How Can Phasors Represent the Function g(t) in Complex Form?
31 replies · 4K views · last reply
Dusty912
Given a function g(t)=acosωt + bsinωt, where a and b are constants, show that g(t) is the real part of the complex function: keiΦeiωt for some k and Φ
Remark: the complex expression keiΦ is called a phasor. If we know that g(t) has the form kcos(ωt+Φ) then we need know only the constants k and Φ-the amplitude and the phase- to know the function g. Hence we can use the phasor keiΦ as a notation for the function g(t)=keiΦeiωt
Euler's formula eiωt= cosωt +isinωt
Not really sure where to start here except for expanding using euler;s as the first step. any help would be greatly appreciated.
So do that, for both exponential terms.
okay so then I get k(cosΦt +isinΦt)(cosωt+isinωt)
but what should this be equal too?
How do you get φt terms?
umm I'm not sure. I didn't know we would be using that symbol. What does φ represent?
It is a constant. You need to find the values of k and φ which make the real part match g().
I think perhaps you did not understand my question. In your post #3, you had terms like sin(φt). I don't understand how you got those. Please post your working.
Dusty912 said:
no φ
Looks like a font issue. Are you saying Φ and φ look very different to you? In the font that comes up on my iPad they are almost the same, so I may have used the wrong one.
yes they look very different. I think that's where the confusion was.
Ok, so please reread my posts with that in mind.
But in regards to your earlier quastion. I used euler's formula to obtain sin(Φt) eiΦt=cosΦt +isin(Φt)
right?
right?
According to your initial post, it is eiφ, not eiφt.
Dusty912 said:
oops, my mistake, than diregard the t's
Ok. So multiply out the corrected version of the expression in your post #3.
kcosΦcosωt +kisinΦcosωt + kisinωtcosΦ -ksinΦsinωt
Right. What part of that is relevant in this question?
The part that does not have i's in them? the real parts
Yes. What values of k and φ make the real part match g?
i'm not sure I want to say 0 or π/2 for Φ but that doesn't seem right.
Remember that t is a variable, so the functions are to produce the same value for every value of t. This means that the cos(ωt) term must look the sameinboth functions, and the sin term must look the same too. That givesyou two equations for the coefficients.
well if I equate this to g(t)=acosωt+bsinωt than I would get Φ=π/2 and b for the sin's and Φ=0 and a for the cos's or is my algebra wrong on this?
ωT)
Compare the expression for g with the real part of the complex expression in post #23. Look at the two cos(ωt) terms. If they are to be exactly the same, they must have the same coefficient. That gives you an equation relating a and b to k and φ. Do the same with the two sin(ωt) terms.
