How can we combine metal and fiber together?
  • Thread starter Thread starter Thenymphadora
    Fiber Metal
The discussion focuses on the best methods to combine carbon fiber composites (CFC) with metal, specifically in underwater conditions for engineering projects such as shipbuilding. The consensus is that using a high-quality epoxy, such as those from 3M, is the most effective method for bonding these materials, particularly when applied to overlapping surfaces. Additionally, the use of ANSYS software is suggested for testing the strength of the bond, although alternatives may be necessary if ANSYS cannot generate tensile graphs.
  • Understanding of carbon fiber composites (CFC)
  • Knowledge of epoxy adhesives suitable for metal bonding
  • Familiarity with ANSYS software for structural analysis
  • Basic principles of material science regarding metal and composite interactions
  • Research the properties and applications of 3M epoxy adhesives for metal and CFC bonding
  • Learn how to use ANSYS for tensile strength testing and analysis
  • Explore alternative software options for composite material testing
  • Investigate the effects of different loading mechanisms on bonded joints
Engineering students, materials scientists, and professionals involved in composite material design and shipbuilding who are looking to effectively combine metal and carbon fiber composites.
Thenymphadora
Hello,
I would like to ask something here. If I would like to combine metal and fiber, what method is the the best because we can't simply glue them together. what material can hold them together. And can we test the strength of them after they stick together using ANSYS software? It would be great if Ansys can generate tensile graph as well. If ANSYS cannot, what software should i use?
(I'm sorry if my english is not good)
What do you mean by combine? If you want to throw a layer of some material on a sheet of metal, you can absolutely glue it on. Elmer's won't work, obviously, but an appropriate selection of epoxy or similar material would in many cases.
Actually I am doing an engineering project for my bachelor. I am looking for a method to use both metal and fiber together in underwater condition. We can't simply glue them together if we are building a ship from metal and fiber. So I am looking for the strongest way to combine them together.
Thenymphadora said:
Hello,
By "fiber", do you mean carbon fiber composites? Or do you mean a fabric of some sort?
yes..its carbon fiber composites.
Are you talking about a sheet of metal (steel or aluminium?) and a sheet of CFC? In that case some form of epoxy should work.
Best results would obviously be achieved if you use the epoxy on overlapping faces of the sheets, i.e. not end to end. This wille depend on the expected loading mechanism on the joint
As far as putting CF on steel, really some form of epoxy (call 3M and see if they have anything to fit your application) is, as far as I know, your only real option. Drilling holes for bolts and rivets may (or will likely) decrease the structural integrity of the CF.
Are you are talking about some sort of steel subframe, rather than sheet-on-sheet?
My question: what do you hope to gain from the addition of CF on steel (from what I understand, CF and Aluminum don't mix well over the long haul, though there are ways around that I think)? They're both strong, but they have different stiffnesses, and that will likely become a major problem when the components are loaded and unloaded.
Is this for a hull, or a keel, or what?
Adding steel to CF kind of defeats the purpose of the CF in the first place, no?
This article might be of some help. Worth a look
http://www.westsystem.com/ss/testing-large-bonded-in-fasteners/
Check out this thread as well: Here
Thanks Travis King.. I am starting to find my answer in the article you linked me.. Thanks for everybody help..
  • · Replies 21 ·
