How Can the Weight of a Human Head be Measured?
The discussion revolves around methods for measuring the weight of a human head without resorting to extreme measures. Participants explore various techniques, accuracy considerations, and the implications of different assumptions regarding the head's characteristics.
  • Some participants suggest using a scale to weigh the head while lying on a table, although accuracy is questioned.
  • Others mention the potential for significant inaccuracies due to unknown factors, such as additional weight from bullets or other objects.
  • A few participants propose using torque balancing to measure mass, contingent on accurately locating the center of mass.
  • One participant references a method involving water displacement, assuming the density of the head is similar to that of water, while another questions the accuracy of this assumption.
  • There are suggestions to weigh the entire body in water and then calculate the head's weight based on the displacement of water, though some express skepticism about the knowns involved in this method.
  • Several humorous remarks about unconventional methods, such as chopping or soaking the head, highlight the informal nature of the discussion.
Participants express a range of opinions on the methods discussed, with no consensus on the most accurate or acceptable approach. Some methods are contested, and various assumptions about the head's characteristics lead to differing viewpoints.
Limitations include the dependence on assumptions about the head's density and mass distribution, as well as the accuracy of the proposed methods. The discussion does not resolve these uncertainties.
This discussion may be of interest to those exploring unconventional measurement techniques, physics enthusiasts, or individuals curious about human anatomy and weight measurement methods.
I_am_learning
Just in the middle of random discussion with my friend, we wondered how could the weight of a human head (the portion above neck) be measured?
Of-course without doing nasty things. (eg. chopping. :devil: )
Biology news on Phys.org
To what accuracy?
I'm afraid I can't help you. I always chop.
http://www.guardian.co.uk/notesandqueries/query/0,,-1244,00.html
That describes a few methods for approximating it although I'm not sure of the accuracy of some methods
According to the Department of Anatomy & Histology, University of Sydney, an adult human cadaver head cut off at vertebra C3, with no hair, weighs between 4.5 and 5 kg (between 9.9 and 10.23 pounds).
Or you could lie ona table and then rest your unsupported head on a set of scales just over the edge of the table
lisab said:
To what accuracy?
Resolution: < 0.1Kg
Permissible Error: < 0.1 Kg
But you can't assume that the head you are measuring is an ordinary type of head. It could have a ~1kg of bullets stuck on somewhere and the person might still be living. Point is, you neither know its tentative weight nor do you know its mass distribution.
I_am_learning said:
Resolution: < 0.1Kg
it seems a 1kg of bullets is pretty nasty.
Note to Jimmy: buy life insurance and avoid chopping bullets.
I agree with Jimmy on this one; if I can't chop, I'm not interested.
Reminds me of my beloved cousin Alphonse C. Snyder. According to the police report, he shot himself in the back of the head 27 times with a rifle from close range. When I chopped his head off to weigh it, the axe hit several bullets. It was so dull I had to replace it. You can well imagine my grief at the loss.
Well, the mass can be easily measured by balancing torque once you locate the center of mass of the head.
The trouble is thus the center of mass.
Well duh, you silly ***. Everyone knows that you use a titanium axe for gunshot victims. :rolleyes:
Can you elaborate please?
I'm sure this has the correct answer https://www.youtube.com/watch?v=0Jkm6aYYdB8
They covered this on QI. Basically, the technique is to stick your head in a bucket of water and measure the volume displaced. The underlying assumption is that the average density of the head balances out pretty close to that of water, an assumption, they assured us, that is reasonably accurate.
So you're pretty much guaranteed of success if your subject is hydrocephalus.
Hmm, so the OP should go soak his head? Not as good as chopping but it'll do.
I don't think that's accurate Ken. Thats just volume of head x density of water.
I think you can do it by weighing yourself in a pool once with your whole body in, and once with your head above water. Also measure the displacement to get the volumes of your body and head. There are enough knowns to solve your head weight out of water.
Okay, well, what they pointed out on QI is that the way to do it accurately is to use an MRI scanner. However, if you don't have access to such a thing, the head in the backet technique is a pretty good approximation. So they said anyway. Can't say I've ever tried it myself.
If you're not allowed to cut off the head and weigh it, there is an equally accurate and more socially acceptable method. Cut the body off instead, then just weigh what's left over. :rolleyes:
In the text below and in all subsequent replies, 'Torso' refers to Whole body minus head.
Ok. We have volume of Torso and volume of head.
Now, as you suggested to measure,
  1. Weight of whole_body inside water = Actual Body weight - weight of displaced water.
    We don't actually need to measure it, i.e. we won't get any extra information by measuring it , because weight of displaced water = volume of body * density of water
  2. Weight of only Torso inside water= Actual Body weight - weight of displaced water by Torso
    Similar case as above.
So, we don't have enough knowns, but instead to many redundant knowns.
Why don't you just soak your head?
  • · Replies 18 ·
  • · Replies 21 ·
19K
  • · Replies 18 ·
