How Can Uniform Random Variables Simulate a Markov Chain?
  • Topic:
  • Thread starter Thread starter power3173
3 replies · 3K views
power3173
Hi people,
I am a newbie in Markov chains and I have difficulty to solve some questions. I would appreciate very much if I get some help:
1) First question is about: I am given a sequence of U1, U2,U3,... of independent random variables, uniformly distributed on the unit interval (0,1). I am asked to describe how this sequence can be used to simulate Markov chain with state space {0,1} and transition matrix (p11,p12,p21,p22) starting in state 1.
2) Second question is about: an Markov process {Xt} with state space S={1,2,3}, and generator Q (a 3X3 size matrix), starting in state Xo=1. I am asked:
a) Finding limits (t goes to infinite) lim P(Xt=j), j=1,2,3.
b) Finding the mean recurrence time of state 1, i.e. finding expected value of T, where T=inf {t>J1 : Xt=1 | Xo=1} and J1 denotes the time for the first jump.
Thanks in advance...
Let's start with question 1).
Uniformly distributed random variables are often used to simulate random variables and thus also stochastic processes. What you need here is a theorem known as 'the inverse transformation theorem'. Since we're working with Markov chains we need a discrete version of the theorem.
The state space is $\{0,1\}$ that means there're four possible transitions with their probabilities given by the transition matrix. The chain starts in $X_0 = 1$. We want to simulate $X_1$. There're two possible outcomes, the chain could go from state $1$ to state $0$ or it can stay in it's original state (namely $1$). In other words, $X_1$ is a Bernoulli distributed random variable with probabilities $\mathbb{P}(X_1 = 1) = p_{2,2}$ and $\mathbb{P}(X_1 = 0) = p_{2,1}$. To simulate such $X_1$ we need the transformation theorem. Generate a uniformly distributed random variable $U_1$ and set $X_1 = 0$ if $U_1 \leq p_{2,1}$ and set $X_1 = 1$ if $U_1>p_{2,1}$. According to the state of $X_1$ we can similarly simulate the r.v $X_2$. If $X_1 = 1$ then repeat the above process. If $X_1 = 0$ then also follow the above process (with a new uniformly distributed r.v $U_2$) with the only difference that the probabilities you have to use now are in the first row of the transition matrix.
Clearly this algorithm can be extended to simulate Markov chains with bigger state spaces.
power3173 said:
Hi people,
Wellcome on MHB power3173!...
... regarding the second question [point a)] if Q is the transition matrix, then by definition is...
$\displaystyle P \{ X_{t} = j | X_{0}=1 \} = u\ Q_{j}^{t}\ (1) $
... where u = [1,0,0] and $Q_{j}^{t}$ is the vector corresponding the the j-th column of $Q^{t}$ ... the required limit depends from the value, if it exists, of $\displaystyle \lim_{t \rightarrow \infty} Q^{t}$...
... for the point b) You have to find first the so called hitting time which is defined as...
$\displaystyle T_{1}= \text {inf}\ \{t \ge 1 : X_{t}=1 | X_{0}=1 \}\ (2)$
... then the quantity ...
$\displaystyle f^{(n)}_{\ 1,1} = P \{T_{1} = n \}\ (3)$
... and finally...
$\displaystyle E \{T_{1} \} = \sum_{n=1}^{\infty} n\ f^{(n)}_{\ 1,1}\ (4)$
Kind regards
$\chi$ $\sigma$
Thanks a lot for your contributions #Siron and #chisigma
