How can link external libraries from the cmd?
To link external libraries like GLEW and GLFW in a C++ project using Vim and the MinGW compiler, it is essential to utilize a Makefile. The Makefile allows for the specification of library dependencies and compilation commands. The basic structure involves defining targets and linking commands, such as using `g++` with the `-L` option to specify the library directory and `-l` to link against the libraries. For example, `g++ -o output main.o -L. -lglfw3 -lopengl32 -lglu32 -lgdi32` compiles the program while linking the necessary libraries. If libraries are located in non-standard directories, their paths should be provided directly. Learning to write a Makefile can streamline the process, especially for multi-file projects. Resources like the GNU Make documentation can provide guidance on creating effective Makefiles.
Buffu
I am familiar with linking external libraries in IDE like Eclipse, Netbeans etc. But in my college they use use vim for programming on Linux. To learn more about vim editor I installed it on my home computer.I can compile basic C++ programs on it with one or two .cpp/.h files. I think it is awesome for C++ programming and now I want to move my OpenGL project from Visual Studios to vim. Before I did anything I released I don't know how to link external libraries (GLEW and GLFW) from cmd.
Please tell how can I link external libraries from cmd, if possible from vim (some vim script or plugins) ?
I am using Mingw compiler.
This is my current vimrc file,
Code:
set nocompatible
source $VIMRUNTIME/vimrc_example.vim
source $VIMRUNTIME/mswin.vim
behave mswin
set diffexpr=MyDiff()
function MyDiff()
  let opt = '-a --binary '
  if &diffopt =~ 'icase' | let opt = opt . '-i ' | endif
  if &diffopt =~ 'iwhite' | let opt = opt . '-b ' | endif
  let arg1 = v:fname_in
  if arg1 =~ ' ' | let arg1 = '"' . arg1 . '"' | endif
  let arg2 = v:fname_new
  if arg2 =~ ' ' | let arg2 = '"' . arg2 . '"' | endif
  let arg3 = v:fname_out
  if arg3 =~ ' ' | let arg3 = '"' . arg3 . '"' | endif
  let eq = ''
  if $VIMRUNTIME =~ ' '
    if &sh =~ '\<cmd'
      let cmd = '""' . $VIMRUNTIME . '\diff"'
      let eq = '"'
    else
      let cmd = substitute($VIMRUNTIME, ' ', '" ', '') . '\diff"'
    endif
  else
    let cmd = $VIMRUNTIME . '\diff'
  endif
  silent execute '!' . cmd . ' ' . opt . arg1 . ' ' . arg2 . ' > ' . arg3 . eq
endfunction
:cd E:\C++\
:set tabstop=4
:set shiftwidth=4
:set expandtab
call plug#begin('~/vimfiles/bundle')
Plug '[PLAIN]https://github.com/WolfgangMehner/vim-plugins.git'[/PLAIN]
Plug '[PLAIN]https://github.com/vim-syntastic/syntastic.git'[/PLAIN]
Plug '[PLAIN]https://github.com/scrooloose/nerdtree.git'[/PLAIN]
Plug '[PLAIN]https://github.com/ervandew/supertab.git'[/PLAIN]
call plug#end()
Computer science news on Phys.org
Does your project use make files? If so that's where you would add the library dependencies as I think vim just calls the mingw make command. If not it might be a good time to start using them. They are especially useful for multi-module ie multi-file programs.
This website has a discussion on how to configure vim so that it can call the mingw32-make.exe command on your system:
http://stackoverflow.com/questions/2423478/how-to-use-mingw-make-with-vim-on-windows
Likes Buffu
I know make files can be executed directly but I have no idea how to write a make file neither I can find any good resource on make files.
I don't want to spend much time on make files, I just want my project to work.
I think the best source for learning about Make is the documentation of Gnu Make at https://www.gnu.org/software/make/manual/make.html .
Start by reading chapters 3 and 4. Most of your make files will look practically the same. So, if you learn write a simple Make file you can then easily extend it.
Likes Buffu
Ok I think I got how to make and use make files.
But I still need g++ command for linking libraries because that is what I have to write in recipe part of make.
Code:
main.o : glew.h glfw.g
      g++ #linking command# main.cpp
Please help me out.
How you link the library depends on where it's located. If it's in a file named foo.a (.a being the standard extension for libraries on many/most Unix-ish systems), in your current directory (folder) along with main.cpp:
g++ main.cpp foo.a
compiles main.cpp and links the resulting object code with the library foo.a. If foo.a is in some other folder, give the path to it:
g++ main.cpp /path/to/foo.a
Special case: if the library is in one of your system's "standard" directories for libraries (maybe /usr/lib, /usr/local/lib, etc.) and has a name beginning with 'lib', e.g. libfoo.a, then you can use
g++ main.cpp -lfoo
which is equivalent to
g++ main.cpp /usr/lib/libfoo.a (or maybe /usr/local/lib/libfoo.a, or in some other standard directory)
[added] I've never used Mingw so I don't know whether it uses .a or some other extension for libraries.
Likes Buffu
g++ main.cpp foo.a
g++ main.cpp -lfoo
Thanks it does work now.
Code:
pig : main.o
    g++ -o pig.exe main.o -L. -lglfw3 -lopengl32 -lglu32 -lgdi32
main.o : E:\DoesWork\glfw3.h
    g++ -c main.cpp -L. -lglfw3 -lopengl32 -lglu32 -lgdi32
clean :
    rm main.o edit.exe
This is the make file if somebody needed help with this in future.(low quality make file).
Thanks for posting your solution! The "-L." adds the current directory to the list of "standard library directories" and let's you put the required libraries there, provided that their names begin with "lib" as expected.
Likes Buffu
Thanks I forgot to mention that.
