How Can We Model and Simplify the Melting of an Ice Cube?
The discussion focuses on modeling the melting of an ice cube in a thermodynamics context. Key assumptions include considering air convection, the formation of a water pool around the ice, and the impact of heat conduction and radiation. A proposed simplification involves placing the ice cube on a grating to facilitate water drainage, thus isolating air convection effects. A calorimeter is suggested as a simple experimental setup to test the model.
  • Basic understanding of thermodynamics principles
  • Familiarity with heat transfer concepts, including convection, conduction, and radiation
  • Knowledge of calorimetry and its applications
  • Ability to formulate and analyze mathematical models
  • Research heat transfer mechanisms in thermodynamics
  • Learn about the principles of calorimetry and its experimental setups
  • Explore mathematical modeling techniques for phase changes
  • Investigate the effects of shape and surface area on melting rates
Students in thermodynamics courses, educators teaching heat transfer concepts, and researchers interested in phase change modeling.
kimmyS
Hi everyone, I am new to this forum. I am taking an undergraduate thermodynamics course and got stumped by this problem. I found this forum and figured that someone here would be able to help me with this! :-p
Develop a model for melting of an ice cube. What assumptions can/need to be made? What is difficult about this problem? What type of simple experiment could be conducted to test the solution?
Which equations would be appropriate to develop this model?
Initially you only have convection of the air around the ice cube to worry about. However, as the ice melts, you have a growing pool of water developing around the ice cube that changes temperature with time. This complicates matters even more. One way to simplify this would be to put the ice on a grating to allow the water to drip off. Then you only need to worry about the air convection.
Please, any help would be great! Thanks! :smile:
Some more complications:
The ice cube changes shape as it melts.
There will be evaporation of the film of water covering the cube.
more complications
Heat conduction from the surface it is sitting upon.
Radiation heating if it is in a lit area.
Simple experiment, do the whole thing in a calorimeter.
  • · Replies 87 ·
9K
13K
