tex] is a 3x3, so this doesn't make sense... back in a minute after I figure out my error.
In the meantime how did you introduce multiplication of traces? What property am I missing? This looks promising!
oops … I got carried away :redface: … I meant
[tex]Tr(B^{-1}A)(B^{-1}A)^T (XX^T)(X^TX)^{-1} - <br /> Tr(B^{-1}A)(B^{-1}A)^T (YY^T)(Y^TY)^{-1}[/tex]
Yeah, sorry the inverted terms should have been [tex](XX^T)^{-1}[/tex] and [tex](YY^T)^{-1}[/tex]. This would result in all of the X and Y terms canceling out in your reduction. I'm excited to learn what property allows for this step!
Even still, what allows you to go from [tex]Tr(M N M^T N^{-1})[/tex] to [tex]Tr(M M^T N N^{-1})[/tex]?
This is not just a rotation, it's a reordering, right?
** solved **
I see how you did it, for any three square **SYMMETRIC** (or anti-symmetric) matrices you can reorder at will because of these properties.
The first [tex]Tr(AB) = Tr(BA)[/tex] allows us to write [tex]Tr(ABC) = Tr(BCA)[/tex] and the like.
The second is [tex]Tr(A) = Tr(A^T)[/tex].
With these we can permute any three square **SYMMETRIC** (or anti-symmetric) matrices. Here is a proof:
[tex]Tr(ABC) = Tr(A^T B^T C^T) = Tr((CBA)^T) = Tr(CBA) = Tr(ACB) = Tr(BAC)[/tex]
Where the last two steps are just an application of the first property.
So, we can say [tex]A= MN[/tex], [tex]B=M^T[/tex] and [tex]C=N^{-1}[/tex] which allows us to get the result you indicate.
Thank you very much, you have solved by problem!
As a side note X and Y are not invertible, but using the pseudoinverse allows me to approximate the least squares solution that I am after.
Thanks, I hope to give back a bit to the forum in the future.
GeoffO said:
I see how you did it, for any three square matrices you can reorder at will because of these properties.
With these we can permute any three square matrices. Here is a proof:
That's it! :biggrin:
Except that I think it only works for three symmetric and/or anti-symmetric square matrices, because of the step Tr(ABC) = Tr(AT BT CT) …
which is ok in this case because XXT is symmetric. :wink:
Good point... It's careful surgery. I'll have to double check, not everything here is symmetrical, so being sure to associate carefully is very important.
(I edited the post above lest I confuse any future reader.)
You can put and/or anti-symmetric in also, even for an odd number …
if A ad C are symmetric and B is anti-symmetric, then ABC is anti-symmetric, so you get a -1 for BT and for (ABC)T, so it's still +1 in the end. :smile:
EDIT: oooh no, that's rubbish … if A and B are both symmetric, then AB needn't be, although AB + BA will be … and if A is symmetric and B is anti-symmetric, then AB needn't be anti-symmetric, although AB - BA will be.
But the traces still work for a symmetric A and C and an anti-symmetric B …
Tr(ABC) = -Tr(BAC)
though not for three symmetric and one anti-symmetric …
Tr(ABCD) = -Tr(BADC), not (BACD)
And B-1A isn't symmetric or anti-symmetric anyway, so I think it's back to square one … :frown:​
