How can I solve a linear equation with multiple variables in MATLAB?
  • Level: Graduate
  • Thread starter Ramona79
Ramona79
Hello everyone,
I have a question:
I want to solve and plot the following function with Gauss-Chebyshev quadrature using Mathematica code:
$$F(t_k)=\frac{1}{N}\sum_{i=1}^N\left[\sum_{j=1}^m a_jT_j(s_i)\right]\frac{1}{s_i-t_k}$$
wehre
$$s_i=\cos (\pi \frac{2i-1}{2N})\quad \quad i=1...N$$
$$t_k=\cos (\pi \frac{k}{N})\quad \quad i=1...N-1$$
on a quick answer I am very grateful
thank you
F(t)=\int_ \! (\frac{1}{\sqrt{1-s^{2} } } \frac{Phi(s)}{t-s} ) \, ds
(integrals are from -1 to +1)
this equation may be solved by the Gauss-Chebyshev integration formulae:
assume that Phi(s) can be appoximated by the fallowing truncated series:
Phi(s)= \sum\limits_{j=1}^m a_{j}T_{j}(s)
so that the integral now reads
\sum\limits_{j=1}^m a_{j} \int_ \! (\frac{1}{\sqrt{1-s^{2} } } )(\frac{T_{j}(s) }{t-s} ) \, ds |t|<1
and my task is to evaluate the unknown coefficients a_{j} . The integral may be evaluated through the relation :
for j=0 :
\int_\! (\frac{1}{\sqrt{1-s^{2} } } )(\frac{T_{j}(s) }{t-s} ) \, ds = 0
for j>0 :
\int_ \! (\frac{1}{\sqrt{1-s^{2} } } )(\frac{T_{j}(s) }{t-s} ) \, ds = U_{j-1}(t)
so that
F(t)=\sum\limits_{j=1}^m a_{j} U_{j-1}(t)
we next note the fallowing relation :
for j=0
\frac{1}{N}\sum\limits_{i=1}^N \frac{T_{j}(s_{i}) }{s_{i}-t_{k}) } = 0
for 0<j<N :
\frac{1}{N}\sum\limits_{i=1}^N \frac{T_{j}(s_{i}) }{s_{i}-t_{k}) } = U_{j-1}(t_{k} )
where the points are the N roots of T_{N}(s) and the points t_{k} are the N-1 roots of U_{N-1}(t) .
It follows that
F(t_{k})=\sum\limits_{j=1}^m a_{j} U_{j-1}(t_{k})=\frac{\pi }{N} \sum\limits_{i=1}^N [ \sum\limits_{j=1}^m a_{j} T_{j}(s_{i}) ] \frac{1}{s_{i} -t_{k} } = \frac{\pi }{N} \sum\limits_{i=1}^N \frac{Phi(s_{i} )}{s_{i} -t_{k} }
where the integration points are:
s_{i} = \cos(\pi \frac{2i-1}{2N}) i=1...N
t_{k} = \cos(\pi \frac{k}{N}) i=1...N-1
the weights (\frac{\pi }{N} ) .
für das Gleichungssystem mit mehreren variablen
F(t_{k})=\sum\limits_{j=1}^m a_{j} U_{j-1}(t_{k}).
wo
F(t_{k}) und U_{j-1}(t_{k}) bekannt
und
a_{j} unbekannt.
wie kann ich bitte dieses Gleichungssystem
a_{j} = U_{j-1}(t_{k}) \ F(t_{k})
in MatLAB lösen.
mir fehlt Code.
F(t)=∫([itex]\frac{1}{\sqrt{1-s^2}}(\frac{\phi(s)}{t-s})ds[/itex]
[itex]\phi(s) = Ʃ^{m}_{j=1} a_{j} T_{j}(s)[/itex]
Ʃ[itex]^{m}_{j=1}[/itex] [itex]a_{j}[/itex]∫([itex]\frac{1}{\sqrt{1-s^2}}(\frac{T_{j}(s)}{t-s})ds[/itex] ; -1<t<+1
and my task is to evaluate the unknown coefficients [itex]a_{j}[/itex] . The integral may be evaluated through the relation :
for j=0 :
∫([itex]\frac{1}{\sqrt{1-s^2}}(\frac{T_{j}(s)}{t-s})ds[/itex] = 0
for j>0 :
∫([itex]\frac{1}{\sqrt{1-s^2}}(\frac{T_{j}(s)}{t-s})ds[/itex] = [itex]U_{j-1}(t)[/itex]
so that
F(t)=[itex]\sum^{m}_{j=1}[/itex] [itex]a_{j}[/itex] [itex]U_{j-1}(t)[/itex]
for j=0
[itex]\frac{1}{N}[/itex] [itex]\Sigma^{i=1}_{N}[/itex] ([itex]\frac{T_{j}(s_{i})}{t_{k}-s_{i}}[/itex]) = 0
for 0<j<N :
[itex]\frac{1}{N}[/itex] [itex]\Sigma^{i=1}_{N}[/itex] ([itex]\frac{T_{j}(s_{i})}{t_{k}-s_{i}}[/itex]) = [itex]U_{j-1}(t)[/itex]
where the points [itex]s_{i}[/itex] are the N roots of [itex]T_{N}(s)[/itex] and the points [itex]t_{k}[/itex] are the N-1 roots of [itex]U_{N-1}(t)[/itex] . It follows that
F([itex]t_{k}[/itex]) = [itex]\sum^{m}_{j=1}[/itex] [itex]a_{j}[/itex] [itex]U_{j-1}(t_{k})[/itex] = [itex]\frac{\pi}{N} Ʃ^{N}_{i=1} [\Sigma^{m}_{j=1} a_{j} T_{j}(s_{i}) ]\frac{1}{s_{i}-t_{k}} = \frac{\pi}{N}\Sigma^{N}_{i=1} \frac{\phi (s_{i})}{s_{i}-t_{k}}[/itex]
[itex]s_{i} = cos(\pi \frac{2i-1}{2N})[/itex] i=1...N
[itex]t_{k} = cos(\pi \frac{k}{N})[/itex] k=1...N-1
the weights ([itex]\frac{\pi}{N}[/itex])
Note that the integration has been reduced to the sum and weights ([itex]\frac{\pi}{N}[/itex]) and the integration points [itex]s_{i}[/itex] are the same as used as in the standard Gaussian quadrature formula.
Let's have a look at :
We assume that F([itex]t_{k}[/itex]) and [itex]U_{j-1}(t_{k})[/itex] are given. That leads to m equations in case there are m different [itex]t_{k}[/itex]. It's our task to evaluate the unknown coefficients [itex]a_{j}[/itex].
Therefor i must solve a linear equation m multiple variables ( the unknown coefficients [itex]a_{j}[/itex] ) in MatLAB .
can you help me to solve it in MatLAB.
i need a code in matlab.
