How can I solve a separable differential equation for an initial value problem?
8 replies · 4K views · last reply
cwbullivant
Solve the initial value problem:
dx/dt = x(2-x) x(0) = 1
Problem statement.
Based on the format, I attempted to solve the problem as a separable differential equation:
∫dx/(x[2-x]) = ∫dt
Evaluating to:
(ln|x|)/2 - (ln|2 - x|)/2 + C = t + C
Simplifying
ln|x| - ln|2 - x| + 2C = 2t + 2C
Cancelling the constant
ln|x| - ln|2 - x| = 2t
Removing the logs
x - (2 - x) = e^2t
Simplifying further
2x - 2 = e^2t
And finally solving for x:
(e^2t)/2 + 1
Which gives me a function, but for t = 0, x(0) = 3/2, not 1.
Should I be using another technique, or did I make a mistake somewhere in the process above?
The reason you are given initial conditions so that you can evaluate the constant, so it shouldn't disappear. I didn't check the integration but instead write :$$\ln|x| - \ln|2-x| + K = 2t + 2C\,\,\,\text{and so} \ln|x| -\ln|2-x| = 2t + D$$ where D = 2C - K. Now evaluate D using initial conditions.
Attempting to evaluate using
$$ln|x| -\ln|2-x| = 2t + D$$
Returns
$$x = e^{2t+D} + 1$$
Hmmm... Perhaps resubstituting so that...
$$x = e^{2t}e^{D} + 1$$
And assuming e^D = some constant A
$$x = Ae^{2t} + 1$$
Which looks similar to the equation for radioactive decay.
But that only seems to satisfy the initial condition for A = 0, and while that does seem like a potential solution, it also implies that $$x(t) = Ae^{2t} + 1 = 1 \forall t $$ (sorry for bad formatting with the last bit, this is the first time I've ever actually used latex), which seems like it will be a problem.
Yes, that's correct.
Returns
How in the world did you get this?
$$x = Ae^{2t} + 1$$
Problem statement.
∫dx/(x[2-x]) = ∫dt
Evaluating to:
Simplifying
The two constants of integration aren't necessarily equal, so you can't cancel them like you did. You usually combine them anyway, so typically, you just include the constant on one side of the equation after integrating.
$$\int \frac{dx}{x(2-x)} = \int dt \hspace{2em} \Rightarrow \hspace{2em} \frac{1}{2}\ln \lvert x \rvert - \frac{1}{2}\ln \lvert 2-x \rvert = t+C$$
Removing the logs
x - (2 - x) = e^2t
This is wrong. ##e^{\ln a + \ln b} \ne a+b##. You need to review how to work with logarithms.
Simplifying further
2x - 2 = e^2t
(e^2t)/2 + 1
##e^{\ln a + \ln b} = ab## and ##e^{\ln a - \ln b} = \frac{a}{b}##correct?
In which case,
$$ \frac{x}{2-x} = e^{2t}e^{D} $$
Is this on the right track?
Yup. So now apply the initial condition and solve for D. Note that ##e^D## is a constant, so you can write the righthand side as ##Ke^{2t}## and solve for K instead.
Ok. So $$ \frac{x}{2-x} = e^{2t}e^{D} $$, and calling $$e^D = K$$
## \frac{x}{2-x} = Ke^{2t}##, applying initial condition x(0) = 1, t = 0
## Ke^{0} = 1 ##
Given e^0 = 1, K = 1?
You have a solution, so you don't need us to verify it for you. If your equation satisfies the initial condition and the differential equation, you're done.
