How Can I Solve These Calculus Limits Without a Calculator?
  • Thread starter Thread starter Jules18
    Limits
8 replies · 3K views
Jules18
I need to figure out these limits without using a graphing calculator:
limx-->0Sinx/(x+Tanx)
limx-->0[sqrt(x+4)-2]/x
limx-->1(x6-1)/(x10-1)
I really had no idea about this one.
Maybe there's an identity I'm forgetting about.
For this one, I multiplied the top and bottom by the conjugate of the top, which was
sqrt(x+4) + 2. But it backfired because I ended up with 0/0 as my limit again which
doesn't exist.
For this one, I used a table of values. I got the right answer, but I'm wondering if there's
any way to do it algebraically.
I would be so thankful for any help at all on these ^_^ o:)
~Jules~
doesn't exist.
~Jules~
I don't have any ideas for #1, but here are some tips for 2 and 3.
2. You had the right idea, multiplying by the conjugate. After you multiply, you should end up with only x in the numerator, which cancels with the x in the denominator.
3. I haven't worked this through, but both numerator and denominator have factors of (x - 1). Rewrite both numerator and denominator as (x - 1)* (the rest), cancel the x - 1 factors, and you should be able to evaluate the limit.
For the first one notice that [tex]\frac{sin(x)}{x + tan(x)} = \frac{sin(x)}{x(1 + \frac{tan(x)}{x})}[/tex].
[tex]\frac{tan(x)}{x} = \frac{\frac{sin(x)}{cos(x)}}{x} = \frac{sin(x)}{xcos(x)}[/tex]
So [tex]\frac{sin(x)}{x + tan(x)} = \frac{sin(x)}{x} \left \left \left \frac{1}{1 + \frac{sin(x)}{x} + \frac{1}{cos(x)} }[/tex].
You know the limit of sin(x)/x as x goes to 0, right? So pass to the limit now, using limit laws.
I messed up the last equation in my previous post. It should be:
[tex]\frac{sin(x)}{x + tan(x)} = \frac{sin(x)}{x} \left \left \left \frac{1}{1 + \frac{sin(x)}{x} \left \left \frac{1}{cos(x)} }[/tex]
Thanks guys
JG89 actually I don't know the limit of Sinx/x as x goes to 0 anymore. I'm sure I did at one time. ... what is it again?
Oookay. that's smart
it ends up being 1/2, which is the same as the answer key.
Also just to add a bit more, I believe you can use L'Hopital's Rule when you have 0/0 or infinity/infinity.
Yes, but the title of this thread is "Finding Limits (w/0 calc)".
