How can you generate a sine wave using integers only?
intervoxel
TL;DR
A recursive generator of a quadrature signal which fits exactly in a NxN grid, where N is a large power of two.
I need to recursively generate a quadrature signal which fits exactly into a grid NxN, where N is a large power of two.
After unsuccessful research, I decided to develop my own solution, starting from the waveguide-form oscillator taken from Pete Symons' book 'Digital wave generation, p. 100'.
\begin{gather}
\begin{bmatrix}\hat{ y_1}\\\hat{y_2}\end{bmatrix}
\begin{bmatrix}
k &k-1\\
k+1&k
\end{bmatrix}
\begin{bmatrix} y_1\\y_2\end{bmatrix}
\end{gather}
where [itex]k=cos(\omega T)[/itex].
This formula works perfectly when using floating point numbers.
In the case of the NxN grid, we have [itex]\omega T=2\pi/N[/itex], and the amplitude is [itex]N/2[/itex].
For [itex]N>>1[/itex], we have [itex]k=N/2-1[/itex].
The difference equations then become
\begin{gather}
\hat{ y_1}=\frac{2((N/2-1)y_1 - y_2)}{N}
\end{gather}
and
\begin{gather}
\hat{ y_2}=\frac{2((N-1)y_1 + (N/2-1)y_2))}{N}
\end{gather}
If we initialize [itex]N=128[/itex] and [itex]y_1=N/2[/itex], [itex]y_2=0[/itex], we get for the first iteration the values [itex]\hat{y_1}=63[/itex] and [itex]\hat{y_2}=127[/itex] (it was expected a low value!). That is, [itex]y_2>N/2[/itex].
What went wrong? Thank you for any help.
I don't know where k=N/2 - 1 comes from, but with k getting larger your numbers will get too large as well. This is true for floating point numbers as well.
Thank you for answering. DDA uses floats not pure integers.
Of course the modified k grows, it is an integer constant.
The rationale for the modified expression for k is:
[tex]lim_{N\to\infty} \frac{N}{2}sin(2\pi/N)=\pi[/tex]
[tex]sin^2\theta+cos^2\theta=1[/tex]
[tex]\overline{k}=\sqrt{\frac{N^2}{4}-\pi^2}[/tex]
for [itex]N>>1[/itex] we have
[tex]\sqrt{\frac{N^2}{4}-\pi^2}\approx \frac{N}{2}-1[/tex]
From the Wikipedia article: "The DDA method can be implemented using floating-point or integer arithmetic. " I know that it is so, because a research institute I once worked for implemented a version using only digital logic chips back in the late 60's.
You are right, a DDA variation called Bresenheim algorithm for circles works with integers. Thank you.
