// VC++... grumble.
#include "stdafx.h"
# include <cstdlib>
# include <iostream>
# include <iomanip>
# include <stdio.h>
# include <math.h>
# include <cmath>
# include <string>
# include <fstream>
# include <process.h>
#include <limits>
using namespace std;
const int dim=7;
double H=0.000001;
const double c=299792458.0;
const double Pi=3.141592653589793; // Improved from 3.14159265 to full double precision
const double lp=0.0000002;
const double hbar=1.05457148*pow(10.0,-34); // Doesn't seem quite right... not as precise as stated?
const double VLargeL=20.0*H/lp;
double S2Min=0;
double x2Min=0; double xd2Min=-VLargeL;
double y2Min=0; double yd2Min=-VLargeL;
double z2Min=-VLargeL; double zd2Min=H/lp;
double S2Max=10.0;
double x2Max=VLargeL; double xd2Max=VLargeL;
double y2Max=VLargeL; double yd2Max=VLargeL;
double z2Max=0; double zd2Max=VLargeL;
double S2Range=(S2Max - S2Min); double x2Range=x2Max-x2Min; double xd2Range=xd2Max-xd2Min;
double y2Range=y2Max-y2Min; double yd2Range=yd2Max-yd2Min; double z2Range=z2Max-z2Min;
double zd2Range=zd2Max-zd2Min;
// Formward declarations
void i8_sobol ( int dim_num, long long int *seed, double quasi[ ] );
int i8_bit_lo0 ( long long int n );
inline int count_bits(long long j){
int m = 0;
while (j > 1LL) {
j <<= 2;
m += 2;
return m + (int)j;
double Integrand1(double S2, double x2, double xd2, double y2, double yd2,
double z2, double zd2)
double sumOfSquares = pow(x2 - xd2,2) + pow(y2 - yd2,2) + pow(z2 - zd2,2);
double sqrtSOS = sqrt(sumOfSquares);
double piS2 = Pi * S2;
return (1 + 4*piS2*(sqrtSOS + piS2*sumOfSquares)) /
(exp(4*piS2*sqrtSOS)* pow(2 + pow(S2,2),2) * pow(sumOfSquares,3));
int main ( void )
cout << "Define n by entering an integer please:\n";
long long int n;
cin >> n;
cout << "n = " << n <<"\n";
cout << "\n";
double r[dim];
long long int seed=0;
long double Result1=0;
long long int PercentagesShown=0;
long double OnePercent=n/100.0;
for(long long int i=0;i<n;i++)
i8_sobol(dim,&seed,r);
Result1+=Integrand1(r[0] * S2Range,x2Min + (r[1]*x2Range),xd2Min + (r[2]*xd2Range),
y2Min + (r[3]*y2Range), yd2Min + (r[4]*yd2Range),z2Min + (r[5] * z2Range),
zd2Min + (r[6] * zd2Range));
if(i>2000000*(PercentagesShown+1))
system("cls");
cout << i << " loops completed";
PercentagesShown++;
Result1=(-(c*hbar)/(4.*lp*pow(Pi,2)))*2*S2Range*x2Range*xd2Range*y2Range*yd2Range*z2Range*zd2Range*Result1/(n*pow(2*VLargeL,2));
system("cls");
cout << "Result = " << Result1 << "\n";
std::ofstream OutputFile("SQR2ndOrderFlatResults.txt", std::ios_base::out | std::ios_base::app);
OutputFile << "\n\n";
OutputFile << "2nd Order Flat\n";
OutputFile << "Very Large Length= " << VLargeL;
OutputFile << ", N = " << n;
OutputFile << ", H = " << H;
OutputFile << ", S2Max = " << S2Max;
OutputFile << "\nIntegration Result = " << Result1 << "\n";
OutputFile.close();
cout <<"\n";
cout << "Exit program? (y/n)\n";
std::string BoolStr;
cin >> BoolStr;
while(BoolStr!="y")
cout <<"\n";
cout << "User chose not to exit program.\n";
cin >> BoolStr;
int bit;
bit = 1;
while (n&1)
n >>= 1;
bit++;
return bit;
//////////////////////////////////////////////////////////////////////////////////////////////////////////void i8_sobol ( int dim_num, long long int *seed, double quasi[ ] )
# define DIM_MAX 40
# define DIM_MAX2 1111
# define LOG_MAX 62
// Here, we have commented out the definition of ATMOST, because
// in some cases, a compiler was complaining that the value of ATMOST could not
// seem to be properly stored. We only need ATMOST in order to specify MAXCOL,
// so as long as we set MAXCOL (below) to what we expect it should be, we
// may be able to get around this difficulty.
// JVB, 24 January 2006.
//static long long int atmost = 4611686018427387903;
static int dim_num_save = 0;
long long int i;
bool includ[LOG_MAX];
static bool initialized = false;
long long int j;
long long int k;
long long int l;
static long long int lastq[DIM_MAX2];
long long int m;
static long long int maxcol;
long long int newv;
static long long int poly[DIM_MAX2] =
1, 3, 7, 11, 13, 19, 25, 37, 59, 47,
61, 55, 41, 67, 97, 91, 109, 103, 115, 131,
193, 137, 145, 143, 241, 157, 185, 167, 229, 171,
213, 191, 253, 203, 211, 239, 247, 285, 369, 299,
301, 333, 351, 355, 357, 361, 391, 397, 425, 451,
463, 487, 501, 529, 539, 545, 557, 563, 601, 607,
617, 623, 631, 637, 647, 661, 675, 677, 687, 695,
701, 719, 721, 731, 757, 761, 787, 789, 799, 803,
817, 827, 847, 859, 865, 875, 877, 883, 895, 901,
911, 949, 953, 967, 971, 973, 981, 985, 995, 1001,
1019, 1033, 1051, 1063, 1069, 1125, 1135, 1153, 1163, 1221,
1239, 1255, 1267, 1279, 1293, 1305, 1315, 1329, 1341, 1347,
1367, 1387, 1413, 1423, 1431, 1441, 1479, 1509, 1527, 1531,
1555, 1557, 1573, 1591, 1603, 1615, 1627, 1657, 1663, 1673,
1717, 1729, 1747, 1759, 1789, 1815, 1821, 1825, 1849, 1863,
1869, 1877, 1881, 1891, 1917, 1933, 1939, 1969, 2011, 2035,
2041, 2053, 2071, 2091, 2093, 2119, 2147, 2149, 2161, 2171,
2189, 2197, 2207, 2217, 2225, 2255, 2257, 2273, 2279, 2283,
2293, 2317, 2323, 2341, 2345, 2363, 2365, 2373, 2377, 2385,
2395, 2419, 2421, 2431, 2435, 2447, 2475, 2477, 2489, 2503,
2521, 2533, 2551, 2561, 2567, 2579, 2581, 2601, 2633, 2657,
2669, 2681, 2687, 2693, 2705, 2717, 2727, 2731, 2739, 2741,
2773, 2783, 2793, 2799, 2801, 2811, 2819, 2825, 2833, 2867,
2879, 2881, 2891, 2905, 2911, 2917, 2927, 2941, 2951, 2955,
2963, 2965, 2991, 2999, 3005, 3017, 3035, 3037, 3047, 3053,
3083, 3085, 3097, 3103, 3159, 3169, 3179, 3187, 3205, 3209,
3223, 3227, 3229, 3251, 3263, 3271, 3277, 3283, 3285, 3299,
3305, 3319, 3331, 3343, 3357, 3367, 3373, 3393, 3399, 3413,
3417, 3427, 3439, 3441, 3475, 3487, 3497, 3515, 3517, 3529,
3543, 3547, 3553, 3559, 3573, 3589, 3613, 3617, 3623, 3627,
3635, 3641, 3655, 3659, 3669, 3679, 3697, 3707, 3709, 3713,
3731, 3743, 3747, 3771, 3791, 3805, 3827, 3833, 3851, 3865,
3889, 3895, 3933, 3947, 3949, 3957, 3971, 3985, 3991, 3995,
4007, 4013, 4021, 4045, 4051, 4069, 4073, 4179, 4201, 4219,
4221, 4249, 4305, 4331, 4359, 4383, 4387, 4411, 4431, 4439,
4449, 4459, 4485, 4531, 4569, 4575, 4621, 4663, 4669, 4711,
4723, 4735, 4793, 4801, 4811, 4879, 4893, 4897, 4921, 4927,
4941, 4977, 5017, 5027, 5033, 5127, 5169, 5175, 5199, 5213,
5223, 5237, 5287, 5293, 5331, 5391, 5405, 5453, 5523, 5573,
5591, 5597, 5611, 5641, 5703, 5717, 5721, 5797, 5821, 5909,
5913, 5955, 5957, 6005, 6025, 6061, 6067, 6079, 6081, 6231,
6237, 6289, 6295, 6329, 6383, 6427, 6453, 6465, 6501, 6523,
6539, 6577, 6589, 6601, 6607, 6631, 6683, 6699, 6707, 6761,
6795, 6865, 6881, 6901, 6923, 6931, 6943, 6999, 7057, 7079,
7103, 7105, 7123, 7173, 7185, 7191, 7207, 7245, 7303, 7327,
7333, 7355, 7365, 7369, 7375, 7411, 7431, 7459, 7491, 7505,
7515, 7541, 7557, 7561, 7701, 7705, 7727, 7749, 7761, 7783,
7795, 7823, 7907, 7953, 7963, 7975, 8049, 8089, 8123, 8125,
8137, 8219, 8231, 8245, 8275, 8293, 8303, 8331, 8333, 8351,
8357, 8367, 8379, 8381, 8387, 8393, 8417, 8435, 8461, 8469,
8489, 8495, 8507, 8515, 8551, 8555, 8569, 8585, 8599, 8605,
8639, 8641, 8647, 8653, 8671, 8675, 8689, 8699, 8729, 8741,
8759, 8765, 8771, 8795, 8797, 8825, 8831, 8841, 8855, 8859,
8883, 8895, 8909, 8943, 8951, 8955, 8965, 8999, 9003, 9031,
9045, 9049, 9071, 9073, 9085, 9095, 9101, 9109, 9123, 9129,
9137, 9143, 9147, 9185, 9197, 9209, 9227, 9235, 9247, 9253,
9257, 9277, 9297, 9303, 9313, 9325, 9343, 9347, 9371, 9373,
9397, 9407, 9409, 9415, 9419, 9443, 9481, 9495, 9501, 9505,
9517, 9529, 9555, 9557, 9571, 9585, 9591, 9607, 9611, 9621,
9625, 9631, 9647, 9661, 9669, 9679, 9687, 9707, 9731, 9733,
9745, 9773, 9791, 9803, 9811, 9817, 9833, 9847, 9851, 9863,
9875, 9881, 9905, 9911, 9917, 9923, 9963, 9973,10003,10025,
10043,10063,10071,10077,10091,10099,10105,10115,10129,10145,
10169,10183,10187,10207,10223,10225,10247,10265,10271,10275,
10289,10299,10301,10309,10343,10357,10373,10411,10413,10431,
10445,10453,10463,10467,10473,10491,10505,10511,10513,10523,
10539,10549,10559,10561,10571,10581,10615,10621,10625,10643,
10655,10671,10679,10685,10691,10711,10739,10741,10755,10767,
10781,10785,10803,10805,10829,10857,10863,10865,10875,10877,
10917,10921,10929,10949,10967,10971,10987,10995,11009,11029,
11043,11045,11055,11063,11075,11081,11117,11135,11141,11159,
11163,11181,11187,11225,11237,11261,11279,11297,11307,11309,
11327,11329,11341,11377,11403,11405,11413,11427,11439,11453,
11461,11473,11479,11489,11495,11499,11533,11545,11561,11567,
11575,11579,11589,11611,11623,11637,11657,11663,11687,11691,
11701,11747,11761,11773,11783,11795,11797,11817,11849,11855,
11867,11869,11873,11883,11919,11921,11927,11933,11947,11955,
11961,11999,12027,12029,12037,12041,12049,12055,12095,12097,
12107,12109,12121,12127,12133,12137,12181,12197,12207,12209,
12239,12253,12263,12269,12277,12287,12295,12309,12313,12335,
12361,12367,12391,12409,12415,12433,12449,12469,12479,12481,
12499,12505,12517,12527,12549,12559,12597,12615,12621,12639,
12643,12657,12667,12707,12713,12727,12741,12745,12763,12769,
12779,12781,12787,12799,12809,12815,12829,12839,12857,12875,
12883,12889,12901,12929,12947,12953,12959,12969,12983,12987,
12995,13015,13019,13031,13063,13077,13103,13137,13149,13173,
13207,13211,13227,13241,13249,13255,13269,13283,13285,13303,
13307,13321,13339,13351,13377,13389,13407,13417,13431,13435,
13447,13459,13465,13477,13501,13513,13531,13543,13561,13581,
13599,13605,13617,13623,13637,13647,13661,13677,13683,13695,
13725,13729,13753,13773,13781,13785,13795,13801,13807,13825,
13835,13855,13861,13871,13883,13897,13905,13915,13939,13941,
13969,13979,13981,13997,14027,14035,14037,14051,14063,14085,
14095,14107,14113,14125,14137,14145,14151,14163,14193,14199,
14219,14229,14233,14243,14277,14287,14289,14295,14301,14305,
14323,14339,14341,14359,14365,14375,14387,14411,14425,14441,
14449,14499,14513,14523,14537,14543,14561,14579,14585,14593,
14599,14603,14611,14641,14671,14695,14701,14723,14725,14743,
14753,14759,14765,14795,14797,14803,14831,14839,14845,14855,
14889,14895,14909,14929,14941,14945,14951,14963,14965,14985,
15033,15039,15053,15059,15061,15071,15077,15081,15099,15121,
15147,15149,15157,15167,15187,15193,15203,15205,15215,15217,
15223,15243,15257,15269,15273,15287,15291,15313,15335,15347,
15359,15373,15379,15381,15391,15395,15397,15419,15439,15453,
15469,15491,15503,15517,15527,15531,15545,15559,15593,15611,
15613,15619,15639,15643,15649,15661,15667,15669,15681,15693,
15717,15721,15741,15745,15765,15793,15799,15811,15825,15835,
15847,15851,15865,15877,15881,15887,15899,15915,15935,15937,
15955,15973,15977,16011,16035,16061,16069,16087,16093,16097,
16121,16141,16153,16159,16165,16183,16189,16195,16197,16201,
16209,16215,16225,16259,16265,16273,16299,16309,16355,16375,
16381 };
static double recipd;
static long long int seed_save = 0;
long long int seed_temp;
static long long int v[DIM_MAX2][LOG_MAX];
if ( !initialized || dim_num != dim_num_save )
initialized = true;
for ( i = 0; i < DIM_MAX2; i++ )
for ( j = 0; j < LOG_MAX; j++ )
v[i][j] = 0;
// Initialize (part of) V.
// Warning: long initialization table snipped here! Add back in before compiling.
cout << "Add in initialization table and recompile.\n";
return 1;
// Check parameters.
if ( dim_num < 2 || DIM_MAX2 < dim_num )
cout << "\n";
cout << "I8_SOBOL - Fatal error!\n";
cout << " The spatial dimension DIM_NUM should satisfy:\n";
cout << " 2 <= DIM_NUM <= " << DIM_MAX2 << "\n";
cout << " But this input value is DIM_NUM = " << dim_num << "\n";
exit ( 1 );
dim_num_save = dim_num;
// Find the number of bits in ATMOST.
// Here, we have short-circuited the computation of MAXCOL from ATMOST, because
// so if we know what the answer should be we can try to get it this way!
// maxcol = i8_bit_hi1 ( atmost );
maxcol = 62;
// Initialize row 1 of V.
for ( j = 0; j < maxcol; j++ )
v[0][j] = 1;
// Initialize the remaining rows of V.
for ( i = 1; i < dim_num; i++ )
// The bit pattern of the integer POLY(I) gives the form
// of polynomial I.
// Find the degree of polynomial I from binary encoding.
j = poly[i];
m = count_bits(j);
// We expand this bit pattern to separate components
// of the logical array INCLUD.
for ( k = m-1; 0 <= k; k-- )
includ[k] = j & 1;
j >>= 1;
// Calculate the remaining elements of row I as explained
// in Bratley and Fox, section 2.
// Some tricky indexing here. Did I change it correctly?
for ( j = m; j < maxcol; j++ )
newv = v[i][j-m];
l = 1;
for ( k = 0; k < m; k++ )
l <<= 1;
if ( includ[k] )
newv ^= l * v[i][j-k-1];
v[i][j] = newv;
// Multiply columns of V by appropriate power of 2.
l = 0;
for ( j = maxcol - 2; 0 <= j; j-- )
for (++l, i = 0; i < dim_num; i++ )
v[i][j] <<= l;
// RECIPD is 1/(common denominator of the elements in V).
recipd = 1.0E+00 / ( ( double ) ( 2 * l ) ); // Faster way of doing this: direct math on exponent field
if ( *seed < 0 )
*seed = 0;
if ( *seed == 0 )
l = 1;
for ( i = 0; i < dim_num; i++ )
lastq[i] = 0;
else if ( *seed == seed_save + 1 )
l = i8_bit_lo0 ( *seed );
else if ( *seed <= seed_save )
seed_save = 0;
l = 1;
lastq[i] = 0;
for ( seed_temp = seed_save; seed_temp <= (*seed)-1; seed_temp++ )
l = i8_bit_lo0 ( seed_temp );
lastq[i] ^= v[i][l-1];
else if ( seed_save+1 < *seed )
for ( seed_temp = seed_save+1; seed_temp < *seed; seed_temp++ )
// Check that the user is not calling too many times!
if ( maxcol < l )
cout << "\n";
cout << " The value of SEED seems to be too large!\n";
cout << " SEED = " << *seed << "\n";
cout << " MAXCOL = " << maxcol << "\n";
cout << " L = " << l << "\n";
exit ( 2 );
// Calculate the new components of QUASI.
// The caret indicates the bitwise exclusive OR.
quasi[i] = ( ( double ) lastq[i] ) * recipd;
seed_save = *seed;
*seed = *seed + 1;
return;
# undef DIM_MAX
# undef DIM_MAX2
# undef LOG_MAX
