How Can Point Particles Have Cross Sections?
  • Context: High School
  • Thread starter Thread starter Nathan Warford
    Cross Particles Point
36 replies · 5K views
Nathan Warford
This is a topic that I have tried researching and I have not been able to find any meaningful information about it. The standard model of particle physics describes particles as point-like objects with no spatial extent. What I can't wrap my head around is how true point particles can participate in interactions. If particles did not have cross-sections, then they would simply fly past one another and not interact at all (i.e. the probability of an interaction would be infinitesimal). Is there any explanation as to how point particles like electrons or quarks or neutrinos can have non-zero cross sections?
I don't know if standard particle physics is enough to answer this question. If concepts relating to QFT or other areas of physics are required, then the Mentors are free to move this thread to the appropriate forum.
Counter examples: Gravity and electrostatics. Objects can interact with each other without "touching". Certainly the Earth does not need to hit the Sun in order to keep its orbit.
Gravity doesn't really apply because elementary particles are so light that gravity has a negligible affect on them. Gravity is better explained by General Relativity anyway.
As for electrostatics, the way I understand the phenomenon is that charged particles like electrons exchange virtual photons. At the subatomic level, emission and absorption of photons are the actual interactions that take place. At least that's the sense that I get based on my limited experience with Feynman Diagrams.
I am not talking about elementary particles here. It was an example of how things could interact without "touching".
Virtual photons are not small balls that are thrown between electrons. The cross sections you are talking about are e+e- cross sections.
Still, I would like to keep this discussion in the realm of particle physics. If gravity turns out to actually be important to the discussion, maybe the thread should be moved to the Beyond the Standard Model forum?
Don't assume to know what I'm talking about. I'm asking about all types of particle interactions. These include electrostatic repulsion, electrostatic attraction, beta decay, electron capture, strong nuclear interactions, particle-antiparticle production, particle-antiparticle annihilation, basically any interaction that can take place between elementary particles. The interactions I'm interested in all seem to be quantum mechanical in nature, so maybe the thread should be moved to the Quantum Physics forum?
I was not a physics major, so I probably don't understand electrostatic interactions correctly. Could you explain to me how particle interactions actually work?
Also my initial question has not been answered yet. How are point particles able to interact even though they don't have finite spatial extent?
Why should that even be necessary? I could ask "how are particles able to interact even though they aren't blue?" or "how are particles able to interact even though they aren't chocolate flavored." Do you have any better reason than "It seems that they should"?
You are missing the point of people trying to GUIDE you to the answer. So obviously, a more direct approach is necessary.
Take for example, electrons. They are, as far as we know, point particles. However, they also have CHARGE, and when something has charge, they give off this thing called "electric field". When another charge gets close, this charge senses the electric field of the first charge. So already, these two charges are INTERACTING with one another even at a distance.
This interaction is what causes point particles to affect each other. It has nothing to do with physical dimension. This is the point that people were trying to get across to you by using gravitational field as an example that you might be familiar with. Obviously, you didn't get the connection.
Zz.
Insulting people who are trying to help you and guide you to an answer is not a very constructive approach to take. Gravity might not be what you are trying to understand but the underlying principles are exactly the same. However, as you seem to be quite stubborn in not wanting to think about what people tell you, I am out of this conversation.
One should think of "cross section" as one of those terms that physicists have adopted from common language and applied to a situation that is only vaguely reminiscent of their original use.
Shoot a beam of something (call them "particles" for convenience) through a thin target of thickness Δx, containing n "target particles" per unit volume (the "number density" of target particles). If you start with Nin beam particles, Nout of them emerge on the other side, the difference ΔN = Nin - Nout having been scattered or absorbed. It turns out that ΔN is proportional to Nin, Δx and n. We can turn this into an equation by inserting a proportionality constant σ:
ΔN = NinσnΔx
Analyzing the units of the other quantities shows that σ must have units of area, which leads to the term "cross section". Many textbooks have diagrams showing the target particles as acting like little circular targets with area σ, but you should consider this as only a heuristic visualization device. Some beam particles that pass through one of the "target circles" do not interact at all, and some that pass outside all the "target circles" do interact.
Unless I have completely misunderstood something, even a point interaction where the potential energy of a two particle system is a Dirac delta function ##\delta^3 (\mathbf{r}_1 - \mathbf{r}_2)##, can have a nonzero scattering cross section. So in other words, even particles of zero size and zero interaction range can "collide" with each other in quantum mechanical systems.
You're right. I should have chosen my words differently. I apologize.
The thing is that there can also be interactions involving particles that don't have electric charge. A photon doesn't have an electric charge, but it can still be absorbed or scattered by matter particles like electrons. An electron can also interact with the uncharged neutrino to create a W boson. So interaction through electric fields can't be the whole story.
ΔN = NinσnΔx
This is a much more useful response. Thank you. I guess I'm just trying to understand the basic interactions between the beam particles and the target particles, whatever types of particles they may be.
This is also a useful response. "Dirac delta function" sounds interesting. Give me some time to look it up.
You're right. I should have chosen my words differently. I apologize.The thing is that there can also be interactions involving particles that don't have electric charge. A photon doesn't have an electric charge, but it can still be absorbed or scattered by matter particles like electrons. An electron can also interact with the uncharged neutrino to create a W boson. So interaction through electric fields can't be the whole story.
Again, you are missing the point!. I used electrons and charge and electric field as an example of how interaction can take place at a distance without things "touching", meaning the physical "size" of something doesn't matter! This means that for other particles, the mechanism of interaction can be anything - EM interaction, weak interaction, strong interaction, gravity, etc... etc.. Heck, in a superconductor, two electrons even exchange virtual phonons (not photons) to cause them to "attract"!
You are looking at the trees without realizing that we are describing the forest. We are trying to explain the GENERAL concept via using a specific example, but you seem to not be able to get past the specific example and not seeing the general concept! If this still doesn't make the connection for you, then I give up.
BTW, light or photons have electric field and interacts with charge particles. It is how we accelerate charge particles in particle accelerators, and why it can interact with electric/magnetic dipoles.
Zz.
Let me ask again - I could ask "how are particles able to interact even though they aren't blue?" or "how are particles able to interact even though they aren't chocolate flavored." Do you have any better reason than "It seems that they should"? Note that the physical extent of a particle does not in general appear in the QM calculation of scattering amplitudes; for example, the total scattering cross-sections of two electrons and two grapefruits carrying one extra electron each are the same - and they are both infinite, as it happens.
I read that and thought to myself - yes, that's true. But I thought again. What does the extent of a particle mean? Their electric presence is a Potential Well so the 'electric size' is a bit meaningless. Any 'size' could be assessed by its likely scattering collision with a neutral particle (neutron?). Size would only be a valid description for an unbound electron because, in a bound state, we would be stuck with a probability density function, which would be of atomic size.
I looked at this wiki link which presents an argument based on "electrostatic self energy" but isn't that making a lot of assumptions?
I can turn around and ask you by what you mean as "... the extent of a particle..."
We know that if an electron has any "internal structure", (i.e. it has a non-zero size) then one of the possible outcome of that is the presence of an electric dipole moment when it is in a high gradient field. I'm sure you are well aware of at least a couple of different recent experiments that could not detect such effect.
Zz.
Virtual photons are no localized particles. Even real photons are not localized in a naive sense. You cannot even define a position observable for them! Virtual photons are rather symbolizing the electromagnetic interaction and are depicted as internal lines of Feynman diagrams. Feynman diagrams, however, are not pictures of "what's really going on" but very clever notations of quite complicated mathematics to evaluate the only truly observable facts about collisions of particles, i.e., the socalled S-matrix elements, which are used to calculate cross sections that can be measured in experiment and compared to the predictions of the calculations.
Regarding your question, I find this text "Are electrons pointlike/structureless?" by Arnold Neumaier very helpful: https://arnold-neumaier.at/physfaq/topics/pointlike.html
I don't know, where you got this wrong idea from. The Standard Model of particle physics is entirely based on relativistic quantum field theory, and describes the strong and the electro-weak interaction in terms of local gauge symmetry based on the group ##\text{SU}(3)_{\text{color}} \times \text{SU}(2)_{\text{WISO}} \times \text{U}(1)_{\text{Y}}##, which is higgsed to ##\text{SU}(3)_{\text{color}} \times \text{U}(1)_{\text{em}}##.
The measurable quantities are defined in terms of abstract correlation functions that define ##S##-matrix elements, i.e., probability amplitudes for transitions between asymptotically free in-states (usually two particles in a scattering experiment) to aysmptotically free out-states (any kind of many-particle state). This is for vacuum quantum field theory describing scattering experiments with a few particles (although the final state of pp collisions at the LHC can have very many particles in the final state, indeed).
Another application is relativistic many-body physics, as needed in the description of the hot and dense medium created in heavy-ion collisions (done also at the LHC, where Pb-Pb collisions at the highest so far available energies are smashed together creating a hot and dense fireball, most likely forming a quark-gluon plasma for a few fm/c). Also here the observables finally are asymptotic free states, i.e., "particles in a detector".
A mental picture of elementary particles, particularly in the relativistic realm, as microscopic billard balls is flawed! The only chance to really understand, what elementary particles are, according to the up-to-date state of research is to get used to the quite abstract formulation as a relativistic QFT. Popular-science media usually do not give an adequate description.
Fair enough question. I was referring to the "cross section" of the thread title. The dimension / size / cross section that you refer to in your reply is only in terms of a sort of derived quantity and that's ok with me but, as the above post says:
So the "cross section" is a quantity on its own and it cannot be thought of in the form of two arrows and a number beside a picture of an electron, equivalent to the height of an IKEA bookcase.
Suppose you modeled electrons as an object of radius r and of constant charge density. You could calculate electron-electron scattering as a function of momentum transferred and you will discover that it's a function of r. From there you compare with scattering data and see if your data supports r > 0. If not, you set a limit on how small r could have been and you would have see it. That's your limit.
In real life, things are a little different because what I wrote is computationally horrid. But that's the general idea.
And grammatically horrid.
I suppose that, at some point, applying the normal inverse square law forces to predict the scattering pattern falls down and that will be equivalent to a 'flat bottom' to the potential well pattern. You could call that the 'size'.
Can you point to this place?
(Electron-positron cross section)
I can't fathom what the graph shows. What are the axis titles and units? In particular "mb"? I would have moaned at my students for leaving out / assuming such information - and how about a title? :smile:
Millibarns, a unit of cross section, and the x-axis is the center of mass energy in GeV.
The title was written above the image.
I didn't make the graph, and that was the nicest-looking I found with a quick search.
But you made the post and included the image. I imagine you wanted to get some message across with it. If you don't actually want to help then why bother posting?
What is the x-axis and what would the units be? kWh / Joules / Bthu?
I can see there are some peaks and an 'inverted well' shape. It may all be blindingly obvious to you but it may not be to all your readers.
Sorry to be grumpy but I am on this thread in the hope of getting to understand the subject (as well as having a friendly conversation).
GeV, see above.
The scale doesn't matter here. The main point is that the plot is full of features, but none of them looks like what you were looking for.
Your approach doesn't work at all.
mfb said:
GeV, see above.
Oh yes, I see now.
I was just trying to interpret the suggestion (?) in Post #20 from Vanadium. So how can you find or estimate the 'size' from that data in your post? Could you inject just a tad of positive into your reply? Saying how something could be done is much more useful than saying another thing just won't work. I know there are a lot of people on PF who know more than I (or even you) do in some areas but what do we post here for?
You cannot, that is the point. If electrons would have something like a classical size you could, but they do not have this.
